Hi, I have a problem with my aiwa ca-dw550 cd portable audio. After a cd is insert, I can hear the motor spin trying to start but after aprox. 20 sec. its stopping, and the CD is not playing. Can you help me?
techman
  • 3130 Answers
SOURCE: lifestyle 12 by Bose
No sound ? Make sure the audio input cable is connected to the music center FIXED outputs, the black connector is fully seated in the music center SYSTEM CONTROL 1 jack, and the multi-pin connector is firmly seated in the Acoustimass module jack. ? Turn the music center off for ten seconds, then on again, to reestablish communication between the music center and the speakers. ? Check the connections for any external components. Make sure to select the correct source for the desired input. ? Check the speaker connections. ? Be sure the CD is placed correctly, label-side up, in the music center, and the cover is closed. ? Increase the volume. ? Check to see if MUTE is lit in the display. Press the MUTE button on the remote to unmute the sound. ? Disconnect any headphones. ? Connect the FM and AM antennas , and last but not least. Make sure there is power going to the remote speakers or the unit will not communicate with them. Good Luck
Posted on Jun 14, 2006
maklean
  • 1665 Answers
SOURCE: jvc model ca:d601t cd tray
Hellow have a nice day!
Posted on Mar 09, 2008
robotek
  • 1512 Answers
SOURCE: cd player multi play problem
Hi dav1892
These units are notorious for getting a layer of dust on the CD optics laser focal lens. You need to give it a clean with a cotton bud moistened with Windex, and then a dry wipe to be sure that there is no smearing left. See how that goes, and get back to me here if it does not fix it.
regards
Graeme
Posted on Apr 14, 2008
SOURCE: Check disc
Change your DVD player
Posted on Jun 28, 2008
Pyrhyc
  • 2028 Answers
SOURCE: HP Pavillion not reading audio CD
It is possible that this is a drive issue, I've seen drives that one of the optical reader device has gone out, but generally it'e the DVD reader and will only read CD's. It's very rare that the CD reader goes and the DVD reader works. Before you replace drive, if it's only music CD's (you didn't mention program CD's), then update your media player. If it still won't play, then unistall the media player and completely reload it. At this point you can replacse the drive.
Aiwa nsx-520 cd player discs not spinning
I have not serviced that model or CD players for a long time. Going from general experience I found a number of reasons. There are a fair number of things that can cause this type of fault. My not be simple. An experienced tech who knows CD players, with the service manual and the proper test tools he should be able to find the failure point.
Some things the tech would check for:
The drive motor.
The servo drive circuit.
If when the disk is inserted, and the disk gets a kick spin and then stops, this could be the laser or the laser circuits are not reading the disk.
It can also be something where inadequate power is getting to the servo drive circuits.
Feb 02, 2017 | Aiwa Audio Players & Recorders
Cd wrongly inserted in an AIWA CA-DW935M is stuck in the cd player, wants to get it ejected
I was able to find the manual for that model, which included a series of tests for the CD trays. Perhaps if you ran through them you will be able to get your CD out. If not, please ask for additional help.
AIWA CA DW935M Service Manual free download schematics eeprom repair...
Feb 09, 2014 | Audio Players & Recorders
Wrongly inserted cd in an AIWA CA-935M
Ye Gods! That's the problem with all-in-one systems.
You will have to take the cover off the CD and pull the CD out by hand.
My aiwa cd disc rotating tray is not working i don,t know what's wrong with it
hi there i know wht is problem rotary changer systems like 5 disic or 3 dics chnager.i have 2 oprions for that 1 is,from cd chnager belt small belt between motor another also mechanism like small tears lack white if there not good oily enaugh,maybe stock with tooth,DO u hear motor when u tray chnage disc 1;2;3? if motor burn rotary change then never will work,Some times belts getting older in cd rotary changers.the gey slepery,like flashy,but i hope will help your problem.Regards,Emil
Sep 13, 2012 | Aiwa NSX-DS55 CD Shelf System
3-cd drawer opened (aiwa cx na 777) and my brand new Iron Maiden CD dropped inside of the unit below the disc spin device (motor shaft and hub?), now I'm afraid to close the drawer. I want to take it apart...
Hello
You have to open the unit to take the CD out of it. If you can, do this. If you are not able to doe this work, contact the nearest authorsed service center for Aiwa at your town. Aiwa is not a brand in market now, as Sony Corporation has purchased Aiwa. so it will be best to contact the Sony Authorised Service center at your town. OK.
Sep 01, 2010 | Aiwa NSX-A777 Shelf System
Hi! I have a problem for reading CDs with an aiwa hifi system
the spindle motor goes bad a lot on these aiwa cd unit
May 12, 2010 | Aiwa NSX-DS55 CD Shelf System
Remove speakers from Aiwa CA-DW630 boombox
They may be heldin by the handle, or tabs that you either need to push or pull on the sides or bottom of the unit.;
Jun 23, 2009 | Aiwa CA-DW530 Cassette/CD Boombox
Aiwa CA-DW535
optical lazor fulty and the controler thattriggers it and cheak cable connecting it if u can get in it otherwise cd rom bad ther go bad after 2 3 yrs on these ones
Feb 03, 2008 | Aiwa CA-DW535 Boombox
116 people viewed this question
 Grubhead
Grubhead
Marvin
Marvin
