Question about GPS
Audio Issues On my maestro 3225...I go to Sytem Settings.audio and unmute speakers and turn volume up full...run the audio diagnostic and nothing...On the map screen the speakers are muted...so I unmute in the map screen...return to system settings.audio and the setting is mute...is there a fix?
  • knotty14 Jun 16, 2008
    reset doesn't fix it...the 2 mute functions (map screen & system settings) seem to be working against each other...still nothing on the audio diagnotic test..
  • 1,183 Answers
The 3225 Gps, is known to have some software glitches. Reseting the device, should solve your problem as told by Ekse.
Alternatively you can call Magellan Support on the following number 800-805-6003.
Thanks
Mandeep
Posted on Jun 16, 2008
  • Mandeep  Singh
    Mandeep Singh Jun 17, 2008
    Even after the reset if the audio is not working , there has to be an issue with the Hardware ie. either the sepakers or the sound card. I would suggest again if its in warranty get it serviced from the vendor or get the same replaced.
    Thanks
    Mandeep
    Sergeant:
  • 243 Answers
There are two ways to access the volume controls; one is tapping the speaker icon on the Map screen
and the other is through User Options.
Changing the Volume from the Map Screen.
1. Tap the speaker icon
2. Tap on the Mute button to mute the volume or tap inside the volume adjust bar below the
Mute button to change the volume levels.
3. Tap save
If you have the volume muted the speaker icon is displayed with a line through it indicating it is
muted. To unmute, tap the speaker icon again and the Maestro will automatically unmute. To make
any other adjustments to the volume, press the speaker icon again.
Changing the Volume from User Options
1. Access the Main Menu.
2. Tap the Next arrow to access the Main Menu Page 2.
3. Tap User Options.
4. Tap System Settings.
5. Tap Volume.
6. Tap on the Mute button to mute the volume or tap inside the volume adjust bar below the
7. Tap save
make sure you tap save when you do it. this might be your problem.
let me know if its not so i can further assist you
thanks,
Nate
  • 2 more comments
  • Nathan Ayers
    Nathan Ayers Jun 16, 2008
    if for some reason this doesnt work and you do have to reset the device as others say. Make sure you backup any extra Map packs you may have installed so you dont lose them.
    you do that like so
    Backing Up and Restoring Data
    Backup and restore provides a way of storing the address book and other data to a SD/MMC card. When the data has been backed up, it can be restored at any time. Please note that when you restore from backed up data, address book and other data will be replaced with the data. The Magellan Maestro cannot append backed up data to your existing data.
    Backing Up Data
    1. From page 2 of the Main Menu, tap User Options.
    2. Insert a SD or MMC card with available space into the SD slot of the Magellan Maestro.
    Note that backing up data will overwrite any back up files on the SD or MMC card.
    3. Tap Backup and Restore.
    4. Tap Backup.
    5. Confirm backup. Tap Yes.
    6. Operation successful! Tap OK.
    7. Tap Back arrow to exit.
    Restoring Data
    4. Tap Restore.
    5. Confirm restore. Tap Yes.
    hopes this all helps you
  • Nathan Ayers
    I would suggest to try making sure that its not saving the setting before resetting the device as it would be useless to loose all the data if it doesnt have to. You can do this by following the first steps I posted to you.
    glad i could help,
    Nate
  • Nathan Ayers
    well then it seems your unit has obtained a glitch that i came across a few times when researching your problem. you can send them the unit and have it serviced for about 25$ plus shipping as i can find from a previous consumer that had the same problem.
    to set that up please call 1-800-805-6003
    glad to be of service,
    Nathan
  • Nathan Ayers
    thank you for the same post as mine eske, im glad we both want to help.
    Brigadier General:
  • 6,966 Answers
Initially, let's assume that for some unknown reasons part of your configuration/settings has been messed up. Then, what would be needed would be to revert the unit back to factory defaults by doing a full hard reset that is poke the small hole with the paper clip which would be in left hand side of the unit. Of course all other personal configurations would likewise be defaulted.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
  • 13,433 Answers
Have you tryed to reset the device, also performing a software update useing your desktop software might fix the problem.
  • Ekse Jun 16, 2008
    heres the user manual
    http://www.magellangps.com/assets/manual...
    page 14
    Volume
    1. Tap the speaker icon .
    3. Tap Save.
  • Ekse Jun 16, 2008
    in the page 10 of the manual you can see a image of the rest switch on the side
How do I turn on the Acer AL1717 speakers?
the internal speakers, RTM it tells you how.
you plug them in to the PC, audio part conn.
then unmute the audio.
then up the volume.
also RTM the monitor OSD may have speaker enable , selection.
that is it.
Sep 26, 2013 | Acer 17" AL1717 Flat Panel Color LCD...
I HAVE SPEKERS AND WEB CAM PLUS MIKE I CAN SEE AND HEAR THE PARTY CALLING me on SKYPE BUT THE OTHER CAN NOT HEAR ME BUT CAN SEE ME I HAVE ALL TURNED UP fully ??? what dose mute and unmute mean ???
the mute means no sound and unmute means sound
click start control panel administrive tools ,computer management ,device manager scroll down image devices you could see a yellow question mark?
right click to reinstall drivers or
update driver
open skype go to tools from the drop down list select options scroll to audio settings
you can make a free test call before you try to make a call
make sure the microphone is using the same as your computers audio
you can make a free test call if you cant get the microphone to work you can select learn about setting up your audio equipment also
click start control panel sounds and audio devices audio and also voice it's the same make sure that you have the right default microphone selected you should be able scroll to video settings to make sure you have the right settings
Open skype go to tools options scroll to audio settings or video settings on the right you will see webcam setting you can change the settings from there click apply after changing any settings also you can see the webcam there you can even take a snapsot also make sure your settings are correct for a video call
also
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick also
select audio from the microphone drop down list make sure you have the right one selected and in the volume box make sure the microphone box has a tick in it or
select the voice tab and make sure that you have the right media selected also select volume make sure the box for microphone has a tick in it
Oct 06, 2011 | Recoton Advent Advent AV570 Computer...
How do i unmute microphone i can hear them but they cannot hear me
Jan 22, 2011 | Skype IM
I have a Sharp LC37D43U TV that has no audio. The volume indicator shows can be moved up or down but no sound comes through the speakers. The picture works fine. I have nothing else connected to the TV....
It appears you ve discovered the sound task levers required to adjustment properties. Your Tv can still move levers even when the volume is set to mute. Select the unmute button before any voice or audio would be reactivated. Assuming that seting the TV on mute has predominant integrety over the volume functions where not unmuting usually with the same button on the remote would not achieve accessibility to the volume functions. refer to the TV user guide for diagnostic audios. Good luck
Jan 09, 2011 | Sharp Televison & Video
I can only hear the person I am talking to through headphones, I want to hear them on my speaker
To solve this problem ,do this; goto start menu >control panel>sound and audio devices
in volume tab under speaker settings , click on "advanced" in speakers tab speaker setup:select desktop stereo speakers
click performance tab Hardware acceleration =full sample rate conversation quality=best. click on apply,and ok
select audio tab in sound and audio output. click on volume ,unmute all . increase all volume to high. close it.
select voice tab in click on volume ,unmute all . increase all volume to high. close it.
click on apply and ok.
then open your audio manager .increase play back volume and unmute all .
important :select default device (sound play back) .to your audio manager's default device . after apply all settings .click ok and close it. in sound and audio output. tick on "use only default devices". . do it and solve it
Sep 08, 2010 | Skype IM
No sound in speakers everything is correct
Hi there
You need to update your sound drivers,to do this go to start menu on your computer and type in the word "device manager",select it from a list of options and click on it you will see a list of components/devices that are working with your computer select the "sound" component.
Click on it and you will see your sound driver,right click the sound driver and you will see a list of options select "update driver software" this automatically search for updates,download them and install it in your computer.
You will have to restart your system for the update to work properly.
Sep 02, 2010 | Microsoft Windows XP Professional for PC
I have an hp g60-230us. installing skype, both parties see visual. I hear them they can,t hear me, Ihave mic volume full high, and have checked unmute.
Have your mic turned on.
Go to your toolbar, double click on your audio volume. Then click on mixer (if your on vista), Turn on skype audio to max.
Go into Skype:
Tools > Options > Audio Settings
Choose where the mic and audio are coming from, if your using a headset choose front panel or where ever your panel is. Otherwise its set on default.
Sep 10, 2009 | HP G60-230US Notebook
My sound has stopped working
what application are you running and what OS?
I'll assume a music/video player on XP using built in speakers
Check the following:
  • Control Panel>sound: make sure mute is unchecked and the volume is up the whole way
  • click "speaker volume" turn the slider the whole way up>click ok
  • click advanced>turn wave (or whatever type) all the way up
  • check that volume slider on your player is all the way up and unmuted
  • make sure you do not have anything plugged into audio ports such as headphones if you have an HDMI monitor that may also be rerouting your audio. I've had trouble where I need to reboot after hibernation/suspend mode when using HDMI audio so try that.
Jun 11, 2009 | Acer Aspire 5735 Notebook
No audio output device
You need to reinstall the drivers. Get these from support.dell.com
Mar 28, 2009 | Dell Inspiron 6000 Notebook
No Sound
Is there any mute/unmute or volume control on the GPS? If so, is the mute/unmute function unmuted, and is the volume all the way up? If you have already checked this stuff, then would say that the device is bad (in which case you can probably send it back to Magellan for a replacement) or the speaker was somehow disconnected( in which case you can't fix it). Has the audio ever worked?
Mar 15, 2008 | GPS
GPS Logo
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
