Question about Garden
The 'primer' doesn't work on my mower's Briggs & Stratton engine. Is there an easy fix?
    Genius:
  • 1,015 Answers
You can try pumping primer bulb 10-15 times instead of 3 or 4 that manual probably suggests. We have a craftsman 22 inch cut push mower with a 3.5 H.P. BRIGGS &STRATTON engine and if you don't prime it at least a dozen times it will not start. It is possible that you have a small hole in your primer bulb in which case it can't create suction to bring gas to carburator. If this is the problem you can purchase a new bulb and seal at most larger SEARS stores or service centers.I would guess that if you have manual for mower you can get part number and phone number to get new parts .Hope this helps. Thanks
Posted on Nov 08, 2010
Where is oil filter on 13.5 briggs
Briggs & Stratton Riding Lawn Mower Engine Oil Filter #696854 ...
? 2:05
https://www.youtube.com/watch?v=QjYmbfGU0qg
Aug 22, 2014 - Uploaded by RepairClinic.com
This video provides step-by-step repair instructions for replacing the oil filter on a Briggs and Stratton small ...
Oil Change- Briggs & Stratton 12.5hp Mower - YouTube
? 5:05
https://www.youtube.com/watch?v=udjoD-mW5ig Aug 15, 2012 - Uploaded by Alex's Bikes and Motors
Oil Change- Briggs & Stratton 12.5hp Mower. Alex's Bikes and ... This is going to sound weird, but I can't ...
Oil Filter 492932S - Briggs & Stratton Parts
https://shop.briggsandstratton.com/us/en/parts-and.../oil-and-oil.../oil-filter-492932s Briggs & Stratton oil filters are engineered to keep your Intek, Vanguard OHV and twin cylinder engine running smooth. Save on costly repairs -- order genuine parts today!
oil filter on 13 5 briggs Google Search
Mar 12, 2018 | Briggs Garden
Fuel leaks out of the primer bulb has a nipple with small hole. fuel coming out of the nipple hole. No breaks or tears in the bulb.
ethanol additive in gasoline causes deterioration of fuel system parts, especially primer bulbs. Needs to be replaced...relatively easy for mechanically minded or bring to dealer. Check Amazon for parts...they are cheaper than most dealerships.
Hope this helps....
May 01, 2016 | Briggs & Stratton Briggs Stratton...
I have a Briggs and Stratton/Bolens 20" lawn mower which needs a primer button. Where can I get that part(s)? Thanks
It looks like the number you are giving are from the mower deck, and would work great for anything but the engine. On a flat head engine above the spark plug on the tin air shroud there will be some more number and they go to the Briggs and stratton engine you have.On a overhead valve engine you should look on the valve cover. There will be model, serial , and spec numbers, all three would be great and would make it easy to look up the primer bulb and post a link to it for you.
Mar 25, 2016 | Garden
4 lawn mowers same problem wont start until I prime the by hand. Briggs Stratton 917.387500/ 12AV566n01124987/20043/SDSP2245D Will the same primer bulb fit the above mowers.
If its identical it should work ,if not take the old one to a mower shop,to get correct one and make sure the choke is going right on when the cable is in choke position.
Aug 05, 2014 | Ryobi Snap In Primer Bulb Pump 683974 ...
Craftsman Briggs & Stratton lawn machine engine 6.75HP don't start no spark
Take of the hood and shine up the magneto and if that don't work the take thecarbrator of and where the primer ball is unscrew the Philips head screws and that will release the primer from the gas tank and there will be a little screan blow that out then put it all back together push the primer button 3 times the pull the cord to start the mower and it will run if that don't work then let me know if you want to get ride of it please because my hobbie is working on mowers thnks please respond back thanks hope this helps you problem
Apr 19, 2013 | Garden
What is the magneto gap for a 6HP Briggs & Stratton 12H802 series engine?
Briggs lists it as .006 - .010 on this 6 HP L-head engine. The .010 width can easily be attained by using a standard sized business card as a feeler gauge (and it doesn't stick to the magnets in the flywheel). I double up the card, loosen the coil and let the magnets in the flywheel draw the pickup legs in until they press on the card, tighten up the retaining screws (threadlocker is optional) and your air gap is set.
http://www.smallenginesuppliers.com/html/engine-specs/briggs/common_specs_single_cyl_lhead_engines.pdf
Jun 10, 2011 | Briggs & Stratton Briggs Stratton...
Lawn mower won't start
to check for firing remove the spark plug insert it in the plug boot and pull the rope while watching to see if the plug sparks be carefull not to touch the plug electrode while pulling the rope or it will shock you. If you don't have a spark, try a different plug. If still no spark the coil could be bad.
Jun 25, 2010 | Briggs & Stratton Briggs Stratton Intek V...
How do you remove the primer bulb on a model 10a902 Briggs and Stratton mower engine?
Look at the outside of the plastic housing where the primer bulb is inserted, you will see an open area where there are 2 tabs, one on each side, using a small screwdriver, push these tabs inward to release them and slide the whole thing out of the hole including the primer bulb. The new primer bulb normally comes with a new mounting ring if you purchase it from a lawnmower dealer
Sep 27, 2009 | Briggs & Stratton Garden
Garden Logo
776 people viewed this question
Top Garden Experts
roeb
john h
Marvin
Marvin
