Question about Ricoh Aficio 1035 Copier
Afico 2035e - error SC326 - Ricoh Aficio 1035 Copier
  • 165 Answers
326 C 2nd laser synchronization error
The 2nd laser synchronization signal
cannot be detected by the main scan
synchronization detector board even if
the laser diodes are activated.
• Poor connection between the laser
synchronization detector board and
the LD unit.
• Laser synchronization detector board
out of position
defective
• LD unit defective
My guess is that polygon mirror failed £50 -£60 if u brave enough to change it yourself
if not its lazer or sync board
Posted on Nov 13, 2010
Reset error code
It's a laser error code, service call required
Feb 04, 2014 | Ricoh Aficio 2035 Copier
I reset my ricoh aficio 2035e photocopier then error sc 322 apear
error code 322 on a Ricoh/Gestener/Nashua/Aficio is usualy related to the laser unit/Polygon mirror motor, can you hear the motor starting up when you swith on the printer?it shoul sound something like an jet engine starting up, if you do not hear it then ask your local technician to replace the polygon mirror motor.
Sep 16, 2013 | Ricoh Aficio 2035E Digital Copier. 35cpm...
What is error code SC326-00 on a Ricoh Aficio 450 copier?
326 error in laser unit . check ld conection and reset yourmachin
Jul 05, 2012 | Ricoh Aficio 450 Copier
RICOH AFICIO 1035 I GET AN ERROR CODE SC326 AND PAPER KEEPS GETING JAMED WHERE IT TRIES TO ENTER THE BIG GREEN ROLLER.
SC326 is a laser synch detect error. The jamming is probably just because of the code popping up and the machine shutting down. 9 times out of 10 the cause of an SC326 is toner dust buildup on the laser optics. It is either that or possibly a laser unit (LD Unit) failure. The power to the LD unit flows thru the front door switches and I have seen those go bad and cut or reduce power to the LD unit which will cause the same code. I would get a Ricoh tech out to clean the laser optics. This is especially true if you open the fron door and there is toner dusting around the toner cartridge/DV unit area.
Good Luck and Thank You for using Fixya.
Aug 31, 2010 | Ricoh Aficio 1035 Copier
Sir my Ricoh 1045 machine have SC 326 problem, after taking a single copy the error code comes. please give a good solution to clear my problem. thanks
sc326 is a laser synchronization error. The problem is usually caused by the laser sync detection board or the LD unit.
Jun 02, 2010 | Ricoh Aficio 1035 Copier
After sc326-00 my copieur ricoh aficio 350 put on his screen sc322-00 and not work, how cold i resolve this problem
Laser Synchronization Error(1 & 2)(sc322 & sc326)
· Laser synchronization detector board out of position
· Laser synchronization detector board defective
Also check if any cables are loose and also if the laser unit is dirty.-Clean it.
Feb 09, 2010 | Ricoh Aficio 350e Printer
Sc300 had this code on afico 1075
Charge corona output error 1
The feedback voltage from the charge corona unit is too high
Possible causes -
· Charge P.P. defective
· Poor charge corona unit connection
Jan 25, 2010 | Office Equipment & Supplies
Functional Problem SC326-00
Hi There,
This error has to do with the laser unit. There is a special fix for it, and it needs to be done by a Ricoh Technician. The laser front right corner needs to be adjusted. For this one, you will have to place a service call.
This happened during the move.
Steve C.
Dec 06, 2008 | Savin 9935DP Laser Printer
Error SC326 on aficio 1045
Hi there below is what is states in the service manual.
the LD unit.
out of position
defective
• LD unit defective
Hope this helps you.
Thanks Jason
Aug 16, 2008 | Office Equipment & Supplies
Ricoh Aficio 3006 error sc452
The SC 326 is -- 2nd laser synchronization error. Meaning, the 2nd laser synchronization signal cannot be detected by the main scan synchronization detector board even if the laser diodes are activated.
Basically your polygonal mirror motor unit is bad and needs to be replaced. You can replace the whole laser unit but that is expensive. When you replace the PMM unit, do so in a still air area -- as to not get anything in the unit. When you get the PMM unit -- contact me and I can walk you through the steps to replace.
The SC 452 is --- Transfer Belt Mark Detection Error. Once you fix the SC 326 error this one should be fixed also.
Jul 17, 2008 | Ricoh Aficio Colour 3006 Color Copier
Ricoh Aficio 1035 Copier Logo
737 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
gggg
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
