Question about Frigidaire FAC107P1A Wall/Window Air Conditioner
Friedrich A/C our Friedrich wll unit is leaking water on our wooden floor... why is that ? and how can we fix it ?
  • 230 Answers
The evaporator coil will sweat condensation from it during normal operation. this can accumulate to quite a bit of water by the day's end. I would check to see if the drain pan under the coil is plugged or the drain line that (Should) be attached to it. Finally it could simply be off balance causing the water to overflow out of the pan.
Posted on Jun 16, 2008
I working on a old Friedrich water source heat pump Model # V42 does anyone knows what size is it?
The friedrich name was taken off of units in the 80's when the climatemaster name was invented. My guess is 42000 btu or 3.5 tons rated capacity
Feb 05, 2015 | Friedrich Heating & Cooling
Friedrich quiet master KS12L10 leaking water down outside wall and windowsill.
it may need coil cleaned. there is a drain hole under evaporator coil that might be stopped up.
Aug 12, 2014 | Friedrich QuietMaster RS10J10 Air...
Unit forms ice on back coil. Please advise
The freon in the unit is low. You probably have a leak.
Jul 13, 2014 | Friedrich D40 Dehumidifier
My air conditioner Friedrich w18c3e is leaking inside? what do I do
Clean the drain out,and make sure ,if it is a window unit,that the unit is tilted enough towards the outside
Jul 15, 2010 | Friedrich M18CE Air Conditioner
Our floating air system from Friedrich is leaking a lot of water,how do i fix this problem,what should i look for when repairing the unit?
The drain hose could be clogged or the drain pan could be blocked. A service technician can correct this. Give an air con technician a call. This can be done by yourself if you know what you are doing but it is best to leave it up to the professionals
I take the time to answer you questions so please rate me
Aug 10, 2009 | Friedrich M18CF Split System Air...
Friedrich AC through the wall ac leaking water out front vent
pull it out and check for packaging left in ac unit, and make sure drain is clear and large enough for water flow ,,,go ahead and tilt ac unit more and see if that doesnt do the trick
Jul 04, 2009 | Friedrich CP12C10 Wall/Window Air...
Friedrich RS10J10-C: Only half the coils are chilled...
If the evaporator coil is only half coated with water, this means it is low on Freon. You need a repairman to fix the leak and add Freon, but this costs way over a hundred dollars.
Jul 23, 2008 | Friedrich QuietMaster RS10J10 Air...
Wall unit leaking water in the front
The problem is in the lines that run from indoor to outdoor unit.
You need to make sure all lines are slightly sloping towards outdoor unit
Jul 20, 2008 | Friedrich QStar SQ06J10 Air Conditioner
Heating & Cooling Logo
204 people viewed this question
Top Frigidaire Heating & Cooling Experts
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
Bill Long
Are you a Frigidaire Heating and Cooling Expert? Answer questions, earn points and help others
