Question about Kenmore 12102
Kenore Sewing Machine Model # 158 Series
Feed dogs don't come up and the fabric will not feed--I've adjusted the wheel inside the head from 0 (darn setting) to 4 and it doesn't appear to raise them or lower them. Can you help me?
  • 323 Answers
Remove the needle plate and clean the lint from the grooves in between the teeth. If there is none, while the plate is off ,move the lever and see if they will raise and lower. If they will not, you probably need to see a technician.
sewman7
Posted on Jun 18, 2008
Fabric not advancing
Make sure the feed dogs are not in the dropped position (for darning).
If it is very light-weight fabric, most machines will have a presser foot pressure adjustment that will increase the presser foot's pressure on the feed dogs, thus pulling the fabric through better.
Make sure the feed dogs are clean--no debris stuck between the teeth, under the feed dogs, or around the bobbin case. If it is an older machine that has been used a lot, the feed dogs could be worn down and need replacement or adjustment. (Do not run the machine with the presser foot directly on the feed dogs. This will cause excessive wear to the feed dogs and the presser foot.)
Jul 25, 2017 | Sewing Machines
My fabric won't feed
Check that the feed dogs have not been dropped for darning or free motion quilting. If the feed dogs do not rise above the needleplate, they will not pull the fabric through the machine.
Feed dogs do wear (which is why one should always sew with fabric against the feed dogs--never on bare metal).
Something else that happens is that gunk builds up between the teeth of the feed dogs so that they no longer have the grip they need to move the fabric.
Another thing to check is the presser foot "pressure." A lot of sewing machines have a pressure adjustment that increases or decreases the amount of pressure the presser foot applies to the fabric and feed dogs. (Consult your owners manual.) he pressure can be adjusted according to the type of fabric being sewn.
http://www.sewdaily.com/how-to-sew/sewing-machine-basics/the-best-kept-secret-on-your-sewing-machine
http://makeitsew.biz/presser-foot-pressure
Adjusting the presser foot pressure on your sewing machine
sewing patternreview com
Sep 04, 2016 | Sewing Machines
I only have a small amount of feed through the sewing claw, i mostly have to pull it through on my Toyota 2400, is this normal is is something wrong?
Unable to locate much information about your make/model machine.
If your machine has the capability of dropping the feed dogs for darning or free motion quilting, check that the feed dogs are in the up position for sewing. Also, verify that the stitch length is set to at least #2. Any shorter stitch selection will cause the machine to advance the fabric so slightly that it will nearly sew in place.
Some machines also have a pressure adjustment for the presser foot. If the fabric you are sewing is very fine, the feed dogs may have difficulty gripping the fabric to advance it through the machine. You can add body to the fabric by including a stabilizer when sewing the fabric, ie a wash-away stabilizer.
May 05, 2016 | Toyota Sewing Machines
Material won't move? How to adjust feed dog if that is the problem
Is the feed dog raised into sewing position and not dropped as for darning? Feed dogs need to be in the raised position in order to pull the fabric through the machine.
If the stitch length is set too short, it will cause the fabric to barely move thereby causing the machine to stitch in one place.
Raise your presser foot and gently rotate the handwheel and watch the feed dogs. Do they rise when coming to the front of the machine, move toward the back of the machine, drop down below the needle plate, and move forward to the front of the machine again? If so, the feed dogs are working properly.
If the feed dogs never rise, they are in the dropped position for darning or free motion quilting when you would move the fabric manually.
If, on the other hand, the feed dogs do not move at all, then they are seized and you should probably get your machine serviced.
Apr 09, 2016 | Sewing Machines
My sewing machine wont RUN. The needle goes up and down but the material wont move along.
under the foot around the needle, there should be two rows of what look like teeth, these pull the material through and there will be an adjustment mechanism on the machine. Try leaving the foot up while you run the machine, you should see the teeth going up and down; if they are it is most likely just a case of setting up the amount of pull. I think it is adjusted with the wheel that sets the length of stitch.
Apr 07, 2016 | Sewing Machines
How to bring sewing foot holder to embroidery position
Hi, I hope this helps. If it doesn't post again.
"Check:
Place the sewing foot under the sewing foot
holder so that the pins of the foot snap into
the sewing foot holder when the presser foot
lifter is lowered.
Please check that the sewing foot is properly
engaged by raising the presser foot lifter
Question: Are you using top feed? If so:
"For all sewing jobs with the top feed, only use sewing feet with Cutout at the back (OA, 1A, 3, 4)."
Embroidery foot Part No.: 98-694-840-00 will not work with top feed.
Also, except for eyelets, the darning foot can be used for embroidery.
I'm not sure what you're trying to do :) darn or embroider :); I'm not sure what mode you're working in either; embroidery mode?
Darning with straight stitch
Program 00
Fit darning foot No. 6.
Set the needle at its highest position by turning
the handwheel, and push the pin of the darning
foot fully into the hole of the sewing foot holder
slightly pressing the darning foot between thumb
and forefinger. When doing this, the guide fork
should place itself around the presser bar and the
wire must be behind the fixing screw.
Darning position:
Lower the presser foot lifter pressing it lightly to
the rear until it snaps into the darning position.
Important Only in this position you have the
optimum thread tension for darning.
• Place the darning work in the darning hoop.
• Lower the feed dog.
• Pull up the bobbin thread and hold the threads
when you start sewing.
• Now guide the fabric back and forth evenly;
the length of the darn will be set by the size of
the hole. As you are determining the stitch
length yourself while sewing with the feed dog
lowered, you should sew at an even speed.
When you have reached the width of the dam
aged area, darn over the damaged area again
from right to left.
This guarantees a durable darn.
TIP: The faster you sew, the easier and more even
the darning will be. It you are moving the workpiece
too slowly, small knots will appear on the
wrong side of the fabric."
Whether working with terry-cloth or woven fabric,
with the help of the darning foot and the pro
gram 02 you can embroider initials of your own
design
Drop the feed dog and insert the darning foot.
Put the machine into the darning position.
Spread the fabric in an embroidery hoop and
embroider in accordance with program 02.
Lower feed dog
If the feed dog is not lowered for embroidering, the
machine does not embroider when the foot pedal
is pressed and the message appea rs:
Lower feed dog
ok?
The feed dog must be lowered in embroidery
mode.
Jun 20, 2015 | PfaFF Creative 7570
Fabric won't feed
if the feed dogs don't move at all, they need to be checked, to see if they need a adjustment, or they may need to be replaced
May 27, 2015 | Singer Sewing Machines
The fabric is not advancing when I sew. What can I do to fix it?
The feed dog are probably dropped lower than the the throat plate. Most machines have a setting for darning that requires that the feed dog to be dropped below the sewing surface. There is a separate knob to change the feed dog from this lowered position so the feed dog, when the balance wheel is rotated will come up above the sewing surface to move the material. Another thing could be that the stitch length lever is set on "0". This is basically telling your machine not to advance any material through it and you will get a big knot instead
Feb 15, 2015 | Sewing Machines
How do I adjust the feed dogs to pull the fabric through. Right now it'll just stitch in place. Help Please! Thank you
Is the stitch length set to 0 or is it set to DARN?
Other than that is pretty hard to say without knowing the brand and model number of your machine.
sewing machine will not feed YouTube
Oct 20, 2014 | Sewing Machines
Kenmore sewing machine 158-17182..sold by sears.. it was bought in 80s..I need to raise the feed dog..the fabric won't feed. .
I believe the solution would be to adjust the foot down till you achieve your fabric feed. GOOD LUCK FRIEND.
Sep 23, 2014 | Sewing Machines
Kenmore 12102 Logo
117 people viewed this question
Top Kenmore Sewing Machines Experts
Tally Girl
Tally Girl
Derek Massey
Are you a Kenmore Sewing Machine Expert? Answer questions, earn points and help others
