Question about Dryers
Looking for a simpson eziset 445 clothes dryer manual
5 Suggested Answers
  • 142 Answers
SOURCE: clothes dryer stops
sounds like the drive belt has stretched, or the auto tension is low.
disconnect power and remove back cover, clean inside around motor resitor block wires, and inspect/ replace faulty components. good luck!
Posted on Jan 30, 2009
SOURCE: Simpson Sirocco 350 Dryer not heating
there is an oval cover on the back of the dryer. Remove this cover and you will probably find a broken fan belt. A replacement costs about $20 Aus.
NOTE: If you have been using the dryer for a while in this condition there will certainly be moisture inside the dryer. Replace the belt and leave the dryer for a few days to dry itself out (motor and electricals) before firing it up.
Posted on Feb 25, 2009
  • 686 Answers
SOURCE: Simpson Clothes Dryer wont start without assistance
your dryer has a start assist compressor go to this site to see it and that could very well be the problem. www.repairclinic.com/SSPartDetail.aspx?s=t-39p400-%3d%3db166i938994%PartID=938994
Posted on Mar 12, 2009
SOURCE: Simpson Maxidry Tumble dryer (Cloths dryer) How
Hi there, There is a switch at the bottom of the dryer. It has a groove for the spring to fit around. Then the spring goes through the metal tag with the holes in the pulley. The pulleys 2 prongs then fits into the slot near the motor. The belt goes through the pulley and around the motor wheel. When fitting the drum, tape the belt at three points on the drum with the machine door facing down making installation easier. Once installed remove the tape. The dryer now works like a dream. See the attached photo. Good Luck!8e72e75.jpg
Posted on Jun 29, 2010
Simpson washing machine
you need a 10mm socket and some extensions and a ratchet take the fabric softer filter out and undo the ,bolt at the bottom of the agitator and lift out
May 28, 2017 | Simpson Washing Machines
I have Simpson eziset 350 dryer can I get the manual
Try Googling (simpson)(350)(manual) without parens.
Apr 24, 2017 | Simpson Washing Machines
Simpson eziset 550 leaves orangey marks on clothing after washing cycle completed
Orangey marks might be rust . possibly from the water or the machine . we can not see it from here . have a local tech look at it .
Feb 13, 2017 | Simpson Washing Machines
Simpson eziset 550 stops at rinse cycle, light flashing
I had the same problem before, but removing the kink in drain hose does the trick. Maybe yours is more complicated but try it.
Aug 28, 2012 | Washing Machines
Simpson eziset 750 manual
Hi our eziset 750 simpson washing machine has stopped working. It randomly just turns off and then will start again few days later. Cheers
Aug 28, 2010 | Washing Machines
Simpson eziset 800 clothes tangle when washing
If you can use a lollipop stick to operate the lid switch while you leave the lid open, you will be able to observe if the agitator is going smoothly back and forth EVENLY or not. If it is tending to turn just one way....this will tangle the clothing like mad!
If this is the problem it could be the switching module or capacitor that needs replacing.
Oct 25, 2009 | Washing Machines
MANUAL FOR SIMPSON EZILOAD 5.5KG WASHING MACHINE TYPE NO R611364
I've seen one for $10 so if it's acceptable for you just let me know
Jul 22, 2009 | Washing Machines
Clothes dryer stops
Jan 30, 2009 | Dryers
Dryers Logo
89 people viewed this question
Top Dryers Experts
Marvin
Marvin
