Question about Sigma 75-300mm f/4-5.6 DL Lens for Nikon AI
Camera lens Is it possible to use my Sigma 75-300 mm lens with my Canon Rebel XTI?
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 480 Answers
Hey kgconstruct,
The lens description that your posting is categorized under is a 75-300 f/4-506 DL lens for Nikon AI. If this is correct then no this lens won't work on a Canon camera. I am assuming this isn't correct and the lens you have is for a Canon camera, and if this is true this lens should work on the XTI. If you’re thinking of buying this lens I would go to a local camera store that carries this Sigma lens and try it out first to make sure you like it. I hope this helps!
Sincerely,
Allan
Go Ahead. Use Us.
Posted on Jun 18, 2008
Does Sigma 70-300mm f/4-5.6 DG Macro Telephoto Zoom Lens fit canon eos rebel
Sigma makes their lenses with a variety of camera mounts. If you get the lens with a Canon mount then yes, it will fit any EOS Rebel camera body. A lens with a Pentax mount, for example, will not fit a Canon camera.
Nov 24, 2012 | Sigma AF 70-300mm f/4.0-5.6 DL Macro Super...
1000d error code 1
user manual say its a communication problem between the camera and lens. The suggested solution is to clean the contacts.
Jan 18, 2011 | Canon EOS Digital Rebel XS / 1000D IS...
Will Sigma 75-300 f/4-5.6 DL work on my rebel XTi
If the lens has a Nikon mount (as you imply in the post), then no, it will not fit. If it has a Canon mount, then yes, it will work fine on your Canon Rebel.
Jun 28, 2010 | Sigma 75-300mm f/4-5.6 DL Lens for Nikon...
I want to fit a 58 mm filter to a 52 mm camera lens how to go about it
Buy a 58mm to 52mm step down ring. They're readily available on eBay.
Sep 09, 2009 | Canon EOS 400D / Rebel XTi Digital Camera
Autofocus gives erratic results
Are you using this indoors, in low light perhaps? This would be the most common reason for this happening. The only way to get around that is to use a "faster" lens, such as f2.8 / f1.8 / f1.4 etc.
If not, try cleaning the lens and camea contacts with a plastic eraser, make sure no debris falls in the camera body (hold upside down for this).
Jun 02, 2009 | Canon EOS Digital Rebel XTI Digital Camera
Sigma 70-300 AF lense
if the lens is the older type with a macro switch which has 2 screws holding it on to the lens it will not work.If it a super 70-300 you can put the camer on AV set iris to F22 if you have a stopdown button see if the lens stops down it ok if noe it will need a rechip or a new interuper
Sep 27, 2008 | Sigma AF 70-300mm f/4.0-5.6 DL Macro Super...
Sigma 70-300 mm lens wont focus
I was focusing to close to the subject & too much glare from a church window.
Sep 26, 2008 | Sigma AF 70-300mm f/4.0-5.6 DL Macro Super...
Lens Compatibility
The XTi does not have a "full-frame" sensor, so vignetting should not be a problem with this lens.
Jan 29, 2008 | Sigma Cameras
Tamron lens for Xti?
if it is an auto focus lens that works on one eos camera, it should work on almost all of them. the only known exception is that some high end extenders will not fit the eos1dmarkII as it protrudes into the opening too far.
but a good rule is that if it fits without any obstruction issues, it should work. try cleaning contacts on the lens and camera body. if that doesn't fix it, talk to Tamron. you can use it manually, but will not be as easy and you would get less predictable results.
my suggestion is to always go with lens from camera maker.
sounds like there is an issue with the tamron lens. not the camera.
good luck
mark
Dec 16, 2007 | Canon EOS 400D / Rebel XTi Digital Camera...
Cameras Logo
192 people viewed this question
Top Sigma Cameras Experts
Steve
Doberman
Are you a Sigma Camera Expert? Answer questions, earn points and help others
