Question about Miele Vacuums
How do you get a miele dog and cat tt5000 hover apart to repair it
reddevil6
  • 1673 Answers
SOURCE: My Miele cat & dog
Will it power up without the hose attached? If it does then you have a clogged hose. If not, there is a circuit board by the motor that may be bad.
Posted on Mar 22, 2008
  • 389 Answers
SOURCE: Is it possible to make
Sorry, but the short answer is: no!
Posted on May 01, 2009
  • 112 Answers
SOURCE: My almost new miele Dog and Cat vac keeps telling
Remove the hose and check the suction. It it is still bad check to see if the canister is closing on the bag. Most likely the hepa filter needs replaced. Here http://www.totalvac.com/mielevacuumcleanerfilters.htm
Posted on Aug 12, 2009
  • 324 Answers
SOURCE: My husband uses talcum powder liberally and we
You can build a homemade soot trap like what oil burner service reps use. Please refer to the drawing. You start with a widely availabe bucket with an airtight lid (Home Depot sells one in their trademark orange color for example). Along with the bucket, you will need about 30 inches of PVC pipe - ideally you will get the diameter that matches your vacuum cleaner hose attachment. "Schedule 40" PVC pipe will work fine. This refers to the less expensive thickness of pipe- any home improvement store rep can help you with this, and if you bring in your hose and explain what you need to do they will gladly help you out! Finally, you will need a tube of silicone RTV sealant. Cut two holes matching the size of your PVC pipe into the lid of your bucket, and cut the pipe into two sections- one that will sit three to four inches from the bottom of the bucket, and one that will sit one or two inches below the lid. Put them into position and use the RTV sealant to hold them in place and also provide an air-tight seal. On the lid, label the side that has the long pipe INLET and the side with the short pipe TO VACUUM. This is CRITICAL so make sure you do it! Labels, paint, marker, crayon- whatever. Label them NOW!
Finally, you need a section of flexible plastic hose to connect your trap to your vacuum. Six to eight feet should work fine. You will have to be creative to make sure the connection between your new trap and vacuum are air-tight, but IMHO this adds a little adventure to the project... you want something easy to attach and remove, and by no means do you want to do anything that prevents you from taking your new trap off and using your vacuum normally. Hardware stores are bursting with all sorts of adapters and stuff! The same goes for the inlet side of your trap, but hopefully you matched the pipe up to your pickup hose to where it makes a nice tight fit and works without adapters.
After the RTV cures (about 24 hours) and you are satisfied that everything is in order, you are ready to use your soot/dust/fur trap! Fill the bucket about 1/3rd of the way up with water. Make sure that the long end of pipe is under water by about 2 inches. It is VERY IMPORTANT that the end that goes underwater (The INLET) is hooked to your pick-up attachment.... You should have labeled it INLET already.
The whole idea is that whatever your vacuum sucks up gets pulled underwater first, trapping it before it gets near the vacuum cleaner. It has worked for decades for oil burner service techs to keep furnace soot out of their vacuums, which would be destroyed after one or two uses otherwise.This will easily trap dog hair and talcum powder. Be forewarned that inside the bucket it will get very messy and it is vital that you clean it after every use.
Good Luck!
Posted on Mar 20, 2011
rockmeister
  • 2047 Answers
SOURCE: Miele Cat & Dog Cleaner
This unit comes with a silence setting in the system. As a result of your taking the unit apart you might have come in contact with this setting and tampered it. The silence setting combines the lowest noise output with the ideal power level for optimum cleaning results. This setting usually becomes activated when you switch the unit to energy saver mode.
Although with the 2200W of power which the motor boasts of if during your re-assembly you didnt cover the unit well this could have also brought about a discrepancy in the noise reduction method which the unit was assembled originally.
As you said there is no problem with your unit as it works excellently but the manner in which you re-assembled it has a space which allows the engine noise out and this is the problem why the unit has become so noisy.
Hope this support has been helpful?
Thank you for visiting Fixya.
Posted on Jul 17, 2011
How can I fix my Miele cat and dog vacuum cleaner. The electric lead will not stay out it keeps wanting to rewind. What can I do?
I think this model is a canister. If it is you might have broken the retractor reel from its bracket. Unfortunately it has to be taken apart and the part checked. Unless you are familiar with taking these apart you will need to bring it to a Miele dealer to have it looked at.
Mar 03, 2015 | Miele Vacuums
Miele upright dog and cat vacuum clogs easily and won't pick up pet hair
could be as simple as a broken belt or a clogged hose run a broomhandle through it or a plummers snake also check filters for dirt
Jan 05, 2014 | Miele Vacuums
Miele 5000 cat and dog power cord will not retract
Hi There,
I have made a video showing how to get a miele S5311 apart. Most of the machines in the same series use a very similar procedure so take a look at the video it should help you.
Mar 13, 2013 | Miele Vacuums
Miele S5000 Cat & DoG - I need to access the motor housing because it sound like there is something flapping in there
Hi There,
You are probably missing the screw under the circuit board or filter assembly. THe miele S5311 is pretty similar and I have made a video showing how to pull it apart. Hope it helps - Alec
Feb 23, 2013 | Miele Vacuums
My Miele cat & dog
Mar 22, 2008 | Miele CatAndDog700 Bagged Canister Vacuum
Miele Cat & Dog Vacuum
doubt it. could be dangerous to use. (had one burn up due to this)
Apr 23, 2007 | Miele Cat & Dog 326i Bagged Canister...
Vacuums Logo
42 people viewed this question
Top Miele Vacuums Experts
Mack Baxter
Colin Stickland
Colin Stickland
Are you a Miele Vacuum Expert? Answer questions, earn points and help others
