Question about Apple iPhone Smartphone
I cannot make or receive calls in my iphone
I had error 1604 first in my itune and after being restored now i cannot make or receive calls
  • eporter717 Jan 13, 2009
    cannot make or receive calls with my 16gb iphone
  • 20 Answers
Press and hold the top power button and the menu button on the front simultaniasly until the iphone symbol comes back up. this performes a reset
Posted on Jun 16, 2008
I dropped my iphone 2g 16GB in a toilet bowl last month. I managed to dry it out but currently having problems in restoring it. ITunes just keep giving me errors like 1611, 1604, 23 and so on. I tried to...
Hey Chee, Usually an iphone with liquid damage may cause damage to internals that may go unnoticed if it is able to work. Depending on the error message you get when restoring with itunes may mean different things.
  • 1604 is just to check your usb cable to make sure its directly (not through a hub) connected to a usb 2.0
  • 1611 and 23 are usually hardware issues that cannot be solved with a restore
Mar 08, 2011 | Cell Phones
Tip
How To Fix 1601, 1602, or 21 Error Codes During iPhone 3.1.2 or 3.1.3 Custom...
Are you trying to downgrade or restore your iPhone or iTouch from the official 3.1, 3.1.2 or 3.1.3 Firmware to a Custom Firmware and your iTunes displaying the following 1601, 1602, 16xx or 21 error codes? iH8sn0w has just released a utility named iREB (iTunes Restore Error Bypasser), which provides a workaround to fix these errors.
iREB is available for both Windows and MAC Operating systems. Tool runs on both iPhone & iPhone 3G with Firmware 3.1, 3.1.2, 3.1.3, and also on iPod touch 1G and 2G.
So here is the work around for 1601, 1602, 1604, 16xx or 1621 Error Codes…
New version of iREB is out for 3.1.2 Devices… If you’re upgraded to the latest firmware (3.1.2 or 3.1.3) you should use this download / tool for the errors you’re experiencing. New version has additional devices and more options available.
1. Download iH8sn0w’s iREB 3.1.2 archive for Windows or Mac.
2. Start iTunes and put your iPhone in Recovery Mode; to do so, hold Home and Power button in your iPhone simultaneously and release Power button after a while (10 seconds approx). Keep on holding Home button, till you see following error message appearing in iTunes stating.
3. Now close iTunes and start iREB, following interface will open.d00f484.png
4. Now select your plugged in device in iREB 3.1.2 and it will then show the White creen after few seconds. This happens fast so if you didn’t see it don’t worry… You will also hear sounds (maybe) like your iPhone is being plugged in and unplugged from your computer… That’s normal… The ih8sn0w.exe will crash… That’s normal, as long as you get a white screen…
5. NOTE: If you still don’t see the WHITE screen, you should do this… While the device is still plugged in and iREB running, put your device into the DFU mode. PRESS and HOLD both buttons on your iPhone for 12 Seconds and then release the POWER button (Located at the top of your Device) while still holding down the HOME button… Hold down the HOME button for 30 Seconds… (Yes 30 Seconds) until you get the WHITE Screen, the iTunes will come up with a message stating it found an iPhone in Recover Mode… At this point you can let go of the HOME button… you will be asked to restore this iPhone… and the iREB tool will crash
6. Now start iTunes again and select your device (iPhone/iPod) from iTunes DEVICES tab.
7. To restore original settings on your Apple device, press and hold left “OPTION” button on the keyboard (“SHIFT” button for Windows), iTunes will give you option for Upgrade and Restore, click on “Restore” option in the iTunes and then release the “OPTION/SHIFT” button. Select .ipsw file and restore it
on Jul 08, 2010 | Cell Phones
My iphone 3gs suddenly turn off and won't turn on
You need a new logic board. Apple should give you a replacement. If you're out warranty, you can try to open it and replace the logic board yourself. You can get the part at iPad Repair and there is a guide that shows you how to open a kindle and install parts at iPad Repair Guide.
Nov 16, 2009 | Apple FOR APPLE IPHONE 3Gs PHONE CAR+HOME...
Lock up after trying to install 3.0
There are a lot of suggested solutions on different forums for the 1604 (including on the Apple support site) - most blame a faulty / corrupted itunes and suggest reinstalling, or blame the USB port you're using and suggest either trying a different port (ideally at the back of your HD) or different computer. None of those things worked for me when it happened to me. My issue was that the 'preparing to restore' phase of restoration became looped and eventually it crashed citing error 1604.
However, there was a solution at: http://daggle.com/iphone-upgrade-fail-701 which did work for me.
For convenience:
1. Start the restore process (whatever way you can).
2. When it seems to be stuck in the loop (and possibly your iPhone just shows a blank screen) use CTRL+ALT+DEL and end task to kill the iTunes application.
3. Restart the restore process.
Jun 18, 2009 | Apple iPhone Smartphone
Error 1604 and Kernel Panic
confirm that your firmware is compatable with your iphone.
if you have a 2G the firmware should start with 1.1 if you have a 3G the firmware should start with 1.2
apparently unlocked or jailbroken phones with the wrong firmware will brick in this manner.
not to worry, your not the only one.
do a web search for error 1604 and you will see solutions such as this below.
  • Problem: I cant restore my custom firmware. I just get error 6, 1, 2, (something low).
    Solution: This has multiple causes. Generally, you are not in DFU mode. See DFU guide. Winpwn solution after ruling out the above: Delete the device file (x12220000_4_Recovery.ipsw) in your iTunes folder. (Search for the file). This can also be caused by using the incorrect firmware image (a 3g on a 2g for example).
  • Problem: I am in DFU mode and I just get error 1604, 1602, 1601 (some 160x). I am pulling my hair out! What do I do?!
    Solution: This one sucks. There’s no single answer for it. Here are some possible suggestions:
    • Validate you are using the correct firmware. You can get this if you are using an incompatible firmware (3g for 2g for example).
    • Restart your computer and try again.
    • Try another computer
    • Try switching USB ports
    • Uninstall and reinstall iTunes 7.7
If you are not able to get out of DFU mode even after trying one of the above fixes, click here to follow the comments on BigBoss’s website.
Apr 17, 2009 | Apple iPhone 3G Black Smartphone
Iphone cannot restore with itunes
Try the following links:
http://amountaintop.com/error-1604-when-upgrading-your-iphone-version-1-1-1
http://support.apple.com/kb/TS1458
Oct 22, 2008 | Apple iPhone Smartphone
Apple iPhone Smartphone Logo
143 people viewed this question
Top Apple Cell Phones Experts
Computer Repairing
Computer Repairing
Lesley Cameron
Lesley Cameron
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
