Question about Kenmore Dishwashers
The lock light on my kenmore elite dishwasher #15962990 wont stop blinking. It wont reset to run a cycle. How do I reset the control panel??? HELP!!
  • 4,323 Answers
Hi
To reset the control panel press and hold the RINSE ONLY/AIR DRY button for 15 seconds. Hope this helps....please let me know if you need further help.
Daniel
Posted on Nov 08, 2010
Kenmore elite dishwasher model 630 Smart Wash light is flashing
You may want to try:
Press a series of four buttons in quick succession. Press "Heated Dry," "Normal Wash," "Heated Dry" and "Normal Wash" to instruct your Kenmore dishwasher to run a short diagnostic test.
Wait for two minutes while your Kenmore dishwasher runs its diagnostic test.
Press the "Cancel/Drain" button once your dishwasher has completed its diagnostic test. This should reset your dishwasher control panel.
Check to make sure that there's no standing water in the bottom of your dishwasher. Standing water in your dishwasher may indicate that your dishwasher has stopped mid-cycle. You will need to press the "Cancel/Drain" button before you can reset your dishwasher control panel.
Dec 18, 2013 | Dishwashers
Error 1 on kenwood dishwasher
Hello.
Manufactured by Whirlpool, Kenmore dishwashers have an electronic control panel that must be unlocked in order to set or make changes to your dishwashing cycle. If an error light is blinking on your dishwasher's control panel, the panel must be reset before you can gain access. Blinking lights on your dishwasher control panel may signal a mechanical problem that needs to be repaired. If the lights continue to blink after you've reset the control panel, contact Sears to service your Kenmore dishwasher or consider troubleshooting the appliance yourself.
1Press and hold the "Heated Dry" button on your Kenmore dishwasher for four seconds to unlock the dishwasher control panel.
2 Press the "Heated Dry," "Normal Wash," "Heated Dry" and "Normal Wash" buttons one after the other, in fairly quick succession.
3 Wait for the dishwasher to run a short diagnostic test.
4 Press the "Cancel/Drain" button at the end of the diagnostic test cycle. This should reset the control panel on your Kenmore dishwasher.
Thanks.
Nov 05, 2011 | Kenwood KDW243A Builtin Dishwasher
My quiet partner 111 whirlpool dishwasher is flashing clean
Hello.
Thanks.
Nov 04, 2011 | Whirlpool GU2400XTP Built-in Dishwasher
I need to reset my Kenmore Elite dishwasher but i don't know how.
follow the below instructions:
Unlock your Kenmore dishwasher control panel by pressing and holding the "Heated Dry" button for four seconds.
Press the "Cancel/Drain" button once your dishwasher has completed its diagnostic test. This should reset your dishwasher control panel and stop the "Clean" light from blinking repeatedly.
Good luck.
Jul 14, 2010 | Microwave Ovens
Kenmore Elite wont power on
Door switch. If the washer thinks the door is open, it won't run.
Jul 31, 2008 | Kenmore 24 in. 15932 Built-in Dishwasher
Kenmore elite dishwasher 665 15962990
Hold down the "HEATED DRY" button for 4 seconds to unlock.
Try to press these botton in sequence,Heated Wash, Heated Dry, Heated Wash, Heated Dry.release your hand, the unit will go into diagnostic mode. that is all leds will ON for a few seconds,and start normal operations.
If that does not work, you might need to check the electronic control board if the ribbon is seated properly.
Finally solution, is to change the electronic control board.
Jul 27, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Kenmore Elite 15962990 will not start
So far, I'm not very impressed with this website. I posted a problem with a Kenmore Elite 15962990. FixYa emailed me back, saying: "We wanted to find out if you still need a solution for the Kenmore 24 in. 15932 Built-in Dishwasher Problem". So now I'm confused. I'm supposed to trust advice from somebody who can't even get the model number right? And FixYa keeps telling me I'm dealing with a top load clothes washer instead of a dishwasher.
Anyway, the problem still exists. I know there must be some way to reset it or put it in "maintenance mode". But none of the button sequences I saw online will work because my specific model does not have the buttons mentioned.
Feb 10, 2008 | Kenmore 24 in. 15932 Built-in Dishwasher
Kenmore Elite Dishwasher Model# 665.15912001
Yeah, I have a similar problem. I tried to go into a suggested diagnostic run, but that didn't yield anything. I tried pushing the Sani-Rinse and Air Dry buttons back and forth a number of times. Didn't help.
At first I thought the lock-on had accidently been engaged, but disengaging the "child lock" doesn't help. The lock-on light comes back on and sometimes blinks rapidly. I"ve counted around 7 rapid blinks at times and 3 rapid blinks at other times--in case that makes a difference. The control panel doesn't work--in other words, the dishwasher does not start, even when I can successfully get other lights to come on. I don't want to spend >$100. for a new control panel if that is not really the problem.
Jan 26, 2008 | Kenmore 15912 Built-in Dishwasher
I had the same problem when I bought it and it just happened again; the problem is solved by ressting the control panel: Hi Temp ---> Heated Dry two or three times. It kind of goes into a testing cycle and the clean blinking light goes off.
Dec 08, 2007 | Kenmore 24 in. 16032 Built-in Dishwasher
Dishwashers Logo
90 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
