Question about Sony Playstation 3 (PS3) Console
Ps3 will only switch on for a second yellow light flashes once
    President:
  • 1,139 Answers
Hi there, this is usually a sign of the Yellow Light Of Death (YLOD). When the PS3 was originally made Sony used lead free solder in their consoles. Lead free solder is not as flexible as normal leaded solder and over time due to expansion and contraction because of heat given off by the console's components lots of PS3's failed. You have got a few options, you can either have the console professionally repaired which is going to cost around £50. If the console is out of warranty Sony will only replace it for a cost of around £130. As a last resort if you are good with electrical items you might want to have a go at repairing it yourself. If you google YLOD you will find plenty of guides that will instruct you on how you can repair it yourself.
Please bear in mind that once a console has the YLOD there is NO guarantee as to how long a repair will last, it could be a couple of hours to a couple of years.
I hope this information helps you and I hope you get your PS3 up and running soon.
Posted on Nov 27, 2010
My PS3 (40Gb) has just shut down on me. I was playing COD Modern Warfare 2 when the PS3 just shut down and then beeped at me 3 times the red light started flashing and when I pressed the power area the...
Its called yellow light of death. Here is a link to my step-by-step instructions on how to fix.
http://www.fixya.com/support/t8396931-ps3_turns_ok_but_turns_itself_off_after
Feb 24, 2011 | Sony Playstation 3 (PS3) Console
After pressing the on button it turns green for 5 seconds then it flashes yellow/orange for a second then it flashes red.
Yellow Light of DeathThe "Yellow Light of Death" or YLOD is the common phrase people use to describe the following sequence when they try to turn on their PS3:
  • Press Power Button
  • Red Light Flashes Three Times
  • Yellow Light Flashes
  • Green Light Flashes
  • Beeps Three Times
  • Red Light Flashes
The sequence above may vary a bit but you do see the flashing yellow light (sometimes shows up as orange) that normally you would not see when operating your PS3. The YLOD is a general hardware fault that can mean a lot of things. However, one of the problems is cracked solder that leads the PS3 to think one of its internal chips is not connected or is broken somehow. Cracked solder can happen when the chips get too hot (RSX most likely) and leads the motherboard to start bending, which may crack the solder. Changing the power supply (lower the average wattage going to the chips to lower the heat) and better thermal compound (heat dissipates faster to the heatsink) may prevent this error from occurring. However, if your PS3 has already had the YLOD, then you can reflow your motherboard every few months to keep it working (but it is not a permanent fix as the YLOD usually comes back).
Oct 09, 2010 | Sony Playstation 3 (PS3) Console
When i turn on my ps3 it starts up fin and the frezzes then a yellow light flashes and then turns of
have you tried this?
Turn the console off at the back switch for a few minutes. Then switch it on from the back, then hold the Power button until you hear a second beep. If your PS3 is completely stuffed it probably won't do this, but there's a chance it might let you into the recovery menu which will let you do a format or System Restore and hopefully get your machine running again.
Is there any green or red flashing lights?
Hope you don't have the yellow light of death.
Apr 08, 2010 | Sony PS3 40GB Best Sellers Bundle Console
Wen i power switch my PS3 red light comes on then wen i pressed down once to get in on beeps once, then green light comes on for a second then yellow light to a steady BLINKING RED LIGHT!!! And does NOT...
This is called the yellow light of death. Cause is sever heat damage to the internal components. Either send it in for repair or replace. Sorry about this but the truth is brutal.
Nov 24, 2009 | Sony Playstation 3 (PS3) Console
My ps3 switched off by its self recently and when i tried to switch it back on the power light was flashing red i pressed it once and it turned solid red then pressed it again it went green for around a...
Yes this is the YLOD (Yellow light of death) to fix it you need to stop the heat build up getting to the main chips in the motherboard to do this you should use the recommended PS3 Repair guide.
It is created by the same person as the top selling Xbox guide>>
PS3 Repair Guide
PS3 shuts down after one second
hi , i hate to say this but you need to do this asap. Call the playstation support line and send it in. your ps3 is experience a corrupted hard drive. This will only get worse and will eventually shut down for good.
Jun 21, 2009 | Sony Playstation 3 (PS3) Console
Wont turn on
your ps3 is done. this is known as the yellow light of death.
Jun 16, 2009 | Sony Playstation 3 (PS3) Console
On and off lights
You have the yellow light of death. You will need to have the mother board serviced.
Feb 17, 2009 | Sony Playstation 3 (PS3) Console
How to fix blinking red light on my ps3?
You should open up the PS3 and use compressed air to dust it off. Take a look at the thermal paste to make sure it isn't dried up! PS3 Flashing Red Light The Ultimate Solution
Jan 20, 2009 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
50 people viewed this question
Top Sony Video Game Consoles & Games Experts
shaun taylor
marley mcelhinney
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
