Question about Samsung MW1080STA Microwave Oven
Cm 1929 error code e41 - Samsung MW1080STA Microwave Oven
I there i have a samsung cm1929 microwave and it coming up with the code e41 please help thanks mike
Posted on Aug 27, 2011
Sharp r884. Will there be enough space for safety in my housing unit for it which is 570 MM. Wide, 315 MM high, 580 MM deep.
Dimensions (WxHxD): 52x30.9x48.8 cm - Should fit in your space, however ... this doesn't leave much room for air flow unless there are vents in the back. There must be somewhere for the hot air to go.
Jul 25, 2016 | Sharp Microwave Ovens
Exterior of oven , top and both sides gets very hot to touch, when cooking +- 10 minutes or more the last couple of days; no Error ( E41/42/45 or 47 are being displayed. Fan is normal, functions: OK
There could be food or oil buildup around the door frame which will absorb some of the radiant and microwave energy whilst cooking. Give it all a good clean and see if that helps. If everything else is working properly, it may be a problem with the cooling fan. Microwave ovens have a "stirrer fan" inside the roof or rear of the cooking area to disperse the microwaves and some convection / microwave ovens also have a cooling fan which assists in dissipating heat within the cabinet.
Jan 04, 2016 | Microwave Ovens
WHAT is error 51 on a rational oven
Error 51 doesn't exist on SCC and SCC_WE models. If you are referring to a Combi-master or Combi-master Plus (CM or CMP) then error 51 means the battery on the control board is below 1.5 volts and should be replaced. Go to your local electronics or grocery store and buy a CR2032 battery, it looks like a quarter. Open up the front control panel and replace the battery.
Feb 26, 2013 | Microwave Ovens
E41 and does not work
If your microwave is displaying an error code cycle the power to the microwave by either unplugging the unit, or cycling the circuit breaker.
If the above suggestion does not work,and the error code returns, your microwave will require service.
Aug 19, 2011 | Samsung MW1080STA Microwave Oven
I have samsung 1850w CM1929 Microwave it shows e41 and does not work.
if you have not plugged out the microwave...then do so now.the trick is that when you plug out the microwave it will reset the microchip.after you have plugged it out ....then you plug it back in after about an hour.if that does not work then it is time to look for a tech to repair your microwave.the problem is that the diode or the cap is bad.
Mar 04, 2011 | Samsung MW1080STA Microwave Oven
Nu-tec NTV2131 51cm TV
Press the 'display' button for 5 seconds
Mar 31, 2008 | Hotpoint RVM1625 Microwave Oven
Repairing Sansung Microwave version CM 1029
first check voltage to hv transformer if volts probably loose contacts on magnetron ,cap ,diode if still change magnetron
Mar 18, 2007 | Bosch HMT9626GB Microwave Oven
Samsung MW1080STA Microwave Oven Logo
1,032 people viewed this question
Top Samsung Microwave Ovens Experts
William Miller
William Miller
Steve Allison
Steve Allison
Simon Flummox
Simon Flummox
Are you a Samsung Microwave Oven Expert? Answer questions, earn points and help others
