Question about Garmin nuvi 1350 Car GPS Receiver
Some how the my Garmin 1350 says: "Cannot unlock
  • 1,514 Answers
The solution is at http://www.fixya.com/support/r6197735-no_detailed_maps_found_support_routing
You may be able to skip step 1 if it doesn't say "No detailed maps found that support routing" but the rest of the solution will be the same.
Posted on Nov 08, 2010
Garmin nuvi 1350 map cannot update
may have to download plugin, garmin communicator off my.garmin.com
Nov 06, 2013 | Garmin nuvi 1350 Car GPS Receiver
How can I update lifetime maps to 1350
Contact Garmin directly---I have seen this many times on several brands, it means they are available but may not end up being free.
Dec 04, 2012 | Garmin nuvi 1350 Car GPS Receiver
Garmin 1350 freezes during operation on
its not the maps that cause this but the updated device software, try makin sure the software is up to date, as Garmin will be adding satelittes all the time so its to make sure that the device can track them
Oct 03, 2012 | Garmin Nuvi 1350LMT
Garmin Nuvi 1350 showing on screen "no map data available"
Shut off the nuvi.
Remove any memory card (if equipped) from your nuvi.
Plug the GPS into your computer via USB cable.
Open the Garmin "drive" icon in "My Computer"
Navigate to the x:/Garmin directory or "folder" (where "x:" is the drive letter assigned to your Garmin). Locate either map files set(s) named: gmapsupp.img or gmapprom.img.
Some units store map files in the hidden x:/.System directory instead. To view the .System folder and contents, you must direct your computer to display both the "system" and "hidden" files.
If you lack large files named either gmapsupp.img or gmapprom.img (about 1 GB or more); your maps are missing from the internal memory of the nuvi and will need to be reloaded.
If you pulled a memory card above, reinsert it and check the directories for the same gmapsupp.img or gmapprom.img files. If they're not present there, the maps should be reloaded.
I hope this helps
Sep 15, 2011 | Garmin nuvi 1350 Car GPS Receiver
My new Garmin Nuvi 1350T. When I try to enter an address for "where to?" I'm told "No Map Data Available" It was working fine for the past several days.
Most likely the problem is that the map has become unselected. You can find how to select the map at http://www.fixya.com/support/r6197735-no_detailed_maps_found_support_routing. There's more information there than you need so you can jump straight to paragraph 5, near the bottom of the page, to find what you need.
If this doesn't solve the problem the may may be locked. You can also find information on unlocking the map at the same link starting at paragraph 2.
May 29, 2011 | Garmin nuvi 1350 Car GPS Receiver
I got a garmin nuvi, i click where to or maps, it says no data avaible
It's possible that the maps have become unselected or locked.
You can find details of how to select your maps and how to unlock them at http://www.fixya.com/support/r6197735-no_detailed_maps_found_support_routing
There may be more information there than you need. Start at paragraph 5 to select your maps. If you need to unlock them start at paragraph 2.
May 27, 2011 | Garmin nuvi 1350 Car GPS Receiver
I have a 1350LMT Garmin that I want to register for free map updates. Mine has free map updates for as long as I own it. Thanks.
You will need to go to Garmins Official website the link to the site is here either click on the link or copy and paste it into your web browser:
www.garmin.com
Look at the top right hand corner of that page where it says My Garmin click on that and create a new user account from there you can do your map updates or whatever you would like.
I hope this helps you out if it did please leave a Yes I was helped. Thank you.
Apr 05, 2011 | Garmin nuvi 1350 Car GPS Receiver
I have 2 Garmin (205W and new 255W). I downloaded the new map update to my PC, and installed the maps onto my 255W. When I turned it on, all seemed well, but after I passed the safety screen, I got the...
It should unlock automatically.
Try reconnecting your device to computer and going onto the garmin site and get the website to check for updates.
If that fails to work, give garmin a call or send an email to them.
they are normally very quick.
Please dont forget to vote if you liked my answer
thanks
Feb 09, 2011 | Garmin Nuvi 255 GPS Receiver
I for got my password on my garmin nuvi 1350 how do i get it to unlock???????
I've been trawling for unanswered questions; this information may be too late for you (or perhaps it may help you resurrect a useless machine which you have put away) but it will certainly help others searching for advice with the same problem.
You have Garmin Lock activated on your nuvi: there are only two ways you can unlock it.
1. Enter the PIN code (but you clearly don't have it or you wouldn't be reading this).
2. Take the unit to the Security Location you chose when activating Garmin Lock: it will then unlock without the PIN code and you can then either reset the PIN or disable Garmin Lock. The Security Location should not be the owner's home address, but many owners ignore this recommendation. Many owners choose their workplace or a close friend or relatives address for this purpose.
If neither option works then your unit is useless unless you send it to Garmin with proof of purchase. Garmin charge for the service and if your maps are not up to date then it's really a waste of money as the investment would be better spent on a new unit with current mapping.
I hope that you manage to either fix your problem using my advice or at least can decide whether to abandon the unit and buy another.
Mar 06, 2010 | Garmin nuvi 1350 Car GPS Receiver
Garmin nuvi 1350 Car GPS Receiver Logo
703 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
