Question about Gigabyte GA-8IPE1000-G (MBGA81PE1000G) Motherboard
Hey, the computer starts with no beep or continuous beep. thanks
    Scholar:
  • 160 Answers
May be the RAM Problem
For solving the problem do the following:
1. Remove the RAM(s) from its positions / place from the mother board
2. Clean the RAM slots inside the mother board with a neat and dry brush
3. Rub the "RAM (Copper Bottom) with an eraser or with hands gently for a few seconds.
4. Place the RAM in their slots and restart the system
Let me know! that i Fixya the problem
Thanking you.
B.Krishnamacharyulu
Posted on Nov 08, 2010
  • robitza_clau Nov 08, 2010
    ok, done. but now, the motherboard don't make any sound at all. the monitor dose not starts
    thanks
After i switch on the ups there are continuous beeps with red light instead of the normal green. if i continue to use the beeping stops after sometime but the red light persists. But then again the beeping...
ups with 300 watts can only back up 1 computer, though it can handle 2 computers but not too long. your ups battery life span are good only for 2 to 3 years. for battery replacement you can visit the nearest service center and ask for battery replacement. it will not cost you much.
Feb 10, 2011 | APC BE500U ES 500 USB BACK-UPS 500VA/300W...
Long beep problem when I turned on my computer
Not the right category for computer but a beeping computer on switch on usually means the memory module is not present or not working.
A continuing beep beep beep memory missing.
One long continues beep that stops and the computer then works could be anything normally the PC is looking for something can’t fined it and moves on.
If you are concerned restore the system to a previous time i.e., prior to the beep starting to happen.
Sep 13, 2010 | Home
Long beep and continue acer motherboard N1996.
1. Beep codes indicates that there is some problem with your RAM memory sticks installed into your computer motherboard.
2. For detailed information about the beep codes, refer your motherboard user manual as there are different kind of beep notifications for different problems.
3. Try removing the RAM from your motherboard, clean of any dust, replace it back to the motherboard and try starting your system. Repeat the step for atleast 10 times, until your system starts up.
4. If still the problem, persists, try replacing your RAM and try again as this will help us to find out if the problem is with RAM or not.
I hope this is helpful to you.
Please rate the solution provided.
Thanks
Jun 29, 2010 | Computers & Internet
Continuous beep will not stop
hey continuous beep means it's on a reserved power mode, make sure you plug it well, and try to click or press on the button of your ups.
Jan 02, 2010 | Powerware Best Power Fortress UPS System
Hey, My Dell Optiplex GX270 will run for a quick second, beep, and then a light with a barrel looking icon lights for a second too. How do I fix this? Thanks so much!
I would run diagnostics. Here's how you do it if the utility partition exists on your hard drive:
Starting the Dell Diagnostics From Your Hard Drive
  1. Shut down and restart the computer.
  2. When the DELL™ logo appears, press <F12> immediately.
NOTE: If you see a message stating that no diagnostics utility partition has been found, run the Dell Diagnostics from your Drivers and Utilities CD.
If you wait too long and the Microsoft® Windows® logo appears, continue to wait until you see the Windows desktop. Then shut down your computer through the Start menu and try again.
  1. When the boot device list appears, highlight Boot to Utility Partition and press <Enter>.
  2. When the Dell Diagnostics Main Menu appears, select the test you want to run.
Aug 11, 2009 | Dell Optiplex GX270
HP Pavillion dv4000 cto won't start
Hey,
if the computer doesn't beep at all, and noting comes on the screen.
Lets do this first,
Remote the ram from the computer, start up without ram.
turn the laptop off and unplug, did you hear beeps?
Place the other memory module back in and try starting up.
if the computer starts up then all is ok you can plug in the other ram and start up again. if it doesn't start up then repeat the previous process.
if this has no effect and you don't get any beeps from the computer the motherboard most likely has a problem.
I would suggest you call hp or your dealer to check your warranty.
If you are outside of warranty the repairs will cost you.
Discuss repairs with hp and see if its worth it.
Let me know if you need anything else.
Thanks,
Ekse
Feb 16, 2009 | HP Pavilion dv4000 Notebook
Beeping Upon Bootup
dependent on how many beeps you hear is dependent on what might be the problem. A fuller explanation from pushing the power button to nothing happening would be more than helpful. Beeps in a Poweredge can mean motherboard, memory or as you said power supply problems.
May 06, 2008 | Dell POWEREDGE 2400 Server
My acer laptop
Computer never stops beeping or has solid beep. When a computer is first booting and continuously beeps or never stops beeping
Good Luck/Please dont for get to Vote.Thank you
Dec 19, 2007 | Acer Aspire 5100 Notebook
Voltage Problem
µGuru load default Settings
Turn ON your PC with our µGuru™ motherboard and then turn OFF right away as one single action; repeat this action continuously for 3 times.
Now you have set µGuru to a load default setting!
Thank You
Dec 07, 2007 | Abit AN8 32X Motherboard
Gigabyte GA-8IPE1000-G (MBGA81PE1000G) Motherboard Logo
148 people viewed this question
Top Gigabyte Computers & Internet Experts
David
David
Tony
Matthew Spark
Matthew Spark
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
