Question about Samsung SF-560 Plain Paper Laser Fax
VERY SLOW FEEDING PAPER THROUGH - Samsung SF-560 Plain Paper Laser Fax
    Champion:
  • Samsung Expert
  • 214 Answers
Open the adf. the is the rop part of the printer where you put in the fax paper. clean the back black roller with soupe. close and test it
Posted on Oct 06, 2011
Ricoh 6123 b copy printer paper jamming in feeding section frequently.
store paper in dry conditions. check any rollers for being worn out
Jan 03, 2015 | Ricoh Office Equipment & Supplies
Thin paper keeps jamming
According to fusing (heating) at last final, thin paper is not possible to print in laser printer. it is better to use with little 70gms thick paper together using glue at feeding side only.
Dec 30, 2013 | Brother HL-2070N Laser Printer
Canon MF 6530 Paper Jams at fuser ,always the same about 2 inches through the fuser , Same issues from bypass tray is this mechanical problem or a electronic
it can be that sesor flaper in fixing unit has an slow response or the sensor is faulty. Also it can be that this is delay jam due to worn out paper feeding roller, or faulty pressure in fixing assy.
Recommendation is to call service!
Sep 16, 2011 | Canon MF6530 Black and White Copier
At the onset of copying one side of the paper is fed into the machine faster than the other side and the paper then jams.
you have worn pickup rollers, as a temporary measure you could take them out and clean them with rubbing alcohol and a fine sandpaper. but idealy replace them.
it could also be a jam that is blocking check the place where feeding is slow and ensure there is no dust or paper fragments in there.
Mar 17, 2011 | HP LaserJet 2840 Printer
I have a Royal VF1000MF shredder. While shredding
Try running the shredder in reverse and oiling the blades. More assistance with paper shredder oil here: http://hubpages.com/hub/Paper-Shredder-Oil
If you can't get the paper shredder back to good condition it looks like you might have to get a new paper shredder. Great place to learn about new paper shredders here: http://hubpages.com/hub/Best-Paper-Shredders
May 24, 2010 | Royal VF1000MX Shredder
Paper not feeding thru properly
please the dumping roll and paper feeding pad is very celing and
who do use paper ? this paper is very glose papre ? if yes,
when one by one give up and second time
the paper is regulary use the friently paper and out of air in paper
and put the paper trey and use regulary ok.
Sep 25, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
Manually feeding paper
Even if manual feeding is an option the paper must be able to fit the paper tray in order to feed it through the printer.
Jan 20, 2009 | HP Photosmart 3210 Printer
Paper not feeding in order to print
make sure the input tray is properly setup and aligned, the tab is pushed against the paper.
Dec 12, 2008 | HP LaserJet 1018 Printer
Paper keeps feeding
Just started happening yesterday to my HP printer as well....a virus maybe?
Jan 25, 2008 | HP Photosmart 2610 All-In-One InkJet...
Slower printing speed
Multiple sheet feeding in any printer can mean many things. Paper roller blockages and jams, wrong paper for printer, too much paper in. Make sure you check right down the back and inside the unit for anh small blocks. This can then cause errors in the printer itself. As it is now printing but slow, the paer issue could be resoved but you may now have driver errors or pc issues. Are you getting any flashing LED lights. Have you checked to see if device is showing errors or functioning correctly. Go to start menu, control panel, performance/main, system, devices, scroll down to your printer, are there any yellow exclamations? Does it say it is working ok?
Aug 10, 2007 | HP OfficeJet K80 All-In-One InkJet Printer
Samsung SF-560 Plain Paper Laser Fax Logo
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
