Question about LG 24 in. LDS 5811 Built-in Dishwasher
Dishes not clean
It seems we have a problem...Bottom wash blade rotates but middle and top blade do not rotate (ran dishwasher multiple times) no visible clog seems to be evident as I have removed both and checked for clogs. Thanks
  • 489 Answers
One of 2 things is wrong.  Either the direction solenoid has failed is not cycling the water between the upper and lower wash blades or the control board that controls it has failed.  You will need a qualified LG technician to diagnose and repair the problem.
Posted on Jun 26, 2008
GLD5900N00WW
You need to remove the top wash arm and check for any blockages in the holes, clean them out and make sure the arm spins freely.
Mar 06, 2012 | Dishwashers
Firgidaire dishwasher MODEL FDB641RJSB leaves cloudy residue on dishes. Top spin arm does not seem to be rotating,
First perform a vinegar cycle wash in the dishwasher. Pour a cup of vinegar into the bottom of the dishwasher. Keep the temperature at the highest setting possible and perform a wash cycle.Then start using a dishwasher most probably that would solve the problem. If this does not solve the problem then there must be some parts worn out or faulty creating the problem.
There are many probable causes of failure .
To clean the dishes the water temperature is essential.It the water is not hot then the dishes will not be cleaned properly.So check the water temperature.
Also check the filter in your dishwasher.Clean the filter if there is accumulation of debris in the filter
If you are in an hard water zone , then try reducing the amount of detergent used and then try cleaning the dishes
Feb 01, 2011 | Frigidaire FDB125RH Dishwasher
Seems like the jet arms are not rotating dishes are not getting clean
Check with hand for free rotation. If OK the water pump is not getting ON or the pump is not developing pressure.
Sep 14, 2010 | KitchenAid 24 in. KUDP01IL - Multiple...
Soap not fully rinsed from dishes, maytag quiet series 300
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
Dishwasher Residue and Film on Dishes
heatman101
Mar 12, 2010 | KitchenAid 24 in. KUDI01IL - Multiple...
My maytag mdb8600aws jet clean 2 only cleans dishes in bottom
The seals that the racks "plug" into need replaced. Ours had the same issue and replaced the seals and it works fine now.
Nov 23, 2009 | Maytag 24 in. MDB8600AW Jetclean II...
SHU43C06UC dishwasher cleans dishes on bottom rack but leaves dishes on top rack dirty
your top spray arm is blocked and not rotating,remove it from top basket and thoroughly clean it paying particular attention to the holes right at the ends these are angled to drive the arms round if they block up the arms will not rotate.
Nov 06, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
The rotating piece on the bottom of my Amana QT is not rotating
check that the upper and lower spray arm nozzles are not clogged with particles if they are remove them a nd clean them out also see if there is a screen in the bottom of dishwasher under lower rack clean it out if you can also purchase a bottle of dishwasher cleaner from your local supermarket use it in a empty dishwasher first run tap closest to machine to make sure water is hot red directions on bottle it works very well and dishes will come out much cleaner also use a good gel like electra sol dihwasher gel
Jul 21, 2009 | Amana 24 in. ADW862EAS Dishwasher
Wash Arms not spinning --Dishes not clean
Without the model number of your Maytag number, I can not determine if when you order a wash pump motor you also get the impeller.
Sounds like you are on the right path to getting your dishwasher to wash dishes again.
Oh, while you have the dishwasher open, check that the heating element has not failed using a Multimeter.
Good Luck!
Feb 01, 2009 | KitchenAid 24 in. KUDI02IRBS Stainless...
GE GSD2200G02CC dishwasher
Your dishwasher probably has rotating blades on the top and bottom that spray water on the dishes.  Clean these off and make sure the holes are not clogged.
Sep 14, 2006 | GE GSD2200Z Dishwasher
LG 24 in. LDS 5811 Built-in Dishwasher Logo
115 people viewed this question
Top LG Dishwashers Experts
Mike
Mike
Mike
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
