I want to be able to control my Sky TV + box with the remote control but on a second TV in a different room. The complication is that some years ago I had a booster box fitted in the loft from which cable runs to each of the rooms I might want to watch TV in .This was fine watching Terestial TV, but now I want to buy a device which will allow me to control Sky remotely. Do I buy a Magic Eye as advertised on Amazon or an AV sender as being sold by Aldi this week?? Your help would be much appreciated. Tony, a.thelwell@sky.com
  • 2,385 Answers
Magic eye is advisable for your problem...
Posted on Nov 08, 2010
I cant view my sky channel on my tv
So you want to view your sky TV in a different room?
You can achieve this a number of ways.
Purchase the multi-room package from Sky TV. This will give you fully independent TV reception in each room. (Basically two sky boxes)
Purchase a TV sender which will wirelessly duplicate the output on the TV to another device.
Connect your Sky box to a second TV with high-quality co-axial aerial cable connected to the RF2 output on the back of the Sky box.
Mar 13, 2015 | Televison & Video
How do I get sky from my set top box to work in a different room, I am trying to get my sky to work on a TV in a different room ? I have wired up TV coax cable from my sky box in sitting room and run
Hi Jim,
Here In my place in India, you can attach only one tv to the sky set top box.That too with AV cables. The program or channel changing is done by box only. The tv works as a monitor and has no role in program selection. You can attach a second tv to the box not through antenna cable but through AV cables only. That too if the box is having second set of output sockets. In that case both the TVs will receive the same programmes. To watch different programmes on the second tv you will have to go for an additional box.
Feb 09, 2015 | LG Televison & Video
Sky Magic Eye not working over SLX 8 way booster/spliter
have you got it set on second out put on the sky box as number one is just normal. all cables have to be set to second output using a splitter box . so its like this.
arial in booster.
out booster to sky box.
out to tv/etc on first output on sky box.
second out put to spliter linc. ( eg 4 rooms out four way splitter)
each room with sky eye fitted to end of the aerial from number feed from sky box.
with each room with Eye sky can be controlled
also check that RF outlet power supply is set on sky+ or HD in settings menu.
access this.
settings
select ( remote)
type 01 (select on remote)
RF outlets.
RF outlet Power Supply ON
RF channel 25 ( is best for most areas)
Feb 01, 2014 | Televison & Video
Convert Sky TV remote control to UMC TV
Cant find umc on my sky to control to use sky control
Nov 19, 2009 | Televison & Video
I have a tv sky box in lounge and 2nd tv in a different room connected by a co ax cable. I need a desription or a diagram to get everything working. It worked prior to having a new carpet fitted and the...
Check first that the Co-Ax cable is firmly plugged into your SKY box in your lounge.
(I'm assuming that the carpet fitters did NOT put a nail thru your co-ax cable or pushed the cable onto any metal carpet grippers???)
If they might have done this accidentally, then, that's why it doesn't work!
Then make sure that the co-ax cable is plugged firmly into your second TV. Sometimes the central connector within the co-axial socket becomes loose and needs nipping back together with a pair of long-nosed pliers.
I'm assuming that you have plugged the Infra-red remote eye unit back into the second TV aerial socket - before you plugged the co-ax cable back in?
If you have, press the SKY remote to see if the Infra-red LED can be seen in the remote pod.
Finally, make sure that you have selected the correct channel number (or Input) on your second TV remote to select SKY.
Nov 18, 2009 | Televison & Video
Have lost the link from sky+ to a second tv which was tuned to sky via channel 5 and majic eye on annolog since re tuning i cannot receive sky on second tv
Hello K Agate,
In the main room where the Sky + is locate. With the sky remote press the following.
Services.
0,1,select
4 (rf)
Ensure that the RF power to set to on, and take a mental note of the channel number the RF is set to. I normally set this to 38 it is upto you.
Now check that the coax lead that links the sky+ box to the 2nd room is plugged into RF out 2 on the back of the sky+ box.
Now go into the other room and make sure that there is a red LED light on your magic eye. If there is then great. If not there may be a fault with you eye. A good way to check this would be to connect it straight into the back of you Sky+ RF OUT 2 port. This would also check to see if there is any fault with the coax cable feeding the other room.
Assuming that there is a Red LED light on the eye when its plugged into the back of the TV in the other room (not the one with the sky box in), This means that there is power getting to it from the Sky + box.
Put your sky box on the TV GUIDE screen. This will make tuning it in a lot easier.
in the other room with your tv remote press the following
Channel 6 or which ever number you want it on.(analogue)
then MENU on the remote.
Go to MANUAL STORE
Then if you go down to where it give you a C ** number just type in what you retrieved from the sky RF menu.
That should bring your sky up then all you need to do now is STORE.
That should be you all sorted out now.
Hope all goes well. If so then please leave a Thumbs up
Cheers Little Dish Fitter.
Oct 21, 2009 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Stopped receiving sky on second tv - does my samsung need a reset
I install a lot of magic eyes etc.
You have checked that the magic eye lights up when it is connected directly into the sky box. So your eye is working correctly.
the next step I would take is with your sky remote in your main room. press SERVICES, 4, 0,1, SELECT go to RF settings and check the rf channel and make sure the power is on. Take a mental note of the channel number.
Now go into the room where the link is feeding. Turn on the TV and go to channel number 6 press your MENU button and then go down to setup. go across to manual install and then down to the channel number type in what you retrieved from you box ie rf channel and then type it in and STORE.
If you go into your main room and just put the normal tv guide on ie blue screen. then check that your getting the sky into the other room. IF you are then great it just needed tuning in. IF not I would remake the coax connectors. as there may be a bit of copper braid touching the centre core. once this is done your sky should be on all you need to do now is put the eye back on. Once you have done this the red light should appear on your magic eye. if not go to your main box and follow the first instructions I gave you and turn the power off on the RF and then save and then go back in and turn it back on and save.
Hope this sorts out your problem
Cheers
Little Dish Fitter
Feb 27, 2009 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
Can't get sky remote control to work
i have a amstrad sky box the remote has the record button on it.
i did not change the batteries in it now it wont work the sky box at all.
HELP PLEASE....
Oct 08, 2008 | Televison & Video
Televison & Video Logo
162 people viewed this question
Top Televison & Video Experts
Electro Med Services...
