Question about Pioneer SX-205 Receiver
Printer won't print anything new. reverts to old material each time I try to print something else
  • 2,386 Answers
It has some old documents in queue, click on printer in notification area and delete all old jobs given to your printer, hope it will solve you problem..
Posted on Nov 08, 2010
My hp Photosmart 7450 printer was working, then in the middle of printing it stopped and there is an error message on my computer, the green light is blinking on printer but won't print
First things first... try connecting your printer to another pc or laptop and try printing... make sure spooling is on in the driver and there are no other programs running...
if issue reappears then
It sounds like your printer cartridges are the issue
I would try reinstalling them...
if that does not work then
I would try cleaning your printer cartridge...
Gather cleaning supplies:
Clean distilled water. Use bottled or filtered water if distilled water is not available.
Clean cotton swabs or any soft, lint-free material (coffee filters work well).
Remove both cartridges.
Unplug the printer.
Lightly moisten the lint-free cleaning material with clean water.
Clean the cartridge contacts. Avoid touching the nozzles. Replace the cleaning material if it gets dirty.
If that does not work then I would try ordering some new cartridges
hp photosmart 7450 ink cartridges
I’m happy to assist further over the phone at https://www.6ya.com/expert/norman_d2fa496dce30c65d
Sep 12, 2012 | HP Photosmart 7450 InkJet Printer
How to change paper size from computer & not have to physically go to printer
when you are printing something get to the print area and before pressing the print button click on printer properties and then select the paper size from the list available
save then press the print button
it is only good for the job you are printing as the next job , it will revert to the default setting
Apr 14, 2017 | Canon ImageRunner 1025IF Copier with DOC...
Can't print from computer
Reinstall the printer drivers. (completely remove the old ones first)
Try new drivers from HPs website if need be.
Check the print queue in control panel>printers to make sure nothing is lying in the print queue and blocking your printing.
Make sure that you are printing to the correct printer in the "print" dialogue box that pops up when you go file>print. Sometimes this can revert to "microsoft document printing" or somesuchand just save a file on your hard drive instead of printing (in techie speak, printing does not necessarily mean print out on a bit of paper). Or may the "Print" dialogue box wrongly is pointed at another/old printer that still has drivers installed on your pc when it pops up, check before clicking the "ok" button..
If not, try a new cable, if not, call HP.
Feb 05, 2010 | HP PSC 2175 All-In-One InkJet Printer
Epson R230 printer head blocked and not printing well, i am using refill ink
This is probably not the answer you want but it may be time for a new printer. There are usually some bundled troubleshooting wizards with the installation software you could try that if you haven't. You might try performing a head cleaning, printing a test page, and physically inspecting the printer head to see if there is foriegn material adhering to the printer head. I'm not familiar with your model but on my old printer I could switch between color and b/w by switching cartridges if you have an old/alternate cartridge try switching them to see if it goes away if that seems to do the trick toss your bad cartridge and get a new one. Hope that helps.
Oct 23, 2009 | Epson Office Equipment & Supplies
Canon mx 860 will not print from rear tray: gets
From the symptom,seems that another material (broken paper or something else) block the paper path. Observe paper path carefully and remove any material which blocking the paper.
Oct 10, 2009 | Office Equipment & Supplies
Horizontal lines in printing of photo
Hi!
Please check the waste container where the ink cartridges rest. After some time, ink sprayed into this container during cleaning cycles and builds up to form a heap of solid waste material of ink. On getting too high it makes contact with the printer head and drags ink across all printed material which is required to be cleaned out with a small wooden stick or brush.
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
Jul 14, 2009 | Office Equipment & Supplies
Ricoh SP C410dn Paper only prints 11cm and stops in the Bypass T
do not use ohp film in this device as it will jam due to the use of optical paper sensors unless your ohp has a paper backing. you can set up the bypass tray for thick paper type to increase fuser temp to get better fusing etc
Jul 08, 2009 | Ricoh Aficio SP C410DN Laser Printer
Printer keeps on jamming paper
Dear all,
I will try to help you. Paper jam error may be caused by some possibilities. So, please notice this indication:
  • If the printer status is READY immediately after Power ON then Paper Jam Error message appears while feeding the paper: Sheet Feeder Unit is faulty or any other material (such as broken paper) present inside paper path blocking paper end to reach paper feed sensor.
  • If Paper Jam Error messages appears immediately after Power ON: Paper feed sensor or logic board is faulty
Corrective action:
  • Remove the material from paper path
  • Replace Sheet Feeder Unit
  • Replace Paper Feed Sensor / Logic Board
Please rate me as Fixya if you find this useful for you. Thanks.
Source:
Canon Inkjet Printer Forum
Re
Sep 01, 2008 | Canon Pixma iP2600 Photo InkJet Printer
PRINTING
tray a clean nozzle and alignment from printer manager, first..that might need to be done a few times
Apr 26, 2008 | Lexmark X1270 All-In-One InkJet Printer
Pioneer SX-205 Receiver Logo
48 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
Ian Summerfield
Ian Summerfield
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
