Question about Refrigerators
I have a THETFORD REFRIDERATOR N112E in my caravan when we use it on the mains electric some times works for a few hours then stops working all together for no reason we can find, read all the instructions in the manual tried everything there, eg: level ok,works off the gas ok.
5 Suggested Answers
22yooper
  • 828 Answers
SOURCE: Dometic Caravan Fridge 7271
Your refrigerant may have completely separated in the system. Shut of the gas, disconnect the electrical and remove refrigerator from the coach or if you have sufficient room inside set it on a clean area. This operation is what is called burping the system.
1. From the base roll it onto the door and wait five minutes.
2. roll it onto the top and wait five minutes.
3. Roll it on the back and wait five minutes.
4. Return it to the base and wait five minutes.
Reinstall it or test it on electrical. It should show signs of cooling in about 30 minutes in the freezer compartment if the system is not plugged in the boiler.
Posted on May 26, 2008
22yooper
  • 828 Answers
SOURCE: Thetford Fridge N112
There is a very likely possibility that the resistance heater for the 12 Volt side of the operation is open. This heater can be checked for continuity using an OHM meter from the terminals for the 12 volt .
Posted on Jun 02, 2008
SOURCE: I have a Dometic rm2807
Check out this site www.rvcoolingunit.net
Posted on Jul 28, 2008
  • 68 Answers
SOURCE: thetford caravan fridge freezes all food in fridge
Thats a Norcold compact fridge. The most likley problem would be the thermister. Need to do an ohms reading. From inside of the fridge remone the thermister from the fins and unplug the wires. With a VOM set it on Ohms, touch the wires with the probes/ does not matter which probe to wire/ hold the bulb end of the thermister between your fingers, your reading should stat at about 7000 Ohms. Stick the bulb end of the thermister in a glass of ice water, reading should start climbing and go to about 22000 Ohms. If this happens the thermister is good and you need to look elsewhere. If it does not test out you need to replace the thermister. The thermister is a thermostat that controls the heat source that makes the fridge cool. If the thermister reads good you may want to get the circuit board tested.
Hope this helps
Thank you for using Fixya
Jerry
Posted on Mar 30, 2009
Thetford n97 fridge runs ok on electic for 6 hours then flashes up diagnostic No 14 and stops working
Error code 14 usually means that the powerboard is faulty. This would require replacing, it is found in a black box at the rear of the fridge.
Oct 28, 2011 | Thetford Porta Potti
How do i stop the shelves in my Thetford N112 caravan fridge from jumping out of their slots, when i'm travelling? Yes! i have attached the shelf clips correctly. I'm using a washing peg to hold...
I don't have a Thetford but my Dometic used to do that also. I went to the hardward store and bought velcro stick ons and that has worked great from me, even on some of the rough roads.
Aug 12, 2011 | Refrigerators
Hi our thetford cassette toilet (c200)blows the fuse every time we touch the flush button.can anyone please help. WE have only had the caravan for two days and has never worked. THANKS
Probably the rotor has come to a stand still (carbonade). I suggest you will clean the rotor with an house-hold acid liquid (like the one for cleaning coffeemachines).
Flying Dutchman.
Jan 17, 2010 | Thetford Porta Potti
Hi, have a built in thetford toilet in my caravan. The pump has stopped working. How do I check and remove the pump if required? Thanks Rosco
Don't send money. Just go to thetford.com and download info.
Some tips - if seal is old and breaking up make sure you recover all the bits which have fallen into the flush water tank. If new o-ring seal not available use outdoor silicone sealant and allow to set for 48 hours before adding anything other than a small amount of water to test flush action. Electric circuit includes a fuse and microswitch which are both contained within the flush water tank but you are unlikely to have problems with these items.
Nov 04, 2009 | Thetford Porta Potti
Electric diagram c2
go to thetford main site, you can download all manuals and diagrams
Jul 02, 2009 | Thetford Porta Potti
I have a Thetford Porta Potti 465 electric. The
Good news , you can go to ;
www.thetford.com/products/toilets/
Click on " Support " , and you should get the help you need .
Good luck !
Alec .
Sep 05, 2017 | Thetford Porta Potti
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
