How to test a hard drive to check controller cannot load or format mine or from cd and do not have boot disk can you help
    Genius:
  • 1,672 Answers
What is ur OS and board? Upon starting click on "del" to go to BiOS and go "BOOT" sequence, choose CD ROM as ur 1st boot sequence! Exit w/ save changes! Now ur ready to install a new Windows OS, insert a OS cd and re start ur desktop! upon starting "START CD ROM" click on "enter"! Let ur windows do everything and follow the instructions!
Taaa!
Posted on Nov 08, 2010
Ex. hard drive will not open windows say windows will not even formate
If windows will not format the hard drive then the HDD is probably bad. Depending on the operating system you're trying to load, if it's Win XP or earlier you can still use DOS to format the drive then try loading windows onto the drive. Windows will want to format the drive again when you load the disk and that's ok because it will format the disk from FAT32 to NTFS. If it still fails then You more than likely have a bad disk that cannot be written to. One other thing you can try is to boot to command prompt and type in sfc /scannow Make sure you have windows inserted in CD drive. This will check your system if Windows is already loaded on the drive but you're having a hard time booting to it. Hope this helps
Oct 29, 2013 | Computers & Internet
I was using a 500mb conner hard disk but now 4.5gb seagate hard disk but can't format it
you have to format your hard drive using a third party disc to erase everything on your hard drive
Restart your computer during the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS the scroll down to advanced bios features press enter change your first boot device to cd,press escape then press f10 to save to cmos to restart
note this will erase you operating system you will have to have an operating system disk to load it onto you hard drive or create a partition to load another operating systemor if you are trying to format a usb drive
insert your pen drive
click start click on my computer you should see your pen drive
right click then select format
another way is to control panel administrive tools,computer management disk management right click on your drive select format
hope this helps
Mar 27, 2012 | Computers & Internet
Format hard dirve
you would either format or delete all of the data from this drive if it has an operating system on it you would format it
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS the scroll to advanced bios features press enter change your first boot device to cd,press escape then press f10 to save to cmos restart
note after you have loaded the operating system you should go back and change the first boot device to failsafe or optimised defaults
after windows has loaded
your computer will automatically restart it might restart 2 times one to finish the installation
the next will be because the operating system is loaded and will boot from your cd
Press and hold that key during the boot up process to enter BIOS using the arrow keys load failsafe defaults or load optimized defaults press escape then press f10 to save to cmos to restart
The BIOS is AMI. Under ADVANCED SETUP:
The options listed for 1st,2nd ,3rd Boot device include:
IDE0 means Pri master
IDE1 means Pri slave
IDE2 means Sec master
IDE3 means Sec slave
or if you are using a USB
insert your usb drive
click start right click on my computer select open you should see your USB drive
hope this helps you
Oct 12, 2011 | Sony VAIO PCG-505 PCG-671L PCG-700...
Can we format pc by usb drive
note after you have loaded the operating system you should go back and change the first boot device to your hard drive
if you need more help with this post a reply
hope this helps
Aug 24, 2011 | HP 419320-001 - HP Pavilion dv4000 Series...
I am unable to format my 40 GB Hard Disk (samsung) with WinXP Installation CD. After Doing Patition and format it comes unable to format
(note after you have loaded the operating system you should go back and change the first boot device to your hard drive)
hope this helps
Aug 06, 2011 | Samsung (SP0411N) 40 GB Hard Drive
How to format N 2600c 2 and what is its code
cmos to restart
(note after you have loaded the operating system you must go back and change the first boot device to your hard drive)
hope this helps
Jun 16, 2011 | Computers & Internet
How do i format my laptop off of the partition on the hard drive. I've managed to hit f 10 and get into the bios but no format option was given
Formatting the hard drive is not a function of the BIOS. You will need to boot the machine from either the Windows CD and do a fresh setup (which will give you the option to format the hard drive) or boot from a bootable CD or floppy disk that has the format command on it. From there you execute the format command and follow the directions.
Jan 05, 2010 | Sony VAIO Notebook
New 160 gig hard drive, can't load XP on Fujitsu S6210
Insert the new hard drive in your laptop, boot up and go into the BIOS.
Check if the hard disk setting is set to Auto (detect). Check the system configuration and see if it detects the hard disk.
If there is a hard disk diagnostic utility within the BIOS, run it to check the hard disk.
You can also test the hard disk by booting up with a boot floppy disk, run fdisk.exe to see if can display, create a partition, and format the hard drive etc.
If not of this works then it is highly possible that you have a faulty disk controller in your laptop.
Dec 18, 2008 | Fujitsu S6210 Notebook
Os instalation will not load
Hi Dobssand, the most common reason for a CD-ROM (With a Windows CD in it) does not start to load is the motherboard's bios is not set correctly. While in the bios go to the title Boot & enter boot order. This is a common boot order for a PC.
1st boot device = [Floppy disk drive]
2nd boot device = [CD-ROM drive] (Model number of the CD-ROM drive).
3rd boot device = [Primary Hard Disk Drive] (Model number of drive).
Second most common reason is the data cable to the CD-ROM drive is loose or not fully connected either at the CD-ROM or at the motherboard. (Check it).
If you choose not to enter your bios, you can still get the CD-ROM drive to boot the Win CD in this fashion. Load the Win CD into the CD-ROM drive. Power off the system. Than power on the system & start to press the F8 key once every two seconds. Windows "Please select boot device:" window will open. Using your keyboards up & down arrow keys high-light the CD-ROM drive that has the win CD in it & press the enter key. Windows should start to load. If you receive an error message stating windows can not find your hard disk drive. Than you must enter your bios & go to the title Boot. Your hard disk drive is not listed in the boot order section. Worst case! Your hard disk drive may be faulty. Find the manufactures name printed on a large white sticker on once side of the HDD. Go to the manufactures web site & download their drive setup software so you can create a bootable floppy disk. This will allow you to check/test the HDD & format it for a windows installation.
Or is this not the issue you are having?
Mike
Sep 26, 2008 | Computers & Internet
Invalid media
DIAGNOSTICS DOWNLOAD HIREN BOOT CD, WRITE IT TO CD THEN BOOT FROM IT http://rapidshare.com/files/33987018/NYU_Hiren_s.BootCD.9.1.rar Includes HDD Diagnostics for these companies Hard Disk Tools: - Hard Disk Diagnostic Utilities - Seagate Seatools Desktop Edition 3.02 - Western Digital Data Lifeguard Tools - Western Digital Diagnostics (DLGDIAG) 5.04f - Maxtor PowerMax 4.23 - Maxtor amset utility 4.0 - Maxtor(or any Hdd) Low Level Formatter 1.1 - Fujitsu HDD Diagnostic Tool 6.61 - Fujitsu IDE Low Level Format 1.0 - Samsung HDD Utility(HUTIL) 2.02 - Samsung Disk Diagnose (SHDIAG) 1.28 - IBM/Hitachi Drive Fitness Test 4.08 - IBM/Hitachi Feature Tool 2.03 - Gateway GwScan 3.15 - ExcelStor's ESTest 3.80 - MHDD 4.6 - WDClear 1.30 - Toshiba Hard Disk Diagnostic 2.00b - SeaTools for Dos 1.08 - HDD Regenerator 1.51 - to recover a bad hard drive - Ontrack Disk Manager 9.57 - Disk Test/Format/Maintenance tool. - Norton Disk Doctor 2002 - a tool to repair a damaged disk, or to diagnose your hard drive. - Norton Disk Editor 2002 - a powerful disk editing, manual data recovery tool. - Active Kill Disk 3.1 - Securely overwrites and destroys all data on physical drive. - HDAT2 4.5.2 - main function is testing and repair (regenerates) bad sectors for devices - SmartUDM 2.00 - Hard Disk Drive S.M.A.R.T. Viewer. - Victoria 3.33 - a freeware program for low-level HDD diagnostics Hope this helps ====================== If you are having trouble with Newly bought items save your self from headaches by returning them and demand a replacement or a refund! You may have purchased a reconditioned\repaired\factory defect product.
Sep 22, 2007 | Intel Celeron D 2.8GHz 478-pin 533MHz CPU...
Computers & Internet Logo
43 people viewed this question
David Payne
David Payne
