Question about Watches
Cannot get to time zone to change from daylight saving to standard When I rotate 'Mode' I cannot get 'Time Mode'
escapement
  • 2334 Answers
SOURCE: Daylight savings time switch?
Visit www.citizenwatches.com
Choose TECHNICAL SUPPORT and solve all problems.
Posted on Dec 18, 2008
SOURCE: Eddie Bauer wireless thermo clock - Time zone problem
TIME ZONE SETTING
The cefault time zone is PACIFIC. lf your location is not in the Pacific zone, set the
time zone as follows:
1. In normal time mode, press the "[,4ODE" key to enter the alarm time mode. 2. ln aiarm time mode, press and hold the ADJ . 'Cl"F" key for 2 seconds to enter
the time zone setting mode.
3. Press ihe "ADJ "C/'F" key to select the proper time zone: P=Pacific
M=Mountain C=Central E=Eastern 4. Press the f,'lODE key to save and exit the time zone setting mode, or let it exit
automaiically 30 seconds later without pressing any key.
Posted on Apr 04, 2009
escapement
  • 2334 Answers
SOURCE: Daylight bloody savings
Follow this link:
http://world.casio.com/wat/download/en/manual/
Rate me, please.
Posted on Apr 08, 2009
  • 2501 Answers
SOURCE: daylight saving time
You can get instructions from the Citizen web site.
Go to "citizen.com" and on the upper right there is a menu. Click on "technical support" and then on "setting instructions"
Fill in the information required from the back of your watch and then click on "get setting instructions"
Posted on Apr 13, 2010
  • 12 Answers
SOURCE: Can you give me the step-by-step process to switch
From the main time display, hold down the adjust button until it beeps and your time zone is flashing on the bottom of the display. Then press the mode button once. [AUTO/ON/OFF] DST will be flashing on the bottom. Use the Time Memo and/or Receive buttons to cycle the mode. When it's what you want, press adjust twice.
Posted on Mar 13, 2011
Testimonial: "Simple, perfect solution arrived 5 minutes after I posted my question; thanks, FixYa!!"
Can you give me the step-by-step process to switch the time from standard to daylight savings?
Mar 13, 2011 | Casio G-Shock GW500A-1V Wrist Watch
I have a Waveceptor 3353. If I change time zone I can usually set the watch to show ,say, Paris time both digitally and in analogue. When I try to go back to my home time zone, London, the second hand...
If you cannot find the automatic way of setting the hands, you can manually reset the analogue hands by pressing the mode button until you reach the "HS" mode and using the 2 or 4 o'clock buttons to adjust the hands.
Dec 30, 2010 | Casio DW9051B-1V Wrist Watch
How to set time on a timex 1440 sports watch
1. Press mode button (bottom button left side) until the time and day appears.
2. With time and day showing press and hold set button (bottom right side).
3. City codes will flash. Press start/stop to select city that represents your time zone.
4. Press mode daylight saving time setting flashes. press start/stop to obey or disregard radio signal for atomic time.
5. Press mode hour flashes. Press start/stop to change hour (include AM/PM)
Repeat the above step for the remaining values ( minute, seconds, month, day etc)
Press set an any step when finished.
Oct 20, 2010 | Watches
Crane & Villeroy watch (radio controlled) After fitting a new battery it shows the time 1 hour behind the correct time.
It sounds like your watch is on daylight saving time (DST) or it is set to the wrong time zone.
If you press the "Mode" button you will enter the settings menu and you should be able to change this by pressing one of the other buttons. Some experimenting will be needed.
Sep 18, 2010 | Watches
Need instructions for my sr927w accurist watch
QUICKSTART - SET THE TIME
1. Push the bottom right hand button until the mode hand indicator points to TME.
2. Press and hold the upper left button for three
seconds. The hour and minute hand will retract to the 12
O’clock position.
3. Select the time zone on the digital display by pressing the
upper right button or the lower left button.
4. Pull the bottom right button out one click. The bottom part of
the digital display will start flashing. Press the
bottom left button to adjust for daylight saving time.
5. Press the upper right button. You will see the seconds
flashing on the lower half of the digital display. Press the lower
left button to reset the seconds to 00.
6. Press the upper right button. You will see the minutes
flashing. Press the lower left button to set the minutes to your
current time.
7. Press the upper right button. You will see the hours flashing.
Press the lower left button to set the hours to your current time.
8. Press the upper right button. You will see 12H or 24H
flashing. Press the lower left button to switch between 12 hour
and 24 hour.
9. Push the lower right button back in.
SET THE CALENDAR
indicator points to CAL.
2. Press and hold the upper left button for three seconds. The
hour and minute hand will retract to the 12 O’clock position.
4. Pull the bottom right button out one click. You will see the
month flashing on the digital display. Press the lower left button
to change the month.
5. Press the upper right button and the date will begin flashing.
Press the lower left button to change the date.
6. Press the upper right button. You will see the year flashing.
Press the lower left button to change the year.
7. Push the lower right button back in.
SET THE ALARMS
indicator points to AL1, AL2 or AL3.
4. Pull the lower right button out one click. You will see ON or
OF flashing on the digital display. Press the lower left button to
turn the alarm on or off.
5. Press the upper right button. You will see the hours flashing.
Press the lower left button to change the hour.
flashing. Press the lower left button to change the minutes.
SET THE TIMEZONE
1. Setting the time zones allows you to add or remove cities on
the digital display or switch between daylight saving and
standard time. Begin by pressing the lower right button to move
the mode hand indicator to SET mode on the bottom dial.
2. If the hour or minute hands are obscuring the digital display,
press and hold the upper left button for three seconds. This will
cause the hour and minute hand to retract to the 12 O’clock
position.
3. Now pull the lower right button out one click. You will see the
digital display flashing. Press the upper left button to select
SET to display the city or OFF to not display the city. Press the
lower left button to turn summer time on or off. Summer time is
indicated on the lower part of the digital display. Daylight
savings time must be manually set for each city.
4. Pressing the upper right button will allow you to scroll
through all the cities. After setting, push the lower right button
back in.
USING THE TIMER
1. Press the lower right button to move the mode hand
indicator to TMR mode on the mode dial.
position.
3. Pull the lower right button out one click. You will see the
minutes flashing in the digital display. Change the minutes by
pressing the lower left button. Once you have set the minutes
on the timer, push the lower right button back in.
4. Pressing the upper right button starts and stops the timer.
5. Press the lower left button when the timer is stopped to reset
the timer to its initial preset time.
USING THE CHRONOGRAPH
1. To use the chronograph press the lower right button to move
the mode indicator hand to CHR mode on the mode dial.
3 .To start or stop the chronograph press the upper right
button. If you press the lower left button it will display the split
time for 10 seconds.
4. When the chronograph is stopped press the lower left button
to reset back to zero.
SET THE TIME ZONE
the mode indicator hand to SET mode on the bottom dial.
savings time must be manually set for each city..
through all the cities. After setting, Push the lower right button
back in one click.
Hope this helps. =)
Oct 10, 2009 | Bulova Watch
Cannot change from 24 hour to 12 hour also did not change to daylight savings time
To change from 24 hour to 12 hour, you hold down the "Mode" button until it switches from 24 hour to 12 hour or vice versa. To change the time zone, you hold down the "Set" button until the time zone that you set it in flashes (like "LAX" on my watch). Then you press the "Receive/Start/Stop" button to choose the specified time zone you want. To set for daylight savings time ("DST" on the watch), after holding the "Set" button and having the time zone flash, you could press the "Mode" button. It will give you a few options for the daylight savings time (Auto, On, or Off). I chose the "On" option, which immediately changed for daylight savings time. If you manually want to change the time, you could hold down the "Set" button and keep pressing the "Mode" button until the time starts flashing on your watch, then pressing the "Receive/Start/Stop" button until you change it to the time that you want. You could also set the watch to beep or chime after pressing the set button if you wanted to know that piece. You hold down the "Set" button when you are done to get it to stop flashing. These instructions worked for my Timex T5G341 Universal Radio Control Watch. I hope this helps.
Mar 08, 2009 | Timex T5G341 Sports Radio Control Watch
TIME ZONE SETTING
Mar 08, 2009 | Watches
Echo drive skyhawk,My watch's time zone is always one hour behind
You posted this in January, which is not during daylight savings time. The SMT setting doesn't turn on automatic DST switching for a particular timezone; rather, it is a manual override to adjust timezones to DST when it is actually active. There is no automatic DST adjustment for this watch (according to their FAQ). Turn SMT to OF for all timezones during winter months, and ON for applicable timezones during SuMmer Time (SMT).
Jan 17, 2009 | Citizen Skyhawk Eco-Drive JR306059F Wrist...
Timex T5E881
You have to get in the right time zone, that’s why you are an hour off (and this may also occur if you are in an area that switches between daylight savings time each spring and fall).
Press mode until ZO appears on the watch face.
Press and hold ADJ. Time zone will begin to flash.
Select start/stop or adjust to get to the right time zone P, C, M, E (pacific, eastern, Mountain, central)
If desired , press mode to select DST (daylight savings time) and press start/stop or adjust to turn it on or off.
Press adjust when done.
Nov 10, 2007 | Timex 1440 Nylon watch
Watches Logo
23 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
