Question about Diesel Garden
How to bypass saftey starting switches on case ih dx29 farm tractor engine just shut off while moving. can start but when put in gear egine dies.
2 Suggested Answers
  • 376 Answers
SOURCE: Tractor Will Not Move And Dies When Brake Is Released
I would check the wires and clean the connectors and make sure seat switch is working. If that is not working, it's like getting off the seat without holding the brake/clutch pedal down or getting off seat with blades engaged. Both will cause engine to die.
Posted on May 26, 2009
Engine will turn over but won't start checked carburator and fuel filter and they are ok are there any saftey switches that would prevent engine from starting?
Since engine is turning over by using the ignition switch it should not be a safety switch problem,
Sounds to me you might have a spark / coil problem
If you have spark then fuel shutoff selonoid on bottom of carb bowl might be bad and not opening.
which in that case I unplug from harness and unscrew from carb bowl , pull out center pin if connected cut off if not throw it in the trash when I do this I always put a shut off valve in the gas line.
You will need a very thin open end wrench to unscrew selonoid from bittom of carb.
Apr 04, 2015 | Ariens 42" 19HP Lawn Tractor
Whatare the oil spec for ih 686 transmission
IH 686 as in Tractor?
If so... Hope this helps you.
http://www.tractordata.com/farm-tractors/000/3/5/352-international-harvester-686-engine.html
Feb 18, 2015 | Cars & Trucks
Case IH DX29 Hydraulic prob. bucket wont lift
Check control cable from lever to valve to see if it has broken or seized
May 08, 2012 | Farmall Toys
Engine stops
Hello
Have a look at the saftey switches.theres one under the seat.and one under the blade engage lever.
There may also be one under the hood near the fuel tank.
May 04, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
My tractor only stays running if i hold the key on if i put it in gear it shuts off i replaced the neutral saftey switch but it did not help
sounds like a faulty blade saftey switch or the operator presence switch has failed, possible saftey interlock relay. hope this helps
Nov 23, 2009 | Garden
I have a Case IH 5230 Maxxum tractor with shuttle hesitation.
I have a 1974 case backhoe 580 it will not move in any gear.
Jul 10, 2009 | Milwaukee Tool Case Heat Gun
Mower won't run
Did you try jumping the switch under the seat? Why would the foot switch shut it down? If it is the switch near the foot and you can't replace, then jump it. But be careful this will disable saftey features. Hope this helps.
May 25, 2009 | Craftsman 20 Hp 42" Deck Lawn Tractor
Garden Logo
113 people viewed this question
Top Diesel Garden Experts
Dennis Key
Dennis Key
john h
Are you a Diesel Garden Expert? Answer questions, earn points and help others
