Question about Ovens
I have a diplomat 700ga gas oven and when I light it and set the temp the flame increases as it should then reduces to a low flame again as it should but then goes out totally after about 5-20 mins dependant on which gas mark I've set oven at. The digital timer/clock also goes blank until 5 mins later. What's going on with my cooker?
  • john_joe682 Nov 08, 2010
    Hi thanks for your reply.
    Is it possible to replace the e.o.c on Diplomat 700ga?
    I'm assuming that e.o.c stands for electronic oven control?
    Thanks
    John
    Guru:
  • 773 Answers
Your thermocouple is bad. Your oven has a safety device called a thermocouple. It detects the flame so that when the flame is not present, it will shut off the gas so that you do not have an explosive problem.
When the thermocouple goes bad, it cannot detect the flame, there for the gas will be shut off. Often times it will work okay for a short time, and then go out.
The thermocouple is a thin copper flexable tube that has a prob on one end that sits in front of the pilot light, and the other end screws into the gas valve.
This not a hard part to replace. You just unscrew the old one, take the prob out of the pilot assembly, and then put the new one in with the probe in place, run it back to the valve, and screw it in making sure it is in tightly.
Posted on Nov 18, 2010
    President:
  • 2,468 Answers
The oven controller circuitry e.o.c. control is defective,before replacing remove power to the unit for a time,sometimes this clears the e.o.c.,if not replace it,with all the problems you described it has to be the controller
Posted on Nov 08, 2010
Why does my westinghouse gas oven ignite, go off, ignite again, off,on, off, on, before temp is reached?
dirty gas orifice in the oven near the burner clean it and try again
Jul 22, 2017 | Ovens
Diplomat adp 0511 grill has no gas or ignition
Gas ovens / stovetop that use gas and not electricity. These work by igniting gas and use actual flame on the the stovetop.
Newest cook top styles, such as the induction or halogen cook tops combine the same style to produce more even heating. Some of these ovens feature thermal limiters or thermostats that regulate the burner system.
I offer free advice bcuz God is so good!
GAS OVENS
The spark igniter tip is dirty (can clean it with either a little wire brush or a piece of fine sandpaper).
2) The Pilot flame is too low, and the tip of the igniter is not in the flame good enough. (the flame acts as a circuit when it touches the tip & completes the circuit).
3) The spark module is no good and needs to be replaced.(But 1 & 2 are your best bet).
spark module does not sense the flame when it's on. The spark igniter is also the flame sensor which provides feedback to the spark module.
Make sure the igniter is properly aligned with the burner lighting holes and it is clean. All lighting holes must be clean too. You can enlarge them using a drill bit one size bigger.
If it would not fix the problem, replace the bake burner and the igniter.
There is a small chance for the spark module itself to be bad as well.
The oven safety valve
(also called the gas valve) is the part that ensures that gas is not released until the igniter has reached the correct temperature needed to ignite the gas. While this part can fail, it is uncommon. If the hot surface igniter does not glow you should first verify that you have voltage to the circuit. This is a live voltage check and should be performed by a qualified person. If voltage is lost at the valve terminals then you should verify the continuity of the bi-metal in the valve using a multi-meter.
Jan 18, 2013 | Belling XOU592 / XOU593 Electric Double...
I have a bakers pride pizza oven and the bottom oven Including the pilot light) continue to go out for no apperant reason. I have changed the thermocouple 3 times and the pilot light once. Sometimes it...
Several things to check. First be sure the pilot light flame is directly striking the thermocouple. It is a pencil sized rod that is next to the pilot light. Sometimes people reduce the size of the pilot flame to save gas. You may need to increase the pilot flame. Follow the small gas line from the pilot flame back to the gas valve. There is a screw where the small pilot gas line goes into the valve. Remove the screw and then deep in the hole is a tiny screw that can only be reached by a tiny flat blade screw driver. Turn the screw counter clockwise to increase the pilot flame. The thermocouple needs to be red hot to work properly. The second item to check is to see if there are any breezes that occasionally blow through the kitchen. Sometimes the hood fan will draw air under the ovens and actually blow the pilot flame out. Same fix, increase the flame. You may also experience low gas pressure to the appliance during heavy usage. You would need a manometer gauge to check for proper gas pressure. In short, if the oven goes out during your busiest time when everything gas powered is on, the oven may be starved for gas.
Sep 09, 2010 | Bakers Pride FC-616 Gas Single Oven
It won't heat up... even though there is a flame
Check The Power Source
If the gas oven won't turn on, the first thing to do is check the power source. Most modern gas ovens are electrically powered. Check to make sure the oven is plugged in and the breaker isn't tripped.
Check the Heat Source
When a gas oven won't heat, the pilot light can also be set too low; if the pilot is lit but the oven isn't catching, adjust the flame.
Newer gas ovens use electric ignitors that produce sparks. If the oven doesn't heat, the ignitor could be broken.
Feb 05, 2010 | Ovens
Diplomat Softline ADP0300 Gas-just not cooking ...anything!
Hi there..
I Just recently had the same problem, also with a diplomat gas oven..
The problem I found was down to a small resetable component under the main cover. ..
It took me ages to find the problem and I had taken the whole electical parts of the oven to bits before 'accidentaly' coming across this 'thermal switch' (located inside the main cover, at the top, behind the display module).. - to reset this there is a tiny red button between the connectors.. press this - and it should all be fine again... : One importnat note is that this may be tripping as a consequence of the fan not running or by my thinking not running on after the oven is switched off, leaving the casing to heat up and then trip this switch component.. - if this component is faulty it can be found in RS components or Farnell components.. look for Thermal swich manual reset part no: L100C 9082 470.
Nov 29, 2009 | Ovens
Oven lights on low flame but will not come up on high flame .cannon chester cooker.suspect by pass is not working. Do I need control knob/thermostat with the phial. Thanking you.
all gas range ovens have a small metal box in the back upper area of the broiler burner; a gas line runs into this box as do two wires; this is a "flame control " gas valve; the way it works is: after the pilot has been lit as you turn the oven temp control a heating element in the box causes a small valve to open allowing a larger amount of gas into the oven burner to ignite the whole burner If you can only get pilot flame on high replace this valve
Apr 26, 2009 | Ovens
Gas oven igniting but not heating up
Is orifice that gas flows thru into burner clogged/restricted? IF not, then Ignitor may be bad; I would replace it. If still same issue then gas valve is bad. Thanks, please leave feedback or contact me again for more info if you need it. Flame height does not change regardless of your setting- it's either on or off; thermostat is not like an accelerator. Thanks, please leave feedback or contact me again for more info if you need it.
Nov 29, 2008 | Ovens
Diplomat Oven ADP3650 Instructions
User manuals are hard to find.
The problem I had was setting the clock on a single Diplomat oven, with no clock button. Here's my solution :
DIPLOMAT OVEN OPERATING INSTRUCTIONS
The Diplomat single oven is controlled by two knobs and a set of buttons along the middle of the control panel.
The left knob sets the temperature of the oven, while the right knob selects the function to be performed, e.g. fan oven, grill, etc.
The buttons along the middle set the cooker clock, the start and end times of cooking, and the “+” and “-“ buttons will increase or decrease the time shown on the cooker’s clock.
PLEASE NOTE THAT THE OVEN WILL NOT OPERATE UNTIL THE CLOCK IS SET.
If there is any interruption to the power supply (including manually switching off at the main switch) the oven will not operate until the clock is reset.
Here’s how to set the clock:
First press simultaneously the first two buttons to the left of the control panel. They are marked as a Bell symbol (Alarm) , and a steaming Cooking Pot (Start of Cooking Time). Then immediately press the plus “+” or minus “-“ buttons to increase or decrease the time displayed. When the desired time has been reached, leave it for a few seconds, and it will remain set at this time. Any further changes to the displayed time will require this procedure to be repeated.
Hope this helps!
Oct 10, 2007 | Ovens
Ovens Logo
180 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
