Question about Grundig YB-550PE AM/FM Radio
YB 550 PE
Just got two of these and no manual and they turn off automatically after what appears to be two hours or so. How can I stop this? I don't need this feature ever.
Thanks
Ron
  • Rohn MacLeod
    Rohn MacLeod Jul 04, 2008
    It would seem Grundig would let you choose not default to a timed turnoff. Many thanks for the solve!
    Ron
  • nasarob Apr 29, 2009
    Radio shust off after 10 sec, if I hold the button down, nothing happens. I must press the button 3 times, then it plays for about 10 sec. The radio is about 2 years old.
    Problem Solver:
  • 6 Answers
When radio is first turned on, it goes into "sleep" mode that you can set between 1 min to 2 hrs. (You'll see the number on the screen). If you hold the "on" button longer, you'll see (yb-550) on the screen and the radio will remain on until you turn it off.
Posted on Jul 04, 2008
Need manual for Grundig YB-400-pe radio
You can use this copy of the user manual for this unit from this link just click HERE.
May 16, 2011 | Audio Players & Recorders
Cycle stops and the code FE appears and to refer to manual but I don't have one, can you help
IE: Water level (246) was not reached in 8 minutes
UE: Imbalance: Load too, small too large
OE: Drain problem took longer than 10 minutes to drain
FE: Overflow issue drain pump running to comp
PE: pressure sensor (sensor out)
dE: door error. open door. switch is out
LE (with a a slash in the
middle of L. Upside down F) Thermistor out
CE: Over amping Too much soap wrong soap
LE: hall sensor shorted/destroyed from sudslock
bE: Ball sensor loose connection/out of order
EE: eeprom out test mode only
PF: power failure momentary interuption of shocktricity
Must be some sediment in the water level pressure hose. Blow out the sediment, reconnect the hos, pump out the water and retry. This is an lg washer. You may only need to set or reset the water level frequency. I have service manuals and notes HERE
Apr 06, 2011 | Washing Machines
Moving home resulted in our loosing the AC adapter for our Grundig YB 400 PE, any sugestions where we could aquire a replacement?
its a 9V power supply
you should try Radio shack take with you the the radio to make sure the power supply have the correct connector
Aug 23, 2010 | Grundig YB 400PE AM/FM/SW Radio
No am radio
You realize that the MW is the AM stations....I don't know
why they didn't just put AM on the band select...
Also I could not get MW (AM) on my set once and the
reason was that it was too close to my laptop...
It was interfering with the radio.....
May 07, 2008 | Grundig YB 300PE AM/FM/SW Radio
Honeywell oil radiator
Press the *power button* once to start the heater on high power, continuous run. If left at this setting, the unit will run continuously on high power (1500 watts, 12.5 amps) and will not shut off until the unit is manually turned off.
Press the *power button* again, to change to low power, continuous run, (900 watts, 7.5 amps) and will not shut off until the unit is manually turned off.
Set temperature:
Press the temp/timer button until the temperature icon blinks. Use the up and down arrows to set the desired temperature.
The temperature icon will stop blinking and the current room temperature will reappear after the desired temperature is set.
The heater will turn off and on to achieve the desired temperature.
Set timer: (auto off)
Press the timer/timer button until the timer icon blinks. The hour display will appear. The auto off icon will also appear.
Use the up and down arrow buttons to set the heater operation time between 1 and 10 hours. This function will activate once the timer icon stops blinking. The heater will automatically turn off whn the times runs out.
Set timer: (auto on)
Press the temp/timer button until the timer icon blinks. The hour display will appear. The auto on icon will also appear.
Use the up and down arrow buttons to set the heater start time between 1 and 10 hours. This function will activate once the timer icon stops blinking.
The heater will automatically turn on when time expires.
Hope this helps!
Sep 24, 2007 | Honeywell /KAZ HOME ENVIRONME HZ-705 7Fin...
YB 300 PE
The reset button didn't work for me.
Mar 03, 2007 | Grundig YB 300PE AM/FM/SW Radio
Grundig YB-550PE AM/FM Radio Logo
271 people viewed this question
Top Grundig Audio Players & Recorders Experts
Greg Cann
Greg Cann
xxxxxx xxx
Are you a Grundig Audio Player and Recorder Expert? Answer questions, earn points and help others
