A red box between 3-4 inches has appeared on our picture. Sometimes it fades in a out. Other times it turns green. It runs vertically from the top middle downward halfway down the screen. Any ideas?
I am getting re or blue lines running vertically on my Tv. They are not there all the time just now and then. Can I fix it with my remote or do I need a tech?
The problem you have is the grayscale tracking needs to be reset.
First, This looks like a philips tv. In order to set the grayscale tracking remove the back of the set. There should be rectangular shaped box that is marked screen and focus on it with 6 knobs coming out of it.
Step 2:
NOTE: DO NOT TOUCH ANYTHING INSIDE THE SET-YOU WITH BE SHOCKED! WITH THE TV TURNED ON, WITH THE REMOTE, TURN DOWN THE COLOR TO ZERO. ON THE CONTROLS I PREVIOUSLY MMENTIONED, THERE ARE RED,GREEN AND BLUE ADJUSTMENT POTS.
Step 3:
TRY TURNING DOWN THE RED UNTIL YOU SEE A NORMAL GRAY PICTURE. YOU MAY HAVE TO ADD MORE GREEN OR BLUE AS NEEDED. IF THIS DOESNT LOOK RIGHT ,TURN ALL 3 R.G ANDB ALL THE WAY DOWN, THEN ADJUST THEM UNTIL THE COLOR IS JUST APPEARING ON THE SCREEN, MAKE THE PICTURE AS GRAY AS POSSIBLE. iF THIS DOESNT WORK,YOU WILL NEED A SERVICE PERSON TO REPAIR YOUR TV.
tv has a blanking picture mute circuit. adjust the screen controls which are located behind the speaker grill in front of set. there will be a access panel to unscrew in center and then you will see a black 4 inch square box with 6 physical knobs. 3 control screen the other 3 controls focus for red, green, blue. turn them down and slowly start turning them up. fixed.
The Blue SCREEN setting is too high. These adjustments are located inside the TV behind the front panel. There are two screws behind covers and then a wooden panel to remove to access the adjustments. The leftmost set are for BLUE, the middle are GREEN, and the right are RED. The top row are FOCUS and the bottom are SCREEN. Focus will focus/unfocus the tube and Screen will adjust the power of that tube (there are 3 tubes, one for each color). If Screen is adjusted too high, horizontal lines will appear (my TV had red lines, but I played around with the knobs and saw that it could happen on any of the colors). Additionally, if SCREEN is set even higher than that, the tube could go so high that it turns the whole screen that color (in your case, blue). If this happens the TV will shut down, probably due to either overheating or overvolting. To fix this issue, turn the appropriate SCREEN dial down until the lines go away. In your case, you want to turn the lower left dial down. Don't turn it too far down, if you turn it more than necessary the TV can give you an AKB error (noted by the STANDBY light flashing a sequence of 5 blinks).
The service manual on page 8 shows how to adjust the Red/Blue/Green screen voltages. To get to the adjustment board, take the front speaker grill off (two screws at the bottom left and right) and set it aside. No need to disconnect any wires. Then remove the plywood board with 4 screws that exposes the screen/focus adjustments. The top 3 adjustments are for focus, and you need not mess with these. The bottom 3 adjustments are for Red/Blue/Green screen voltage rough adjustments. My screen showed red lines, so I had to turn the bottom right adjustment with a philips head screwdriver just slightly until the red gun retrace lines where no longer visible.
remove the front speaker assembly and the small access panel behind it and you will see a small square control assembly with 6 dials on it 3 control the color guns and 3 control the 3 gun focus. Try turning down the red control slightly they will be set up just like the CRTs red green and blue.
Problem solved. I tried playing DVD and the TV picture was fine. So I double-checked cable wires from cable box - one of the wires was loose (obviously it was the red color input). After tightening, the TV picture is good as new.
