Question about Bosch HBN540UC Electric Oven
Bosch oven HBN 56M shelf clip that holds shelf side rail to oven side broken how do i fix it?
SOURCE: Bosch HBN 455 Oven Cooling-Fan Issue
After the oven is switched off, the after-run of the cooling fan is controlled by an electromechanical thermostat switch. The fan can switch back on, due to residual oven heat that accumulates within the oven's outer case and reactivates the cooling fan temperature switch. Considering yours is making buzzing sounds and activates on and off, the fan's thermal switch may have dirty contacts or just be defective and require replacement.
Posted on Oct 02, 2007
Master_Tech
  • 770 Answers
SOURCE: Easy Off Heavy Duty Oven Cleaner on Self Cleaning Oven
NO..wont hurt it as loong as you got it all out.. but plz remind her that this is a self cleaning oven....Which does not mean you have to clean it yourself !!! it should be fine.. tell her next time to run it thru a self clean cycle for at least 3.5 hours on the timer setting..
Posted on Jan 27, 2008
grandadfixer
  • 99 Answers
SOURCE: bosch hbn s gb
oven element would need model and ENR No. to supply
Posted on Oct 12, 2008
  • 134 Answers
SOURCE: How do you programme Auto Start.
Here you go
http://safemanuals.com/user-guide-instructions-owner-manual/BOSCH/HBN5056AUC-_E
If this helps please leave feedback
Posted on Feb 12, 2009
  • 27 Answers
SOURCE: INSTRUCTION MANUAL
you can obtain the instruction manual for this directly from the bosch web site free of charge if it is not listed there try the BSH Home appliances ltd site they are the manufacturers repair service in the UK
Posted on Mar 09, 2009
Tip
Common heating faults with Bosch HBN 560570B / 560550B single oven
For all Free appliance repair videos visit our VIDEO TUTORIALS 1, If the Bosch fan motor in the back of the oven is going round and the temperature light is on (normally little red light), but there is no heat then you will probably need a new oven element, these are generally very easy to fit and readily available from our website these can be tested with a electric meter.
To gain access to the BOSCH element you will have to remove the back plate from inside the oven. Once removed you will see the fan and element, if you look closely at the element you will probably see a small hole burnt in it where it has blown. Sometimes however there is no evidence of a fault but the element is open circuit ie: broken inside the element casing, either way it will need replacing. Some elements will are fixed from inside the oven and some are held in place by nuts from the rear of the machine.
2, If your BOSCH fan oven is getting warm but takes a very long time to cook or is burning the food more on one side than the other, then you need to check if your oven fan motor is working you will see the blade turning fast if it is ok. if the element is heating but the fan motor is not blowing the heat into the oven then you need To replace the oven fan motor is a little more expensive and a bit more involved.
3. If you have the opposite problem ie: your oven is over heating and burning everything then you will need to replace your BOSCH oven thermostat
4, A quite common and easily overlooked answer is if your BOSCH oven is not working at all ie: no heat and no fan then the chances are that someone has put the oven timer into AUTO mode, simply put oven back to MANUAL mode and all should be working again.
on Jan 19, 2010 | Bosch HBN 560570B / 560550B Electric...
Tip
Common heating faults with Bosch HBN 430560B / 430520B single oven
on Jan 19, 2010 | Bosch HBN 430560B / 430520B Single Oven
Why wont fan turn off after use in oven bosch model hbn 13n5,1b
It should turn off after a while. The fan is actually the cooling of the case, it runs longer if I have used a higher temp setting. If it does not stop after app. 20 min something is broken.
Sep 03, 2014 | Bosch Ovens
Bosch oven glass
http://www.bosch-home.co.uk/store/spareparts/search
Feb 20, 2013 | Bosch HBN 9061 / HBN 9021 Double Oven
Tip
Common heating faults with Bosch HBN 131560B / 131520 single oven
on Jan 19, 2010 | Bosch HBN 131560B / 131520 hot-air...
Tip
Common heating faults with Bosch HBN 442 / HBN446 single oven
on Jan 19, 2010 | Bosch HBN 442 / HBN446 Electric Single...
Instructio manual for a Bosch oven HBN 574850
http://www.bosch-home.co.uk/customer-service/download-product-manuals.html click on link, open new window as indicated and type in the ENr number without spaces, you can then download the manual (IU is user manual, II is installation instructions)All the best
Aug 29, 2011 | Bosch HBN 742 / HBN746 Electric Single...
Smeg fautly themostat - too hot, burns everything
Sounds like thermostat faulty, make sure sensor is not detached or broken in oven, if still under 1 year old, then I suggest you contact service agent.
Pleas rate my solution.
Thanks.
Oct 10, 2009 | Bosch HBN 452 / HBN 456 Electric Double...
Bosch hbn s gb
Sep 16, 2008 | Bosch HBN 9163 GB / 9163 GB hot-air Double...
Bosch HBN540UC Electric Oven Logo
61 people viewed this question
Top Bosch Ovens Experts
Oloyede Monsuru
michael_t919
Are you a Bosch Oven Expert? Answer questions, earn points and help others
