Question about Select Brands Mirage DR-B500E True 500 watt Silent Aluminum PC Switching Power Supply with LED Light&2 Fan -Brand ... (SPR500WMIR) Power Supply
I HAVE A MIRAGE MODEL NO. DR-B500E ATK 500W SWITCHING POWER SUPPLYIN MY COMPUTER AND IT HAS STOPPED OPERATING. I HAVE TRIED DIFFERENT POWER POINTS AND DIFFERENT POWER CORDS BUT THERE IS STILL NO POWER TO THE COMPUTER. i HAVE NOW TESTED THE POWER SUPPLY WITH A MULTIMETER AND IT CONFIRMS THAT POWER IS GOING INTO THE SUPPLY BUT NOT COMMING OUT. CAN THE SUPPLY BE REPAIRED OR WILL IT HAVE TO BE REPLACED COMPLETELY AND WHAT WOULD A ROUGH ESTIMATE OF THE COST BE THANK YOU DENNIS HAWKES
  • 32,281 Answers
I recommend you replace the switch mode power supply. These power supplies have dangerous mains voltage inside the unit and you should not try to repair if you do not have electronic knowledge.
The cost of a 500 W ATX power supply should be approx. $100.
It is not difficult to swap out the power supply, make sure you have the power connectors are the same as the old power supply.
Posted on Nov 08, 2010
2007 ATK dirt bike no spark
Hi, Ken and the usual suspects are:
1. Fouled spark plugs.
2. Severely discharged or a damaged battery, should have 12.5 volts or better and be able to pass a load test if necessary.
3. Check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
4. Loose connection at ignition coil or plug between ignition sensor and CDI box.
5. Spark plug cables in bad condition, shorting / leaking, spark plug cable connections loose, check for spark leakage in the dark.
6. Faulty ignition coil, pick up coil, trigger coil or CDI box testing needs to be checked with an ohmmeter at 70 degrees Fahrenheit
7. Faulty safety switches clutch, kickstand, neutral, off/on etc.
8. Faulty ignition switch.
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
ATK Rider Forum View topic 260 is getting no spark
How to fix No Spark Problem on Motorcycles and Dirt Bikes
ATK Rider Forum View topic No Spark 2000 ATK 250LQ questions and...
How to test motorcycle CDI box ignition coil
ATK Rider Forum View topic Copies of 1988 ATK 406 Owners Manual
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Nov 12, 2016 | ATK Motorcycles
Auxiliary power points in center console stopped working.
If you are getting power to the fuse, I would check continuity from the fuse to the port itself. Personally, I would check every fuse you have to ensure you are getting power to the left and right of the fuse with the KOEO. It may be running though a different fuse than you expect. It should run through the wires and fuse marked accessory or CIG LGT.
98% of the time it is a fuse, so I am surprised that is not it.
Also check your ground coming from the port.
Are you having any other electrical problems?
here is a rundown of your electrical system
2013 focus all models except smart key
Topic 2013 focus se hatchback remote starter
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gregg_27a4d257e54e7920
Feb 04, 2016 | 2014 Ford Focus
Foxconn mobo and Switching power Supply
It could be possible that there are some settings in BIOS that prevent You from booting because as much as the dual PSU is good, it will never give the same electrical current. And when You MB feels the difference, it stops from booting in order to prevent electrical damage.
Oct 01, 2013 | Foxconn Computers & Internet
Hi,my laptop is Asus X42J,the problem is the Fn key,don't know why Fn + F11 and Fn + F12 cant set the sound volume,before still can...not only this 2 key,Fn+V and Fn +C also fuctionless ...but Fn + F1 and...
Hello there. Follow my steps:
  1. Go to support.asus.com
  2. Select "Download" (if you don't see a "Download" button due to being in another language, select the last item from the main menu and select "English)
  3. Find your laptop model using the wizard
  4. Select your operating system (to determine whether if it's a 32bit/64bit, go to your start menu > right click on "Computer" for Windows Vista/7 or "My computer" for Windows XP and look for a text which says "XX bit operating system)
  5. Go to the "ATK" tree
  6. Download the "ATK Hotkey Utility" thingy and install it.
Mar 16, 2011 | ASUS Computers & Internet
Computer won't turn on
youb can use a 845 series board for it...
if you want to spent more money then purchase any pro. series ofmb remember that there should a ide slot...;
Jul 25, 2010 | ASUS P4S800-MX Motherboard
HP PSC 1210 is not switching on
there is fuse in side the printer in power part ,its broke down then it must be open it and check with the power supply in side it .
Jan 11, 2009 | HP PSC 1210 All-In-One InkJet Printer
Static Timing
My initial guess is that you have TCI or CDI ignition. Basically theres no way to manually adjust timing. It either works or doesn't.touch problem take it to a mechanic,
Nov 10, 2008 | 2004 ATK 620 Intimidator
Atk 0110 acpi utility error
try disabling the power saving features at the BIOS startup screen. this is an ACPI (advanced configuration power interface) error. I think that Windows does not like the BIOS settings so it just errors out.
Nov 05, 2007 | ASUS P5VD2-MX SE Motherboard
KV7-V power supply
follow the power cable from the PSU to the motherboard and see if the 21 connection has melted to the motherboard. You are better getting a 500W silent type, but it depends on the peripherals you have installed, try www.ebuyer.com for various makes.
Oct 09, 2007 | Abit KV7-V Motherboard
Computers & Internet Logo
350 people viewed this question
Top Select Brands Computers & Internet Experts
Alun Cox
k24674
Are you a Select Brands Computer and Internet Expert? Answer questions, earn points and help others
