Question about Haier Washing Machines
Inside rubber gasget attached to the drum has a piece chipped off it where can iget another because its leaking every where,and how does it come off
  • eric_bh Nov 08, 2010
    when i get a new rubber gasget , how do i get the old one off
    haier washing machine, ineed to renew the drum gasget, how do i get it off
  • 4,059 Answers
With your model number you can find parts on-line at several sites This sears site is one of them.http://www.searspartsdirect.com/partsdirect/index.action
They have diagrams and the new parts come with instructions. If you want you can post back here with the model number and I'll try.
Posted on Nov 08, 2010
  • Haier Master
  • 19,396 Answers
Hi.
In US and Canada use Support - Haier America or ask to A.P.Wagner: Haier Appliance Parts
InUK use Hayer Spares.
You can get hayer parts delivered worldwide contacting Repairclinic.
Regards.
Ginko.
  • Ginko
    Ginko Nov 08, 2010
    Re:"haier washing machine, ineed to renew the drum gasget, how do i get it off"
    Thanks for the negative feedback! You need to take off the cabinet and remove the drum to change the drum seal the door seal is a different thing.
    On your request the problem has been passed to other expert. Ask them to provide pictures from schematics and all the rest. My help has already been refused.
    Good luck.
    Ginko.
After replacing valve coils it now makes thumping noise reassembled it twice
Thumping noise is usually something with the drum system. You didn't list make and model so I'll give a few suggestions. If its Whirlpool--- the drum rides on 2 rubber rollers at the back edge that wear and need replaces if the rubber gets too bad. The front edge of the drum has a 2 piece plastic bearing strip that snaps into square holes in the front drum edge. Those 2 strips sometimes break or chip and need replaced.
If its a Frigidaire dryer----the back drum bearing is a small round metal ball that looks like a small trailer hitch ball. If fits inside a slotted plastic retainer block. The plastic block wears and the ball sometimes gets grooved and needs replaced. It comes as a complete kit (ball and socket) for about $20. The front of the drum has a similar system plastic strip as the Whirlpool I described above. Hope this helps.
Jun 10, 2015 | Dryers
BBQ valve leak
check and see if there is a rubber gasket inside of the piece you screw on to the tank sounds and looks like you are not getting a good seal. if you do not see a rubber gasket inside of that black nob go to lowes or home depot tell them your situation and i bet they have a new attachment piece or a gasket hope this helps
Jul 05, 2013 | Grilling
Leak beneath dash on passenger side. 2010 Chrysler Town and Country
i had this same thing happen to me. this may or may not be your problem. outside at the very bottom of your windshield there should be a grate, that will come off. under that is a ruubber type gasget that sometimes is not in the right position and the water drips inside your car. i had a wind-shield replaced and the tech did not put the rubber gasget back in it's proper place. it was like a 10 min fix and it never leaked again, amazing
Feb 26, 2013 | 2010 Chrysler Town and Country
A piece of material came out of my harmonic balancer and I dont have any brakes, steering, and its not charging what is the problem.
Sorry to tell you this but you need to get a new harmonic ballancer wheel.
The rubber that came out is part of the whole constructed unit.
The rubber lining inside the housing helps balance out any vibration in the belt assembly.
The rubber has to be inside the grooved drum that the belts attach to powered by the crankshaft,so no rubber inside is like driving your car without tires on the rims.
Slip around nice eh? so does the gap between the belt housing and the pulley that's attached to the crankshaft.
Nov 25, 2010 | 2001 Dodge Ram 2500 Truck
There is water leaking down the electric wire at the bottom of the unit. What could cause this? the unit works just fine.
Once disposal rusts out, it needs replacement.
Usually if sink basket seal is broken or if dishwasher attachment is leaking, you can feel water near top of disposal.
Use paper towel at top to see if that area is wet.
If top area is dry, then water is coming from inside disposal, and disposal is rusted out.
If sink seal is still good, we used to buy same brand disposal and re-attach to same sink basket. That's the quick fix.
If this is inside your home, you probably want to install new sink basket that comes with disposal.
To install new disposal, also buy container of plumber's putty to seal sink basket.
Remove disposal.
Clean off old putty on sink. It will chip off easily.
Apply finger-thick amount of plumbers putty to sink opening.
Set disposal sink basket into putty and push down.
Tighten screws on bottom of sink basket.
Wipe away excess plumber's putty from sink so it looks nice and smooth.
Before lifting disposal into place, attach electric wires and attach dishwasher hose to disposal.
Use hammer and screwdriver to remove steel blocker located inside dishwasher stem ... the blocker is left in place if no dishwasher hose is attached.
Disposals can be different: But here's the usual sequence:
Lift disposal with one hand and hold level. Push up strong while rotating attachment ring until ring grabs bottom of sink basket.
If you cannot lift disposal with one hand while rotating attachment ring with other hand, use small bottle jack from auto-parts store. And put piece of wood between bottle jack and aluminum disposal so disposal doesn't break.
Here's how to handle tubular pipes below sink:
Any tubular pipe joint that moved while removing or installing disposal, has to be taken apart, cleaned and re-attached.
If washers are plastic, then clean and re-use.
If washers are rubber, then replace each washer with new rubber washer.
When reattaching tubular pipes, apply generous amount of rectorseal over each plastic or rubber washer for first-time seal of tubular pipes.
Nov 19, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Water goes on to floor when filling washing machine. All hoses are connected securely.Machine was previously overloaded and shifted considerably when when nobody was home.
sounds like one of the hoses connecting drum or pump is adrift.most times these can be most readily seen with the machine lying on its back.make sure all power & water connections are off!
Aug 16, 2009 | Washing Machines
Tour rubber gasget leaking
firstly,if it isnt a bad tear you could always try putting a patch on it ie a puncture oufit for a tyre this works as i have done this for a lot of young single mums who cant afford a new boot.but to replace a new one then you have to take the metal strip off around the boot wich you call gasket,once done this it lifts off with a lip all around it then just pulls out make sure when replacing that all the lip sits all around the drum.
Jul 14, 2009 | GE WBVH6240F Front Load Washer
Whirlpool Ultimate Care II drum does not spin.
Depending on your washing machine model, the drum and motor are connected by 2 plastice yellow circular pieces, with a black rubber washer in the middle with holes where the pegs or rods go into. The 2 plastic circular pieces have 3 pegs or rods if you will, that connect to the black rubber washer via 3 holes. Sometimes, one or both of the 2 plastic circular piece pegs get broken off or the rubber washer cracks and breaks apart, so that the motor will not turn the drum. If thats the case, you can purchase the 2 circular pieces and black washer piece as a set.
Jan 05, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Washer not draining all the way
http://www.instructables.com/id/GE-Adora-Lint-Filter-Cleanout/?download=pdf
Had the same problem, this fixed it!
Oct 30, 2008 | GE WSXH208A Front Load Washer
Washing Machines Logo
60 people viewed this question
Top Haier Washing Machines Experts
Gerry Harvey
Gerry Harvey
Owen Barnes
shaun taylor
Are you a Haier Washing Machine Expert? Answer questions, earn points and help others
