Question about Gigabyte Giga-Byte: GA-8I865GM-775 LGA775/865G/FSB800/DDR400/MATX Motherboard (MOTGB15)
Iam open the power supply connection after open iam don't know how connect powerled, h.d.d led, reset led and plus minus power led.
SOURCE: connections
Foxconn 6150BK8MC-KRSHN2 Socket 939
Posted on Jan 05, 2008
mumma_1
  • 903 Answers
SOURCE: ACORP 6bx/via/zx81connectors
http://images.google.co.uk/images?gbv=2&hl=en&q=where+does+hdd+led+and+pw+led+wires+go+on+gigabyte+motherboard&btnG=Search+images
click on this link and it will take you to some images of various motherboards and where the leads go.
I hope this helps
Posted on Nov 15, 2008
  • 45 Answers
SOURCE: Pls help how to install reset led, powerled, hdd led in SiS-74
Find the model name and google it, you should find a manual to help.
Posted on Dec 21, 2008
mrahul_009
  • 83 Answers
SOURCE: powerled and resetled where isit conected in main board e139765
go to below link.....refer the diagram
http://support.dell.com/support/edocs/systems/dim2350/techov.htm#1101565
Posted on May 31, 2009
Took the connector off of my lorex mc7221 color night vision surveillance camera. I want to connect the dc power and put an RCA connector on it to plug into my tv. there are three wires coming from ca
RED IS PLUS DIRECT CURRENT POWER
BLACK IS MINUS DIRECT CURRENT POWER
WHITE IS CENTER VIDEO
OUTSIDE OF SHIELD OF VIDEO JUMPERS TO DIRECT CURRENT MINUS
BE SURE TO OBSERVE POLARITY OF POWER SOURCE AND BE SURE THAT VIDEO DOES NOT EVER CONTACT PLUS SIDE OF POWER SUPPLY
Nov 23, 2014 | Lorex Home Security
How to replace my battery without locking up my radio with theft deterrent
Obtain a temporary battery (12volt)and connect it across the terminals plus to plus and minus to minus this will ensure there is power available while you disconnect the old battery and replace with a new one,when the new battery has been installed remove the temp supply.
Len
Oct 14, 2014 | Cars & Trucks
How to determine the plus and minus wires
You may check it with DC voltmeter. With voltmeter, red cable is plus, black cable is minus. Connect it wit the inverter.If your voltmeter is measuring positive, it mean the polarity is true, this is mean cable of inverter that connect with red cable of is plus, and with black cable is minus. If voltmeter measuring negative, try to flip the connection to measuring postive.
Apr 19, 2012 | Targus APV10US1 100W Slim Line Mobile...
My digitech rp 500 has power supply but it won't
Make sure you have the OFFICIAL Digitech power adapter. Universal adapters or those for MOST other pedals will NOT work... things may light up but you will NOT get audio. This unit requires an adapter supplying 9 VAC (not DC) at about 1 amp. These AC output adapters are not very common and people get the units without an adapter and try using universal adapters and they do not work. An AC adapter is used by Digitech so they can generate both plus and minus voltages internally. I don't know what your utility power voltage is in Cebu, so you need to get an adapter for your voltage that will give 9 VAC output and fit the power jack on the unit.
Sep 15, 2011 | Digidesign Digitech Control 2 pedal for...
I need to connect a led light for the number plate to the bike and i dont know how and where to wire it too
Connect this across the same wires that go the tail light. Find the wire that powers the running light bulb, not the stop light!
You can find which is which by just pushing the wires of your LED into the connector plug for the tail light.
With LED it is important to wire the plus to plus and minus to minus.
So black to black, then test the other two potential wires (with igniton on) to see which is hot, without touching the brake.
Once you identify the correct wires to splice to, make a permanent connection to the wires.
Positaps - are a great connector for this kind of connection - you can get those at your local autoparts store.
Aug 15, 2009 | 2004 Yamaha DT 125 R
Need picture of mother board for Emachine C2825
I've built a PC myself, each connector had text on it to say what it was and one arrow on it in relief, don't know wether that indicated plus or minus anymore.
Anyway, I recommend you just plug them in, and try to boot the PC. If it doesn't boot, switch the Power SW connector around, then it should boot. Do the same with the LED connectors, and it should work just fine!
Good luck,
Yannick.
Jul 13, 2009 | Intel D845GVSR Motherboard
Dec 20, 2008 | AMD A7S333 (SiS 745) (MBSA7S333)...
Wire connections/installation
the +/- wires don;t really mater ! but as a general rule, the writing on the cable connectors should be facing you !
i don;t realy understand what u don;t understand, it-s easy, u guide u're self from the diagram on the motherboard (the one u tried to draw) (in the first raw on the left u put the power led cable, under it the reset cable .....)
there is no problem if u get them wrong, u can't damage anyting, so u can try until u get them right
Jan 20, 2008 | Soyo SY-K7V Dragon Motherboard
Connecting hdd led lead and power led lead,where do they go ?
Hi, There are 3 versions of this motherboard; 1.0, 2.0 & 3.3, but the layout is identical. The general layout is shown in pins.jpg. For the power led, the white wire goes to the (-) terminal either pin 2 or 3, both are MPD- while the green goes to the ( ) or pin 1 (MPD ) as shown in powerled.jpg HDDpins.jpg shows the connection of HDD led, the white goes to pin 3 or HD- while the red goes to pin 1 or the HDD . I cropped these images from the manual which is also available at the gigabyte website. Hope this gives you some ideas and workout of you. Good luck and pls post again how things turn up. Kind regards.
Aug 15, 2007 | Gigabyte GA-965G-DS3 Motherboard
Computers & Internet Logo
26 people viewed this question
Top Gigabyte Computers & Internet Experts
David
David
Tony
Matthew Spark
Matthew Spark
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
