Question about Dishwashers
Just purchased a new Beko DFN1000X One Touch dishwasher. Plumbed in, switched on - starts up then says Call Service on LED panel? I have poured 1Ltr of water into salt dispenser as instructed.
  • 641 Answers
SOURCE: LG LD-2160 dishwasher
Get an aqua vac and suck out the water (with the dissolved detergent)from the salt container. Refill it with water and repeat the process couple of times. Fill the container with water and salt and it should be fine. Good luck !!
Posted on Jun 28, 2006
  • 1462 Answers
SOURCE: the salt light keeps burning
the salt light is done by a reed switch operated by a float in the salty water. float may be stuck - give softener (where you put in the salt) a tap and also stir the water inside the softener. i assume you have put in enough salt. its not a serious fault
Posted on Mar 30, 2007
jaylex
  • 417 Answers
SOURCE: dishwasher and salt
run a few times with nothing in the machine on full washes it may be that the salt you are using is not suitable for that machine also check that you have the machine plumbed into the hot water outlet.
Thanks J
Posted on Feb 16, 2008
  • 1462 Answers
SOURCE: adding salt in dishwasher
that is what is supposed to happen
Posted on Sep 18, 2008
SOURCE: G892-SC Miele water intake/drain light blinks
The intake/drain light blinks. How do I fix this problem?
The water is coming directly drain. water comes inside and drain so on. What could be the problem?
Under the sink, be certain that the drain hose from the dishwasher to the disposal is higher than where it attaches at the disposal.If it's laying on the bottom of the cabinet, that is your problem. Good luck
May 11, 2017 | Beko Dishwashers
Where About's is the heating element on the beko Dfn1000x
Base of the dishwasher tube below the lower water sprayer.
Jul 20, 2016 | Beko Dishwashers
On Off switch faulty
The switch is available from eSpares.
http://www.espares.co.uk/product/es1624719/onoff-switch?ModelId=1630729
The rear of the control panel will become accessible by removing the screws holding the stainless steel door panel from inside the door. Make sure the dishwasher is disconnected from the mains power supply.
Mar 30, 2014 | Beko Dishwashers
Settings
settings should show you how the machine is to function. Do uou have a manual?
Jul 23, 2013 | Beko DFN1000X Dishwasher
I have just been given a beko slimline dishasher DE2431F, my friend told me it was only washing on cold wash,and it needed a heater element,i bought one installed it but it is still running cold the water...
Use a mulimeter to check the voltage to the heaters when the dishwasher is started on. If there is no supply to the heaters then the fault lies with the program controller drive. It can be failure of the relay or the contacts. Or it can be problems in the main program controller not outtputing to switch on the heaters..
Jul 14, 2011 | Beko DFN1000X Dishwasher
My beko eco care d3421fw dishwasher won't fil with
i have beko glacier fridge freezer.the freezer section works as normal but the fridge section only works sometimes.the pump only starts after you hear a click sound from the back of the fridge.is there a starter component that activates the pump.
May 22, 2009 | Beko 24 in. D3421F Free-standing...
Dishwasher not taking in water
It could be a few things, one of them is a defective water inlet valve, the water inlet valve lets water enter the dishwasher from the main water line, another thing it could be is a defective float switch, the float switch rises up as water fills the dishwasher.
Mar 13, 2009 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Dishwashers Logo
127 people viewed this question
Top Dishwashers Experts
