Question about Sony FD Trinitron WEGA KV-32FS100 32" TV
Sony kv-32LS60U turns off and blinks2 then 3 times
  • mcewan07 Jun 30, 2008
    the light on the front of my tv flashes 5 times then stops then flashes again .has been doing it for a couple of months but recently my picture has gone too.the sound is fine but it takes about 5 min of me turning the tv on and off standby untill the picture shows up.would like to know if it is fixable or if i need to go and get a new tv.thanks
  • johnkata Jan 17, 2009
    Sony KV-32LS60U The standby light constanly blinks. The TV takes an age to come on. The sound is fine. There appears to be a pink tinge on screen. The problem appears worse when watching anything with grass! The green is more like pinky brown! ! Are the problems related? It is repairable? How common are these faults?
    Regards,
    John Mc...
LINE DRIVE FAULT, YOU NEED A TV TECH TO LOOK AT IT. LIGHTS ON THE FRONT FLASHING IS A BREAK DOWN CODE. UNIT HAS GONE INTO FAULT PROTECT MODE.
Posted on Jun 16, 2008
Does a universal remote work with a sony KV-32LS60U?
Hello
Sony TV can be synchronised with [RCA RCR311B] model universal remote control. The codes are:
1001, 1036, 1093, 1135, 1177, 1179
OK.
Aug 13, 2011 | Televison & Video
I have a kv-32ls60u Sony TV. It blinks 5 times
The most common failures are the flyback transformer assembly and sometimes some of its support components, and or there is the possibility of a short in the CRT electron gun. In either case, the power supply is going in to protect mode, and the uPC is sending this flashing error code to the front LED.
I have no idea if the flyback transformer assembly is still available, but I am very sure the CRT is no longer available. In any case you will find the cost of servicing your set to be expensive for its age. The last time I checked, the cost of the CRT exceeded the replacement cost of the set.
Jerry G.
Nov 14, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony wega tv wont turn on
sony kv-36hs500 no enciende y parpadea el stand by
Feb 22, 2009 | Sony FD Trinitron WEGA KV-36HS510 36" TV
Sony Vega Service Codes
KV-32HS510 and KV-27HS420, seven times blink error code shows problem in Horizontal deflection circuit.
There are many possibilities like dry solder joints, weak capacitors, Horizontal transistor short or flyback transformer fried etc.
If you have little experience of TV repair and good solder skills and have necessary tools to test / check defective parts, then you can make it. you also need to have related service manual to see board location, schematics and part numbers.
Dec 12, 2008 | Sony FD Trinitron WEGA KV-27HS420 27" TV
Sony Trinitron KV-32fs120 Does Not Turn On
i have a unvirasal remote how do iget the codes for it
Sep 29, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony kv 32ls60u
You just press the screen format button, It is 2 down from the number 9 button, Visit http://pdf.crse.com/manuals/4090586111.pdf For the instruction booklet which tells you all about it.
Hope that helps
Aug 19, 2008 | Sony FD Trinitron WEGA KV-32FS100 32" TV
Sony kv-30xbr910 my tv won't turn on and the standby fashes 7 times
Good day.
Your unit has issues with the high voltage section. Particularly the vertical and horizontal sections. Blinking lights indicates that your flyback is not osscilating to distribute the supply to the sections. Please have it checked by a repaiman.
chris
Mar 21, 2008 | Sony FD Trinitron WEGA KV-30XBR910 30" TV
Sony wega model KV-32FS12
Probably a defective horizontal output transformer , also check the horizontal output transistor. Both parts available from tritronicsinc.com
Jan 28, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony KV-32LS60U FD Trinitron 32
Your tv has Leak cap in POWER supply its either primary or secondary power. Need to replace it. Look for a Electronic Tech.
Jan 17, 2008 | Sony FD Trinitron WEGA KV-20FS120 20" TV
Sony FD Trinitron WEGA KV-32FS100 32" TV Logo
323 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
