Question about Mitsubishi HC3800 1080p Home Theater DLP Projector Projector
Yhe picture on my 3800 has a tendancy to shudder every now and then. it only seems to do this when it is ceiling mounted. any ideas? Cheers! Bryan
    Brigadier General:
  • 8,909 Answers
I should say it has a heating problem. In the uppermost part of rooms, the temperature can get very high.
Check the air vent filters are clean and replace them as required. Make sure the air ways are clear by placing a vacuum cleaner pipe against the air inlets and exhaust outlets to clean them out. That should dislodge any fluff etc.
Hope this fixes your problem.
Posted on Nov 08, 2010
Who made an M52 series ceiling fan? 5 blades, 4 lights
I have a 52" A.C. Ceiling Fan, M52 Series, Fan 82F4, 120V, 60 Hz 1.0A, File No# E143948, TR/HD: 0596, Serial No# 026351-027900, and have had the fan stored for awhile now and it seems I've misplaced/lost, the mounting bracket that fits inside the cover where the stem and ball are located and mounts to the bracket box inside the ceiling. Any ideas of where I can find one so that I don't have to purchase an entire new ceiling fan (again). I've tried 2 ACE Hardware stores, Home Depot and Lowes and no one carries them.
Jan 31, 2012 | Dryers
I have the Panasonic BB-HCM527A Poe Dome Ceiling Mount camera about two years. Lately, the color of the picture turns a little greenish. Can you help?
in your case, it seem that the sensor is already broken. to fix the sensor will be quiet expensive, i suggest you to replace. WV-SC384/WV-SC385 will be a good choice.
Jun 14, 2011 | Panasonic BB-HCM527A Poe Dome Ceiling...
I want to attach a Vivitek 650HD projector to a ceiling mount, but am not sure if I mount it upside down. There doesn't seem to be a "flip" function to flip the picture.
I am 99% sure most projectors are mounted upside down. There should be a way to simply flip the image electronically via the option menu.
In most projector OCD menu (keep in mind you may want to do this before mounting), under the "Installation" or "Initial Installation" section should be an option about Projection mode/method. The options should allow you to pick front, rear, ceiling, or ceiling+rear. This sets the project to know when it will be in front of the screen, behind it, and/or attached to the ceiling (which it knows will be upside down). Then you simply set it to ceiling, mount the projector, and finish your other adjustments as needed.
Apr 27, 2011 | Televison & Video
Car shudders when taking off
If this is a standard transmission, I would bet money that what you are experiencing is clutch chatter. The clutch may still seem to be working ok, but it will definitely get worse. if you have an automatic transmission, please clarify. To get an idea of what a new clutch kit will cost you, please go here And don't forget to visit my blog.
Jul 25, 2010 | 2002 Mazda Miata
How to invert picture when mounting on ceiling
go into your menu and check the box for ceiling mount or something like that.
May 20, 2010 | Office Equipment & Supplies
Infocus X1 lighting problem
Well there are only a couple of things that could cause this problem. However considering this all started when it was mounted consider the possibility you may have used screws that are too long and are is/are subsequently shorting something out.
Cheers
Oct 14, 2008 | Apple InFocus X1 Multimedia Projector
Need to invert the picture--ceiling mounted
The SYSTEM menu provides options for ceiling mount and rear projection. From the main menu, select SYSTEM, move the cursor down to CEILING and then click the SELECT button. That should put a check mark on that option. Then go to PREVIOUS and finally EXIT the menu,
Aug 19, 2008 | InFocus ScreenPlay 4805 Multimedia...
Hitachi projector cp - s210
hi there,
I have just done the exact same thing today. Press menu button on projector. Scroll (navigate) to the mirror option. This give you the options to mirror image left to right or up and down.
This should fix any of your problems.
Cheers
Luke
Feb 03, 2008 | Hitachi CP-S210 Multimedia Projector
Mitsubishi HC3800 1080p Home Theater DLP Projector Projector Logo
91 people viewed this question
Top Mitsubishi Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Mitsubishi Office Equipment and Supply Expert? Answer questions, earn points and help others
