The door is not opening easily and tape runs for approx.2 sec. during playback then right hand reel table stops and the deck switches to stop. FFW/REW is OK.
I have same problem with 2 sec playback then stop on technics rs tr232. need advice and enlightenment so repair guy doesn't rip me off.
Posted on Nov 14, 2010
Pioneer CT-W350R Double Cassette Deck will not playback.
Might need belts and a good cleaning.Rotation sensor not detecting reel table rotation. It is doing what it is suppose to do when at the end of the tape but you tape may not be at the end.
Nov 20, 2012 | Audio Players & Recorders
AIWA AD-F810 reel torque
If you have a service manual, go to exploded view 3 and look at 31.
This is the FR idler sub assembly. Check the rubber tyre or tire, see if it has hardened. This is driven by the reel motor and flip-flops between the table reel assemblies to drive fast forward,reverse, and play take up.
Also check the reel assemblies for oil that's gone to gunge.
I'm using brass valve oil with PTFE by Denis Wick, That's musical !
Feb 11, 2012 | Audio Players & Recorders
Aiwa AD-F810 when a tape is place and I try to close the door it won't but it will close and open with out any tape ? the deck is mint
i had the same type deck years ago, some decks have a two part door, make sure the outer door is clipped on to the inner mechanism correctly, may just have to be popped off. then re pop back on to inner door. jim d
Apr 26, 2011 | Samson Audio Players & Recorders
I have a single cassette deck Philips DC 900 when you hit the play button,it plays for about 5 seconds then stops and head retracts. Belts have been replaced
It's not seeing the takeup reel turning.
Either the takeup reel isn't turning or the takeup reel sensor has malfunctioned.
Check the belt to the takeup reel by doing a fast forward.
Will it fast forward? and is the takeup reel spinning during playback?
Feb 27, 2011 | Audio Players & Recorders
Akai gx-625 reel to reel tape deck has no sound
This could be a head fault? Another possibilty is the preamp stage. You will need to look for something that would take out both channels. Such as an IC.
Aug 26, 2009 | Audio Players & Recorders
Emerson EWV403 VHS VCR stops taping and powers off spontaneously
There are probably a few different ailments which can cause this. One is if something is afoul in tape transport. I'd think the problem would occur whether in record or playback however.
If the tape takeup reel drive is slipping, tape takeup might intermittently stop, and cause the machine to power off (this is to avoid spilling tape in the machine). With the cover off, insert a tape, hit play, and see if tape takeup is steady, especially nearer the end of the tape, when the right reel is filling up.
An associated problem is if the reel sensor is intermittent- this sensor tells the logic whether or not the takeup reel is turning- again, this is to avoid massive tape spillage and damage.
Another possibility is a dirty mode switch- this switch tells the logic circuitry what position the mechanicals are in. It is probably located on the underneath side of the deck. Sometimes it can be disassembled and cleaned with a cotton swab wetted with contact cleaner. Others must be replaced.
Hopefully this helps- perhaps another tech has a better solution too.
Nov 12, 2008 | Emerson EWV403 VHS VCR
Cassette Recorder play problem
It is problem in Take-up Reel section and its not sending signal to processor. How old is this unit?
Jul 24, 2008 | Onkyo TARW255 Single Dual Cassette Deck
Sounds like the tape tension sensor is stuck. The sensor is always telling the mechanism that the tape has reached the end.
Sep 17, 2007 | Onkyo TARW255 Single Dual Cassette Deck
Stops during rec, error code E - 5 in display
E-5 is a "reel lock" error. This means that one or both of the reels that move the tape through the deck have stopped turning and are not sending a feedback signal to the system control cpu. This deck does use a drive belt, and has a clutch mechanism to transmit power to the reels. Check the belt and clutch for wear (the belt has a tensioner; the tension screw may be loose.).
Aug 05, 2007 | Panasonic AG-TL500 VHS VCR
Error "04" on display & tape won't eject
you have bad capacitors in your power supply. i would suggest you take your unit to a good shop in your area and request a power supply re-build and mode switch cleaning.
Jan 22, 2007 | JVC BR-S822DXU VHS/S-VHS playback VCR
85 people viewed this question
 Grubhead
Grubhead
