Question about Mitsubishi Car Audio & Video
HOW TO DECODE RADIO IN SUZUKI LIANA - Mitsubishi Car Audio & Video
SOURCE: suzuki liana engine check light code required
BANK 2 SENSOR
Posted on Nov 15, 2009
dancandoit
  • 436 Answers
SOURCE: the radio in my suzuki liana has stopped working.
there should be a fuse at the back of the radio, check this.
Posted on Mar 03, 2010
Testimonial: "Thanks..didn't even know the panel unclipped Thanks again"
muntejaya
  • 10421 Answers
SOURCE: due to battery being disconnected
Hi, Please get the code here:
http://carsoundsystem.org/car-music-system-unlock-code/
www.solware.co.uk/download-products/unlock-car-radio.shtml
Regards, Jay__PDxzWs
Posted on Feb 24, 2011
kenw392
  • 2226 Answers
SOURCE: car radio i put n
Try leaving the radio turned on for an hour or two. You should then be able to enter the correct code.
Posted on Sep 15, 2011
hepcars
  • 1249 Answers
SOURCE: need to change the battery in a suzuki liana
First be sure you are purchasing the proper replacement battery for your specific needs...batteries are not the same...kind of like cereal makers, batteries are only made by about 6 companies...(many brand names) Your local parts store should be able to offer the proper battery model to start your comparison...Use the rated "Cold Cranking Amps"...CCA for comparison. Your factory battery was probably rated at 650 CCA...you can compare amps from 650CCA to 1000CCA. Depending on your array of electrical accesories, the higher rated CCA's have more starting, and maintaining power...the warranties will range from 3-8 years as of course the higher rated CCA battery will cost slightly more. If you have not purchased the battery yet...compare the Duralast Gold battery from Auto Zone...power, warranty, and price are hard to beat...includes a 3 year free replacement, and 8 year pro-rated warranty...Also, most auto parts stores will install your battery for free:) You can watch and see the simple process of disconnecting both positive (red) and negative (black) terminal cables...then locate the battery hold down bolt...(usually 10MM deep well socket) remove and carefully lift out the old battery...some old and most new batteries have a ******** top that helps in the lifting out...and installing the new battery. Tighten down the hold-down bolt, re-connect the terminal posts...and you should be complete...the engine may run rough for a few minutes while the fuel and air mixtures are automatically re-setting to factory specs...Your parts store can confirm that your problem is the battery and not your alternator, before you invest in a battery or alternator...again for free while still installed in your car...Hope this helps.
Posted on Aug 17, 2012
I am looking for a manual suzuki liana m18a gearbox for my car
no year, stated.
welcome to USA forum
the forum and country with no M18a,
this Liana name is only used, in
called the Liana - Life In A New Age - in China, Pakistan, Europe, Israel, South Asia, Taiwan and Australia)
you never said which country, so cant help you could anyone.
really
go to your suzuki dealer in your country and ask this.
USA runs a J20b engine, on the Aerio (our name for same car class)
Dec 07, 2016 | Suzuki Liana Cars & Trucks
Where is crank sensor liana 1.6
welcome to the USA forum , is your car USA.
no.
my guess is it has the M16a engine
see bottom left CKP #5
The M class engines , its on the PULLEY side
and facing said pulleys, (regardless of car it is)
its to the right of the pulley
that means the crank tone (teeth) wheel is behind said pulley on end of crank shaft.
we do have swifts here with m15 or M16
Aug 24, 2015 | 2005 Suzuki Liana 1.6
About suzuki liana
I haven't seen or heard of common problems with Suzuki. Their parts wear out like the others. Only thing I don't like is having to buy about every part for a Suzuki from the dealer. Not much after market parts out there for Suzuki.
Mar 09, 2015 | 2005 Suzuki Liana 1.6
On my suzuki liana 1.6 2004 the airbag light keeps on
that means there is a fault in this system.
we scan it and read the Bxxxx codes.
in the suzuki shop (LOL finding one) the use a special factory SRS air bag tool.
my fancy scan tool can not do Suzuki/s
so take it in and get it scanned, by any shop with a SRS scanner that works in suzuki,
Feb 26, 2014 | 2005 Suzuki Liana 1.6
Need the unlocking code on my car . its a suzuki liana
the security lock show up in the dash board and the car wont start what can i do it's for suzzuki liana 2003
Feb 12, 2013 | Cars & Trucks
Car Audio & Video Logo
172 people viewed this question
Top Mitsubishi Car Audio & Video Experts
xxxxxx xxx
Jeff Turcotte
Jeff Turcotte
Mister Danger
Are you a Mitsubishi Car Audio and Video Expert? Answer questions, earn points and help others
