Question about Garden
Looking for manual for DAPC ATK 80 impact wrench hammer grinder air tool kit set
  • 3 Answers
SOURCE: I HAVE A HUSKY AIR IMPACT WRENCH MODEL #H4140 I
http://parts4tools.com/store/page10.html contact these people, they don't actually make the kits but they can get you the repair parts
Posted on Apr 02, 2009
  • 5 Answers
SOURCE: Impact wrench never stops spinning!
you have a bad o-ring at the air inlet
Posted on Apr 25, 2009
john631068
  • 172 Answers
SOURCE: Craftsman 1/2 inch impact wrench,not working
Make sure you have at least 90 pounds of air and if you do you need to oil the wrench air tool oil pour some in the where the air line hooks up ..air tools need to be oiled daily cause compressed air cause water vapors to build up when you use it and then when it sits it begins to rust a bit and the oil stops this ...
Posted on Nov 17, 2009
SOURCE: Need exploded diagram of ingersoll rand Model 8049
Here you go... I needed the same...
http://www.powertoolrepairohio.com/pages.php?pageid=14&breakid=1118
Posted on May 22, 2010
  • 50 Answers
SOURCE: impact wrench is not working
fill down the air pipe wit penatrating oil hold trigger and keep movin forward and reverse wen in frees up fill wit airtool oil
Posted on Aug 10, 2010
On the CP-797, do you put oil in the hammer case?, there is a small plug up front.
Some of the early CP797 used grease, the current models use oil.
To identify your tool look at the front of the hammer case where the anvil is located and look for a seal (item# 115) if it is present then you tool uses oil, the manual states that the tool requires 6 ounces of SAE30 oil use non detergent type.
Follow this link for the owner's manual:
http://etools.cp.com/cpvscatalogue/files/CA155616.pdf
Nov 19, 2013 | Chicago Pneumatic 1" Cp797 Air Impact...
Ingerroll rand 2132g how do I oil my air impact wrench?
Most I.R. impacts require grease in the hammer mechanism (clutch) and oil in the air motor.
To lubricate the air motor simply add oil through the air inlet about 3 to 6 drops at every use.
To lubricate the hammer (clutch) mechanism you will need a grease gun with a needle, the grease fitting (item# 17) is located on the hammer case assembly (item# 15) 2 or 3 small squirts will sufficiently lube the hammer (clutch) mechanism.
With heavy use grease the tool once a month, with light use 2 to 3 times a year.
Follow this link for the parts list, also indicates the grease needed:
http://manualarchive.ingersollrandproducts.com/ir_pdfs/Tools/Vehicle%20Service%20Tools/Air%20Impact%20Tools/80164726_ed4.pdf
Aug 04, 2013 | Impact Husky® 1/2" Wrench
I have a ingersal rand 2141 3/4" impact the hammer frame had broken. It was replaced and
THE IR 2141 HAS A 2 HAMMERS, ON 1 SIDE IT IS FLAT AND ON THE OTHER IS HAS A BEVEL. THE 2 BEVELS HAVE TO FACE AWAY FROM EACH OTHER AND 180 DEGREES OPPOSED (1 UP AND 1 DOWN) IF NOT ORIENTED CORRECTLY IT WILL CAUSE THE MECHANISM TO LOCK. FOLLOW THIS LINK AND LOOK AT ITEM 15.
http://irtechpubs.com/ir_pdfs/Tools/Impact%20Tools/Air%20Impactools/04584009_ed1.PDF
May 01, 2013 | Air Tools & Compressors
Runs but when you try running on a nut it just blows air. should the plates and drum be greased when rebuilt?
The air motor on the 285B needs to be oiled, the hammer section needs to be greased. The symptom described could be in the hammer mechanism, 285B's have 2 different side plates (item# 41) that sit atop the hammer mechanism, tools made from 2005 to 2007 use the old style side plate (item# 41) that has a small lip that need to sit looking toward the hammer case bushing (item# 44) when installed with the small lip facing in to the hammer will cause it to lock, tools made from 2008 to the present have a side plate that is flat on both sides and can be installed in either position. also check the hammer and anvil for cracks and pitting.
Follow this link to view the parts list.
http://manualarchive.ingersollrandproducts.com/ir_pdfs/Tools/Vehicle%20Service%20Tools/Air%20Impact%20Tools/80162944.pdf
Jun 01, 2011 | Ingersoll Rand Ingersoll - Rand 285B - 6...
My cp772h is running low on power. I am unable to loosen bolts that I tightened on lower setting
The biggest problem I have seen with these is the hammer mechanism.Remove the front of the tool and disassemble hammers.Clean them good with solvent and using a paint brush re coat then with a special hammer grease that can be purchased at a local tool repair and supply store.Also check fwd and reverse seals while you have it apart.Check motor veins for wear.Check inlet screen and exhaust for debris.
Oct 19, 2010 | Chicago Pneumatic CP772H - 6 3/4" Heavy...
What sockets fit
Any sockets will fit the ratchet, 3/8 drive, the impact drive is 1/2 drive, and they make hardened sockets for it. And I can't really make out the last tool there in the kit. The impact tool will take normal sockets for reg duty use but not for wheel lugs and such, they will crack, but if you buy Craftsman, they will replace it. I have only cracked one in thirty years. But I also have the hardened set of sockets. Hope this helps.
Jun 25, 2010 | Craftsman Mechanics Air Tool Kit Impact...
I have a nitrocat 1000rg with a broken hammer pin were do i get more?
I have same impact and have had same problem, I got mine from Mac tool distributor that comes to dealership I work at and also purchased sets of new hammer pins from him also, take note that the round cam that hammer pins ride on will get nicked and damaged and take out new hammer pins so watch out for that too.
Feb 22, 2010 | Aircat Nitrocat Xtreme By Impact Wrench...
My CP 734 has no power under load. Is there a rebuild kit to fix this problem and where can I get it? If a kit is available, is that a difficult rebuild? Tim
I used to repair these impacts for a living. Simplest first thing to do is back off the three 1/8" set screws in the back a couple turns. Pour a little varsol into the air inlet and plug it in. run the gun until your hand is black, (wear a glove). Once the varsol stops disconnect the air, add a few drops of air tool oil and tighten the screws slowly and evenly. You will hear the impact rpm increase. If your gun doesn't speed up to it's original scream you will have to remove the four 5/32" set screws and see what's worn. To open it hold the impact by the nose 3" off the table and position a center punch in the hole of the anvil shank with the same hand and hit it with a hammer hard enough to overtake the spring. The guts should drop on to the table in tact. The guts are in twp parts, the hammering mechanism, and the air motor. The three 1/8" screws hold the motor together. You will soon see the problem. Take the back off the air motor and it will show your if the veins are worn. Cjeck the end plates for wear. You can turn the end plates down on a lathe if available. As a rule of thumb, if the anvil shank is dry buy a repair kit, if it's wet, buy a tune-up kit. If the ring on the anvil shank doesn't turn, buy a repair kit and change your sockets. When rebuilding these front seal often leaks. These impacts are supposed to use 30 weight oil, but a mix of Ingersol Rand grease and 30 weight oil, ( just till it's slightly runny) will stay much longer. Assembling the anvil assembly can be tricky until you figure out how to hold the shank and two pins with the same hand. Good luck.
Dec 04, 2009 | Chicago Pneumatic 1/2" Air Impact Wrench
Air wrenches are noisy. Aree all air wrenches equally noisy?
No, by design there is a hammer hitting an anvil inside the tool. There is no way to make that quiet. If you want quiet you will have to use hand tools.
Feb 01, 2009 | Aircat Silent Power 3/4'' Air Impact...
Garden Logo
142 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
