Question about LG WM2432CW Front Load Washing Machine
I have a whirpool model 5145/4 washing machine aa1400 it been problem free since i bought it but from last few days it stops at programe b where it should fast spin but drum goes farward and backward but do not move on to fast spin program . i have checked the rinse hold switch which is not in so i cant see any reason why it should not move on to fast spin . i have also tried to clean the filter.ubnscrew the cap on the filter as showed in the book but cant seem to figur out but to do next. there has been few washes when it worked ok what then it does the same thing again stopsat fast spin, please advise thank you
If it has been a problem since you first brought it? How long have you owned it?
Posted on Apr 12, 2017
  • 62 Answers
SOURCE: LG wft7014pp wont drain rinse nor spin
do you have a drip-dry function...as this cancels the spin cycle unless you select it yourself
Posted on Jan 03, 2008
SOURCE: LG Intellowasher 7.2kg WD80130F
where is the drain filter located
Posted on Mar 11, 2008
SOURCE: When to know if the motor is going out ?
well here is how i fixed my lg LE error.
i just replaced the main pcu and all better now. it was not the hall sensor nore the rotor on the motor or the bearing or even the power soap
it was the main computer. for about 170 bucks and took about 5 min to change out it was all done and wroking fine
Posted on Sep 04, 2008
onthejob5130
  • 640 Answers
SOURCE: LG Washing Machine Model # WM1832CW, Error LE shows up
im going to try and help in a way everyone will understand without getting technical..LE...ERROR..locked motor error,,your motor works like a big version of a toy race car the one that run on the tracks with the trigger ,,eletromagnet...somewhere between the rotor the outside of motor and the stator the inside of motor..its not sendind or recieving signals...now between the inside of your motor and the main power board,,theres a sensor ,,called the hall sensor..its no more than a line fuse,,replace this first..its a couple of dollars..tryed to explain in the lightest form,,for every one,,not all of you might have this problem..but milt does ,,im onthe job
Posted on Jan 06, 2009
localwonder
  • 6784 Answers
SOURCE: dE code on WM0642HW TROMM washing machine
HI, this is a Door Open Error.
Possible Causes are..-
* Door not all the way closed
* Loose electrical connections at door switch and pwb assembly(Control Board)
* Door switch assembly is out of order(Miss aligned)
* Gasket on door may be creased in
Most common issue here will be a defective door lock switch. check all causes before replacing the switch.
Posted on Jul 12, 2009
Hi, just bought a Whirpool front load model wfw75hefw. Looks like it is stuck on demo mode. Anybody knows how to turn off the demo mode. The dryer was on demo mode and I was able to turn off the demo mode,...
1. Press SETTINGS/CLOCK until "DEMO MODE" is displayed.
2. The current setting will be displayed.
3. Press the "1" keypad to adjust the setting.
4. Press START or CANCEL to exit and display the time of day.
This should put you in normal operating mode.
Apr 08, 2018 | Washing Machines
Problems with BEKO WMB 751441 7.5 kg washing machine
take it back to the place you bought it from immediately and demand your money back or contact consumer affairs.
Jan 27, 2014 | Washing Machines
My awm 5145/4 has stopped working! There is still power going to it but when you select a programme it does nothing,but it will drain,someone has suggested the brushes,where are these located on this...
Could well be the Carbon Motor brushes that are worn they last round 5 years hen need replaced..I lie under the machine to do this but you may find it simpler to remove the motor they are located at the side and are secured by two screws, parts cost around £25 per set.....
Feb 27, 2011 | Whirlpool AWM5125/1 Front Load Washer
MY Whirlpool AA1400 5145 I had remove bottom drain and there is some blocking then I don't know whow comes first the ball or the rubber. Regards, OA
Hi
I hope I understood your question properly.
When you take off the drum drain pipe, you have a plastic ball and plastic ring inside the cup shaped hose which fits on the bottom of the drum.
When putting it back on, first put the plastic ring inside the cup-shaped hose. Then put the plastic ball on top of it.
Secure the hose to the bottom of the drum with the metal clamp. Make sure it is on correctly and will not pull off.
Also make sure there are no kinks in the hose leading to your drain filter.
Start a quick cycle and monitor the machine to make sure there are no leaks.
Best Regards
Ash
Nov 15, 2009 | Whirlpool AWM5145/2 Front Load Washer
Whirpool washing machine is displaying 'Water stop' red light
Check the motor coupling.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 08, 2009 | Washing Machines
Water in the baskedt
yes it is the problem replace the water inlet valve
this is done by removing the top you will see the valve that the fill hoses connect to
make a diagram of the connections so that you get it right when you reassemble the unit
May 19, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool awm 5145/4
FILTER MAY BE BLOCKED IRE CLOSE BYE
Nov 27, 2007 | Whirlpool AWM5145/2 Front Load Washer
LG WM2432CW Front Load Washing Machine Logo
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
