Question about Grundig 21" TV
When I turn on my Gundig TV the sound is there, but the picture does not come for about 15 minutes. It starts off blue then slowly changes colour and eventually comes on. The TV is only 16 months old. have you ad]ny other experiences of this type of thing.
    Top Expert:
  • Grundig Master
  • 75,157 Answers
Hello
It may be due to the fault of its picutre tube base socket. Some of them may show this type of fault eventhough it is a new one. Picture tube base socket is located at the picture tube bas card itself. It is directly soldered to the base card, throu which the connections are going into the picture tube via its pins. You just open the tv, and pull it out [not make any shakes while pulling it, as that may bed the picture tube pins, or iven break the picture tube neck. Just pull it straight out, and refit it at the same way as you pulled it out, for two or three times. Sometimes this will retify the fault, as this process will remove any loose contact between bascard socket and picture tube pins.
If this doesn't hlep, desolder it out from the picture tube base card, go for a similar type and pin confuguation. Replacing it will solve the problem. As you replacing the base socket, look into the base card for any loose soderings are there too. OK.
Posted on Nov 08, 2010
I decided to try the TV again, after it sat for the day. I plugged it back in, turned it on from the tv panel. It came on picture and sound was fine. Within 10 minutes, everything stopped, went blue. I did...
sounds like it is over heating. in side the tv there is 2 square box cannot remember the colour but they are yellow or blue near to a heat sink chip. if you change them it may just be that fault. Bush tv's suffer from this problem.
Aug 31, 2013 | Spectroniq PLTV-42HW68 42 in. LCD TV
Sony KLV32T400A LCD TV. Colour Problem With Black colour of hair showing blue. Other than that the TV is fine. What solution
Hello, Sounds like an LVDS Cable or T-con Board.
Usually this will slowly get worse until it is repaired. It is caused by a failing T-con (Control) Board or connecting cable. T-Con Will Need replacement. This picture show's more extreme T-con board failures
Feb 18, 2012 | Sony Televison & Video
When I turn on my Philips rear projection tv, the power comes on but no picture or sound. power light stays lit solid. If i adjust slowly the screen or focus controls, the picture and sound will come on....
could be a number of things....check for bad solder connections on circuit board around Flyback xformer and also check connections on conversion module for colour problems....double images red , blue , green popping in and out.
May 19, 2010 | Philips 60PP9352 60" Rear Projection...
Sony wega 28 inch colours wrong, circle on screen
It sounds that there is some magnet near by TV that is affecting picture tube. Please remove any extra speaker or any thing that has strong magnet inside, unplug TV for 20-30 minutes, replug back in, turn it ON, hope that will solve your TV problem.
Thanks.
Nov 16, 2009 | Sony WEGA KV-28HX15 28" TV
Bush RFT TV
The picture tube of the tv has 3 color in CRT Red, Green, Blue. The red cathodeof tv set has no function, its either the resistor become higt resistance, that why u need a repairman to replace it.
Apr 10, 2008 | Televison & Video
Samsung tv settings
it depends on what your using it for, adjust colour tones to what you think looks natural, contrast between 80-90, keep sharpness below 30. just have a play around till you find what best suits the source material.
Mar 25, 2008 | Samsung LE40R74BDX 40 in. LCD Television
Televison probs
Most tv's degauss themselves when turned on so turning off and on a few times might help. Leave about 15 minutes between on off cycles and keep on trying untill you see improvement. You could also get hold of an old tape eraser, plug that into the mains and starting from a foot or so away try to brush the badly coloured parts away without coming to close to the screen.
Jan 13, 2008 | Beko 324250WN 28" TV
AKAI TELEVISION
Probable bad tuner or tuner circuit issue, repair or bypass.....
If you can direct signal to A / V inputs as you are doing with your
DVD, then no repair is necessary.....utilyze cable box or VCR
tuner to change channels.......................T.
Dec 03, 2007 | Televison & Video
Shutting off and on...
the problem may be due to dry soldering in the power supply stage if it was with the lamp there would be red or green light showing the presence of the power to the tv after making it own some of the components get hot and it will make the the soldering point conectionless and after some time the heat sink get cooled and the soldering point gets connected and u will see the picture again it is a simple problem if u have a soldering iron u make it hot and re solder all the components in the first part of the circuit board and the problem if rectified
Jul 03, 2007 | LG RU52SZ30 52" Television
Grundig 21" TV Logo
159 people viewed this question
Top Grundig Televison & Video Experts
Raj Patel
Are you a Grundig Televison and Video Expert? Answer questions, earn points and help others
