Question about HP LaserJet 4730 MFP Printer
I have problem in alige colors it mixing the color in very bad way
  • 85 Answers
REMOVE CARTRIDGES OUTSIDE, ALSO contacts clean with a soft cloth EASY CLEAN BELT turning smoothly
Posted on Feb 24, 2011
Why does my ge washer model wvsr1060g2ww not work when i select to wash whites, but works when i select to wash colors?
colors uses a cold water cycle and whites use a hot water cycle so you may have a bad water inlet valve where the the hot water coil has went bad or is clogged with debris? u can check it with a meter for OHMS and for 120 volts both test are important. MACHINE MUST BE PLUGGED IN WHEN DOING VOLT TEST SO BE VERY CAREFUL AND TRY TO USE ALIGATOR CLIPS ON UR METER
May 17, 2015 | GE Washing Machines
Problem with color alignment on DocuColor 1632
Below is a link to the user manual, the aligment procedure should be in there. Xerox DocuColor 1632 User Manual
Jun 16, 2017 | Xerox DocuColor 1632 Laser Printer
How to stop printing test page every time I turn on my printer
This is an aligment page.When printer print the page just follow the instruction on page put it on the scanner glass and finish the aligment.If your color or/and black cartridge is empty or clogged the aligment is not compete and printer will print this page every time when you turning it on.If your case is that just replace the cartridge and finish the aligment.
Nov 04, 2009 | HP PSC 1410v All-in-One Printer
HP photosmart C4200 - alignment disable
I've run into this problem. The first simple thing to look at is the aligment page itself. Does it have colors on it or is it strictly greyscale/black and white? If your color cartridge is empty/a knockoff/not installed correctly, the printer will just print the alignment page in black/white and not necessarily notify you of a problem. However, the cartridges won't align if the aligment page isn't printed in color.
This is clearly a screw-up by HP, because there is nothing to notify you of this problem in the software or manual. The printer will automatically print an aligment page, and then tell you to scan it. If they did it right there would be some error message notifying the user that it couldn't print an aligment page rather than print one that is worse than useless.
Sep 03, 2009 | Office Equipment & Supplies
Print cartridge aligment faild
That usually happens when one or more colors is missing, you need to do a printhead cleaning and test print to make sure all the colors work, when yellow or black is missing it will always fail.
Aug 28, 2009 | HP OfficeJet 7410 All-In-One InkJet...
Top and bottom mis aligment and color ribbon
If the picture is curved on the top / bottom and looks like a "rainbow", the convergence amps need to be replaced.
Jun 13, 2009 | Sony KP-51WS510 51" Rear Projection...
My jvc-hd52g886 has a bad picture where black shld appers it is over lapped with red bloches
A projection tv that has color issues is usually due to bad ballast which is attached to color wheel which you should also look at to make sure the colors are not mixed together and wheel is not warped.
May 10, 2009 | JVC Televison & Video
Rca color problem
Please post the model number of your set and i will post a link where you can get what you need plus free instructions on how to do the repair yourself and save a few hundred dollars.
Apr 26, 2008 | Televison & Video
HP LaserJet 4730 MFP Printer Logo
85 people viewed this question
Seeker5211
Seeker5211
