Question about Umax AstraPix PC210 Webcam
Need software to use the webcam on my computer
I need free software for webcam
The webcam usually comes with instructions on how to connect it to a computer and are usually connected vial a USB 2 plug. If you know the make of the Webcam you can search the Internet for the company and, hopefully you will download their software.
Dec 28, 2014 | Casio Exilim Zoom Ex-z35 12.1 Mp Digital...
Lost cd that i need to use webcam
You can get the installation drivers you need from the webcam's manufacture website.
Go to Google or Yahoo search and type in the name of the webcam and model number.
The list of results should guide you to the manufacture where most likely you will find
installation software for your webcam that can be downloaded to your computer.
Often, you may find a non-manufacture website that will offer installation software for
your webcam as well.
Good Luck with your search.
Mar 10, 2011 | Computers & Internet
My web cam is showing a black screen i dont know what to do i have windows vista
How to troubleshoot Webcams in Windows Vista?
If you are having difficulty getting the webcam to work, review the tips about using a webcam, and then follow the troubleshooting actions in this article.
Tips:
  • Do not enter standby and then wake the system immediately, before the power light turns yellow. If so, the webcam may not function correctly until the computer is restarted. To avoid this issue, allow the system to fully enter standby before waking up the system.
  • If you installed the webcam separately (it did not come with your Vista PC), make sure the webcam drivers and software are compatible with Windows Vista.
  • If you are using an external webcam, make sure you install any webcam software from the CD before you plug the webcam to your computer. Without the software, the webcam may not be recognized by your computer and this can cause error messages.
  • If the display is blank, the camera may have timed out. Turn the camera on again.
  • If the camera does not display Connected to computer, disconnect and then reconnect your camera.
  • Make sure the camera is set to Digital Camera in USB Configuration when trying to download images through some software.
  • Test your webcam in a different application to confirm if the issue is specific to that application. If the webcam functions properly in a different application, then contact the manufacturer of the video software for the latest drivers and for specific troubleshooting instructions.
  • If you have an external webcam, test it on another computer. If it functions properly on a different computer that has the same operating system, then you may need to install hardware drivers for your computer to work with the webcam.
  • If an external webcam fails to work on several computers, your webcam may be defective. Contact the webcam manufacturer for specific diagnostic information and troubleshooting instructions.
  • Your webcam may not work properly across some network firewalls. If you have trouble viewing or sending video to someone on another LAN or outside the network firewall, refer to the support information for the firewall or contact a network administrator for assistance.
  • Dial-up Internet connections often lack the data transfer capacity to handle both video and voice simultaneously. A broadband Internet connection is highly recommended for video messaging. Performance varies with dial-up connections.
  • For the best webcam experience, close all other applications and background tasks, and limit your Internet browsing or streaming to preserve bandwidth.
Step 1: Close all software before starting a new webcam session
Sometimes after you finish using the webcam in a software program, the program may not properly release the webcam for other activities in other applications, or even the same application. Sometimes you cannot use the webcam because it is being accessed by another program by default. So, if you are having a problem with your webcam, close the program you are using it in and then restart the same program or open a different program.
Step 2: Restart your PC
Sometimes, closing the software application that was using the webcam is not enough. Some webcam software cannot close the webcam for other applications to use later. When this happens, the webcam cannot be used by any other application until the computer is restarted.
Step 3: Select the webcam in your video viewing software list
Make sure USB 2.0 Camera or your Webcam is selected as the video input source in the software you are trying to use. The various software programs that can use the webcam use different terms for describing a video source and the option to select it can vary. Usually, camera, webcam, or video settings can be found in the preferences or properties pages for the software that uses the webcam.
If your PC includes a TV tuner, often the TV tuner is the default video input device. So, for example, if you are using Windows Live Messenger to have a video chat with your webcam, you need to select the your Webcam as the active input device because the TV tuner is the active video input device by default.
Example: Select webcam in Windows Live Messenger
To select the webcam as the default video input device in Windows Live Messenger:
1. Open Windows Live Messenger.
2. Click the arrow icon on the Windows Live Messenger toolbar.
3. Select Tools and then Audio and Video Setup .
4. Click Next, Next, and then Next again.
5. In the "Select a Webcam you would like to use" dropdown list, select the name that corresponds to the webcam that is installed on your PC (such as USB 2.0 Camera)
6. Click Finish.
Step 4: Download the latest drivers and updates for your webcam and your video software
Some webcams may not be recognized by some software programs unless you have the most recent drivers and updates for your webcam hardware and webcam video software. Also, if the video footage from your webcam is in a format not supported by your video software, you may need a third-party plug-in or utility to view or convert the video footage to a format supported by your webcam video software.
  • If you installed the webcam separately, go to the webcam manufacturer's website and download the latest drivers, updates, plug-ins, or conversion utilities for any webcam video software. Make sure the webcam drivers and software are compatible with Windows Vista!
  • If you are having problems getting the webcam to be recognized by video playing or editing software, go the software manufacturer web site to find and install any updates or patches.
  • Check Windows Update for any Vista-related drivers that may affect your webcam and your video software. Click the Start button, All Programs , and then Windows Update
Step 5: Make sure you have the correct Vista drivers installed
If you are having problems hearing sound or using your webcam, try the following steps.
Make sure you have installed the correct Vista drivers and not the generic sound driver in Windows. If you have installed the generic sound driver, uninstall the webcam video software and download and install this Vista sound driver, and then reinstall your webcam video software.
To update Windows Vista drivers:
  • Click the Start button, All Programs , and then click Windows Update . If you are prompted for an administrator password or confirmation, type the password or provide confirmation.
  • Click Check for updates .
  • To see if updated drivers are available, click View available updates . Windows Update will list any updated drivers that are available for devices installed in your computer.
  • If updates are available, click the driver that you want to install, and then click Install . Follow any onscreen instructions to finish installing the available drivers.
You may need to set up the sound settings in your instant messaging program or any other video webcam software you are using with your webcam. Refer to the Help information in your webcam software.
Aug 15, 2010 | Logitech Webcam
Error: Webcam driver open fail. Problem with Satellite A305D
sounds like driver related problem, download this tool: Driver Update Software for XP Vista 7 8 update your drivers, and won't be any problem.
Jim
Jun 15, 2010 | Toshiba Satellite A305-S6845 Notebook
Laptop integrated webcam is not working can show me a solution ?
Test your webcam here by hitting "allow" in top window and seeing if webcam displays in left panel
http://www.testmycam.com/
1) Working OK = Webcam hardware (cam and connections) are functional and installed software is problem
2) Not working = Fault with hardware - Take laptop to techshop or disable software and install plug-in webcam
Software problem ( as in 1 above )
solution
1) Expand 'imaging' file in Device Manager and right click on text for webcam - 'Update driver' using internet option.
2) Uninstall webcam software, restart computer and re-install using CD ) 3)Uninstall webcam software, restart computer and re-install using webcam manufacture's download from support website
4) Uninstall software and if computer has 'New Hardware Detection' facility reboot allowing the software to install automatically.
Aug 31, 2009 | Computers & Internet
Software for creative vf-0040
i need the software for creative model vf-0040 webcam
Sep 29, 2008 | Creative Labs WebCam Live!
Webcam
With the camera focus away from press the left curved button to record video. To use as a webcam hook the usb cable to your computer, and open the software that came with your computer. Press that same button and in the software you will see the webcam. Or you can use your chat program to access the webcam.
Mar 05, 2008 | Aiptek DV8800 Digital Camera
Webcam labtec
if u lost the CD you can download the software from "www.newsoftwares.net"
you can download the software by entering the serial number of that webcam
Let me know if your problem is solved and rate me as FIXYA!
Mar 01, 2008 | Computers & Internet
How can i download the software in to my new computer
www.logitech.com has some answers. Pick your model number, and operating system for your computer, and you should be fine.Download that software, and follow installation instructions
got backup for your computer?
Feb 12, 2008 | Logitech QuickCam Sphere Webcam
I lossmy webcamerra cd software
I lost my software to install my webcam....what can i do?
Dec 05, 2007 | GE EasyCam Webcam
Umax AstraPix PC210 Webcam Logo
15 people viewed this question
Top Umax Computers & Internet Experts
EKASYS IT SERVICES
EKASYS IT SERVICES
tdk1988
Are you an Umax Computer and Internet Expert? Answer questions, earn points and help others
