Question about Electronics - Others
I bought a new tdk 4GB flash memory card for my Canon digital IXUS 8001S camera. The screen on the camera shows Memory card error card locked. What do I need to do please?
rmaddox5
  • 5 Answers
SOURCE: MEMORY CARD
I would think that as long is it is a sd memory card then it would be compatible since the camera uses the sd card and the 4gb is for photo storrage
Posted on Jan 26, 2008
SOURCE: Canan digital IXUS 8601S Camera showing
canon camera xius 80 showing - memory card locked .... please help... it beeps at the atempt of clicking photos
Posted on Sep 08, 2008
randy320sgi
  • 121 Answers
SOURCE: New San Disk memory card not working
vebhat,
Make sure the little slide on the SD card is in the right position, and if it's a high capacity SD it might not be compatible with your camera...
randy320sgi
Posted on Jan 09, 2009
  • 5 Answers
SOURCE: memory card error
I assume that you know that there is a tiny tiny on-off switch on the edge of each SD card. If they are locked in the off position....
Posted on Apr 29, 2009
SOURCE: Memory card will not show up on my computer.
Verbatim compact flash card has over 200 photos corrupted files. I volunteered to take photos for local senior anniversary I was the main camera now, I have lost the content. Files are Dcim--JPO, POG and worse coded files not JPEGs and I even with trial acdsee repair I am unable to rename and restore these photo files. CVS photo was able to open some of the files with their program but advised we would need to find the proper recovery program to restore some of the files.HELP
Posted on Jul 21, 2009
Camera canon ixus 105 memory card error
There are several possible causes for "memory card locked", "memory card error", or "no memory card". The most common is trying to use a 4GB or higher SDHC card with an older camera made before SDHC format came out. Other causes include problems with the tiny slide switch on the side of the card, or the electrical contact switch internal to the camera. The problem may also arise from simple formatting problems if the card has never been formatted in the camera (note that this will also erase the card). Troubleshooting tips for this problem may be found at this link.
Jun 05, 2011 | Canon PowerShot SD1300 IS IXUS 105...
Canon IXUS 95 IS gives me a report: card locked, while the card is not locked; gives me a report; memory card error please tell me what is wrong?
There are several possible causes for "memory card locked", "memory card error", or "no memory card". Some include trying to use of a 4GB SDHC card with an older camera made before SDHC format came out (note, this is not the problem with your newer model camera). Others include problems with the tiny slide switch on the side of the card, or the electrical contact switch internal to the camera. The problem may also arise from simple formatting problems if the card has never been formatted in the camera (note that this will also erase the card). Troubleshooting tips for this problem may be found at this link.
Oct 15, 2010 | Canon PowerShot SD1200 IS / Digital IXUS...
I got a new 4gb sd memcard for my 2005 canon ixus 50, screen shows " memory card error" "card locked". tried switch on card as u suggested, no diff.
The IXUS 50 works with SD cards. Your 4GB card is actually an SDHC card. While it fits into the slot, it is electronically incompatible and will not work. You need to use SD cards 2GB and smaller.
Oct 06, 2010 | Canon Cameras
I have a Canon SD400 Powershot digital camera. It
First, make sure your camera can accept SDHC cards. If the camera says the card is locked, move the slide switch on the side of the card.
Jun 13, 2010 | Canon PowerShot SD400 / IXUS 50 Digital...
Inserted new memory card error message:memory card error unable to access format under menu
I'm guessing that you bought a new 4GB SDHC card. Although it looks exactly the same as a standard SD card, the format the card uses is very different. Unfortunately your camera was designed before the SDHC format came out. Sorry, but a SDHC card will not work with your camera.
You'll need to use standard SD cards (usually those 2GB or less). But if you really want to use a 4GB card, do a Google search for 4GB SD "non HC", with the non HC in quotes. Believe Transcend makes one.
Nov 07, 2009 | Canon PowerShot SD630 Digital ELPH / IXUS...
I just purchased a 4gb memory card for my canon powershot sd700 and it reads memory card error-card locked. I put my old 2gb card in and it works just fine. I took the 4gb back to the store and bought...
ok, first off:
make sure the card is compatible with the camera and the camera is compatible with the card (reffer to the manuals of both products).
if all checks out, contact the manufacturer of the camera first, then do the same with the card.
if everything works up to this point, but you still cant get it to work, get a new camera.
Oct 27, 2009 | Canon PowerShot SD700 IS Digital ELPH /...
Memory card error
Apr 29, 2009 | Canon PowerShot SD550 / IXUS 750 Digital...
My Powershot 450sd camera is not reading 4GB SDHC
Apparently IXUS 55 is not compatible with a 4GB SD card. Use a 2GB and you would be fine.
Dec 29, 2008 | Canon Powershot SD450 / IXUS 55 Digital...
SDHC memory cards are relatively new, and are sadly compatible with only the newest model cameras. For your model camera, recommend a maximum 2GB standard SD card. Fortunately, these days a 2GB card is very inexpensive.
Canan digital IXUS 8601S Camera showing Memory Card Error Card Locked
Aug 05, 2008 | Canon PowerShot SD750 / IXUS 75 Digital...
Electronics - Others Logo
Top Electronics - Others Experts
Are you an Electronics - Other Expert? Answer questions, earn points and help others
