Question about Philips Televison & Video
Philips universal rermote codes
Cant find it a 3 devices
    Novelist:
  • 97 Answers
Http://www.remotecodelist.com/remotes/magnavox/Philips-Magnavox_PM525S.pdf
This is the user's manual for a Phillips remote control. There is a list of codes in it. They should be rather universal. There's also instructions as to how to program it. I believe that there is a way to program it without using the codes.
Programming with Code Search
1. Manually turn on the device (TV, VCR, etc.) to be controlled.
2. Press and hold Code Search button until the red indicator stays on. Release the Code Search button.
3. Press and release the desired mode button (TV, VCR, etc.). The red indicator blink, then stays lit.
4. Press the Channel Up button repeatedly (up to 300 times) until the device could be controlled changes channel. The red indicator blinks, then stays lit. If you accidentally overshoot the code required, press the Channel Down button to backtrack through the library until the device changes channel. Pressing Channel Up changes direction to forward again. Press and release the Mute button to install the code.
Hope this helps :)
Posted on Jun 21, 2008
What is remote control code for 42 inch vizio tv with phillips universal remote
Your Philips remote is universal so you can use its "code search" feature to find a suitable code. The codes are stored in the remote. If a thorough search does not produce a code, you may have to try another universal remote because not ll codes are stored in all remotes.
Oct 07, 2014 | Philips Phillips SRP1103/27 3-Device...
HOW DO I CHANGE THE MODE ON MY HT-X50 WITH A PHILIPS UNIVERSAL REMOTE
You should have its original remote control to select its inputs. To buy its original remote control, contact the authorized service centre, or authorized dealer to your device brand. They can either give you a genuine remote control to your device, or can direct you, from where can you purchase a suitable one.
To select a proper universal remote control, you should know about the number of digits to its set-up codes. There are 3 digit, 4 digit, 5 digit, 2 digit and even single digit codes, to some brand devices. After confirming this, check the sites linked here. Both the sites have set-up code list and set-up procedure to many popular brand remote controls. Check which brand remote control has set-up code/s to your device brand, and buy that one according to availability. Brand name of the remote control isn't a matter, but it should have set-up codes in its code list, to the device brand you have.
Please note: Every new universal remote control will have set-up code list, and set-up procedure along with its pack. Never accept a remote control, that hasn't both of this. For more details about the set-up codes, visit the sites Check this site too.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Universal remote controls are available at most of the electronic spare part selling shops. Visit some online sites too, which deals with electronic spare parts.
Jan 30, 2014 | Philips Universal PH301S Remote Control
Philips universal remote code for 19 inch sharp TV
Please go to below website you can get the codes to programme your remote.
http://www.urc.philips.com/
Please select the below informations.
1. Location
2. Select your remote
3. On your left side you will have an option called as REMOTE CONTROL CODE FINDER.896948c.jpg
4. Select the device you need to programme and the make of the device you will get the codes for your device.
Thank you
Sep 19, 2010 | Philips Universal PH301S Remote Control
Need to program my tv and dvd player to the remote
Please follow the steps below
Program the First Device by Entering Direct Codes
1.Turn all of your devices off, and then manually turn on the device you want to program.
2.Press the Setup button on your the universal remote and continue to hold it down until the indicator light stops flashing and remains solid.
3.Release the Setup button
4.Press the TV button.
5.Release it immediately and make sure the indicator light is illuminated.
6.Enter the first possible four-digit code on the universal remote, and then press another button on the remote to see if the device is now programmed, such as the volume control or power button.
7.If the device responds, you have successfully programmed your Philips universal remote.
8.If not, turn the device off and back on and follow the steps again using the next code on the list. Repeat until the device successfully responds.
How to Program a Remote Using Code Search
6.Press either the Channel button or the Play button until the device responds. Each time you press the button, the Philips universal remote tries a new code.
7.When the code works, press the Mute button on the Philips universal remote and the code will be stored.
To get the universal remote codes please visit below solution
http://www.fixya.com/support/t5395701-universal_remote_code_phillips
Thanx
Jul 27, 2010 | Philips Universal PH301S Remote Control
I have a philips universal remote i need the code
Please go to below website you can get the codes to programme out remote.
Please follow the below instruction.
1.Location
2.Select your remote
3.On your left side you will have an option called as REMOTE CONTROL CODE FINDER.
4.Select the device you need to programme and the make of the device you will get the codes.
Thanx
Jul 25, 2010 | Philips Universal PH301S Remote Control
Help
http://www.remotecodelist.com/remotes/magnavox/Philips-Magnavox_PM525S.pdf
Hope this helps :)
May 18, 2008 | Philips Universal PH301S Remote Control
Televison & Video Logo
90 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
