Question about Pioneer Elite PRO-111FD 50 in. Plasma TV
8 blinking blue light on my pioneer elite tv - Pioneer Elite PRO-111FD 50 in. Plasma TV
SOURCE: Pioneer Elite Plasma TV
Power went out and after it came back on I experienced the same issue. I have not been able to figure out what the problem may be. My elite plasma still won't power on.
Posted on Jul 18, 2008
electronick
  • 505 Answers
SOURCE: pioneer elite 50 plazma tv
this is a power supply.. you have to replace the board to fix. price depends on model but on the old ones its $$
Posted on Jan 09, 2009
  • 2326 Answers
SOURCE: TV keeps shutting off automatically
Since your plasma is less then a year old, I would suggest to contact the manufacturers to get it fix under warranty. If the plasma keeps shutting off by itself, that is not normal and should be repair.
Posted on Jan 28, 2009
renowiccan
  • 234 Answers
SOURCE: Pioneer Elite PRO-1540HD displays 13
Have the power board professionally replaced.
Posted on Mar 21, 2011
bshldn
  • 736 Answers
SOURCE: Pioneer elite 2006 50" tv How can I change from
You can't change the resolution on the television itself. You change the resolution on whatever you have connected to the television. Let's say it's a cable box or a blu ray player you've got connected to the television. First off you have to connect it to the television with a component (green, blue, red, white, red) cable or an hdmi cable. Then you make sure it is only connected to the television with either a component cable or an hdmi cable. This may sound ridiculous but there are some people that have their cable boxes and blu ray players connected to their televisions three different ways ( an hdmi cable, a composite cable, and a component cable) when they only need to have it connected one way.
Select the proper input on the television. Set the cable box or blu ray player's resolution to 1080i or 1080p (in the case of the blu ray player if it the tv will allow it).
Posted on Apr 05, 2011
My 60 inch Pioneer elite plasma TV light blinks blue light blinks eight times, what can I do?
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
Apr 12, 2015 | Pioneer Televison & Video
Find activation code for pioneer
My pioneer 5020FD Kuro tv. when I plug power to the unit, a blue light blinks 8 times pause 2 sec. and blink 8 times repeating this and if i press power button it clicks red light and makes a clicking sound and goes back to the blue light blinking again, it did this once before and the picture came on fine until i turned it off and now it just blink the blue code.
Dec 10, 2014 | Pioneer PDP-5020FD 50 in. Plasma HDTV
Pioneer 5020 will not power up and blue light flashes 8 times
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power led, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating, to many popular brand TVs and other devices. Viewing it in "Mosaic" will make surf easy.
Feb 15, 2014 | Pioneer Elite PRO-111FD 50 in. Plasma TV
Pioneer Pro-111FD does not power up and blue light keeps blinking 8 times
8 times blinks denotes a cooling fan failure. If you wish to get some details, check this link. http://electronicshelponline.blogspot.com/ Selecting the view option, either to Mosaic / Timeslide / Flipcard, can be selected by the drop-down list, at the top left of the display window, will make surf easy. You can also do a search, by type in the brand name / model number / IC used, in the search box at the top right of the display window.
Nov 10, 2013 | Pioneer Elite PRO-111FD 50 in. Plasma TV
Pioneer Elite 1140 HD not working : reds light blinks 4 times
Four blinks of standby light to Plasma TVs, denotes a voltage output failure from its main power regulator board. Check this link for more. http://electronicshelponline.blogspot.com/ Pull up older posts there. Blinking codes to most Plasma TV brands will be similar. Check them. Pioneer brand is also there.
Products powered by electricity should be serviced or repaired only by experienced professional technicians. Any attempt to service or repair the product by anyone else could result in serious injury or death. If you are not familiar with electronics, do not attempt to repair. Whether you suffer fatal electrical shock. Instead, contact the nearest service centre.
Jun 03, 2013 | Pioneer Elite PRO-1140HD 50 in. Plasma...
Pioneer PDP-r06xe 50 in. Plasma Television Problem. During a Rain Storm - a lightening strike in my loft - the save system it has protect several electronics, but when I try to switch on - the TV it turn...
when switch ON it blinks 7time blue led - then switch OFF by SELF and blinks 8time blue led. Of-course when it switch off by self the TV swap the led from blue to red but the blinking Blue led is on the Receiver (The switcher on the TV is never blinking)
May 22, 2010 | Pioneer PDP-4350HD 43 in. Plasma...
I have an Elite faltscreen television that has been working well for over one year. For an unknown reason, the blue light (next to the on/off switch0 is blinking and the TV is not responding or turing...
Please count the number of flashes of the Blue LED. It will flash Ex. 12 times and pause for 2 seconds and then flash 12 times again. The number of times it flashes will tell me more as to what the solution is. I am assuming the set works otherwise ?? What is the model number of the set ?
Scott
Feb 14, 2009 | Pioneer Elite PRO-1540HD 60 in. Plasma...
Jan 28, 2009 | Pioneer Elite PRO-111FD 50 in. Plasma TV
Pioneer elite 50 plazma tv
Jan 09, 2009 | Pioneer Elite PRO-1140HD 50 in. Plasma...
No picture blinking stand by light
I hve worked on a number of these units , your description is typical of a shorted blue picture tube. The protection circuits in the tv detect that there is a problem thus shutting the unit down to prevent further damage. Sony had a bad run of picture tubes in this series. The replacement cost of the tube is about $250 plus labor. My estimate would be for the repair about $400-500 depending on where you live and how honest your local technican is. I will caution you however, that you could replace this tube and the red or green could go. These would not be covered by the technicians warranty. When these sets are working, they have a superb picture and it is easy to get lured into fixing them. Scrivitron
Jun 13, 2007 | Sony KP-51HW40 51" Rear Projection...
Pioneer Elite PRO-111FD 50 in. Plasma TV Logo
1,200 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
