Question about Dell OPTIPLEX 320 (MH651) Motherboard
My optiplex power light were solid yellow and my monitor black screen
  • 2427 Answers
SOURCE: black screen on start up
yep
unplug the system
open the case
look for a battery and take it out
take out the memory (rams)
wait ten minutes
press power button 5 times
put everything back in
and boot it
Posted on Jan 12, 2008
nuwan chinth
  • 111 Answers
SOURCE: bought refurbished dell optiplex 260 w/o operating system
it can be aproblem of.
1.vedio card (please use good card and check)
2.cpu(try to changing processor)
3.mother board(you have to replace)
nuwan.
Posted on Jan 15, 2009
rj_8017
  • 22 Answers
SOURCE: E196FPf says that it is E176FP monitor - image is washed out
memory ic software currupted..
Posted on Feb 08, 2009
konzzz
  • 255 Answers
SOURCE: monitor goes black............
try checking the cables first.
Posted on May 28, 2009
SOURCE: Power on - blank (black) screen
Disconnect the monitor signal cable from PC and switch on your monitor. It should show some logo with Red, Green and Blue colors with a message similar to "No signal". If so, your monitor is working fine. Sometimes if the brightness and contrast is set to zero using controls present in the monitor, it will not show up anything. check wheather somebody set your monitor brightness and contrast to zero. If so incease them. As a last try connect to different PC and check before approaching a service center. I hope this will help you out. :)
Posted on Aug 21, 2009
I have a Dell Dimension E521. When I cut the power on everything comes on including the monitor, but the monitor will stay black. It does say something about power save hit any button but the screen
A solid green light means the computer is operating normally.
A solid yellow light indicates the power supply is operating normally but the computer is not processing data.
This could mean there is a problem with the CPu or another component on the motherboard.
((A blinking yellow light indicates the power supply is receiving power from the wall, but not functioning properly.
This generally means the power supply itself is bad and should be tested or replaced.))
A blinking green light means the computer is in standby mode.
You should consider visiting Dell Support and downloading the manual for your
your Dell computer. So use the LED power light codes if your Dell computer has them.
hope this helps
Sep 10, 2012 | Dell Dimension E521 PC Desktop
My dell optiplex light is solid yellow
That usually means the switch on the power supply has been moved to 220v vs 110v. The switch is located just above where the power cord plugs in.
Aug 31, 2012 | Dell OptiPlex GX620 PC Desktop
My Dell optiplex SX280 Wouldn't boot up
If you tried to install a BIOS up-grade and it failed, then your motherboard is toast.
Jul 19, 2012 | Dell OptiPlex SX280 PC Desktop
Hello I have a Dell optiplex GX270, with the mobo it comes with. It will boot, has sound coming from the HD, CD drive, cpu cooling fan, etc, but will not show anything on the monitor and the keyboard...
Hi,try swapping the Memory chip ie putting it on the other slot,also test with another processor if after all these system does display,i'll suggest you go get a new board.
Jan 04, 2011 | Dell OptiPlex GX270 Small Mini-Tower...
Monitor won't come back from "sleep" setting.
Yes it can be, try it on other PC first to narrow down the problem.
Most problems in the Dell are failed transistors, poor solder works, see pictures here for guide: http://s807.photobucket.com/home/budm/allalbums
Post back what you find.
Apr 03, 2010 | Dell E152FP 15" Flat Panel LCD Monitor
Won't load windows...
you video card is not working.... if you have onboard video use that until you have installed the driver for your add on video card
Apr 16, 2009 | Dell Dimension 3000 PC Desktop
Black screen
how can u fix this black screen? the green power light is on, shows vista for a bit then turns black and stays black. any solutions or do i have to send it back?
Apr 03, 2008 | Microsoft HannsG HU171D 17" LCD Monitor
Powerbutton flashing yellow
If the main power button LED is flashing or solid yellow, this could indicate a hardware problem.
Was it running good before?
Are the diagnostic LED lights all green?
Here is what dell says:
If the power light is blinking amber  —
 The computer is receiving electrical power, but an internal power problem might exist.
  • Ensure that the voltage selection switch is set to match the AC power at your location (if applicable).
  • Ensure that the processor power cable is securely connected to the system board.
Do you remember what the BSOD said?
Oct 22, 2007 | Dell OptiPlex GX620 PC Desktop
Dell OPTIPLEX 320 (MH651) Motherboard Logo
257 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
