Question about Mitsubishi WD-65C8 65 in. LCD HDTV
I need a manual for WD 65C8 - Mitsubishi WD-65C8 65 in. LCD HDTV
  • 320 Answers
Please refer to the link below for the manual of Mitsubishi WD-65C8
http://www.retrevo.com/support/Mitsubishi-WD-65C8-TVs-manual/id/21395ag201/t/2/
Posted on Nov 08, 2010
Testimonial: "Awsome thank you"
No image, but good sound
You need to replace your power supply board. They can be had at www.shopjimmy.com
Jan 08, 2014 | Mitsubishi WD-65C8 65 in. LCD HDTV
TV speakers off
check your audio settings,
Dec 24, 2013 | Mitsubishi WD-65C8 65 in. LCD HDTV
What would cause a shadowing of pastel colors when watching my tv
I have personally had this problem, you have the cords in the wrong place.
Nov 03, 2013 | Mitsubishi WD-65C8 65 in. LCD HDTV
I just replaced my bulb on my mitsubishi wd-65736 but picture is still dark looking and the bulb stays lit up after we cut the TV off. Could I have hooked the two wires up wrong?
This site lists your service manual for $7.99
https://www.completeservicemanuals.com/mitsubishi/dlp-projection-television/wd-65736-service-manual/prod_1408.html
This site claims to have a free PDF download, but the "free download" link throws you to www.tradebit.com, which sells the service manual (as a downloadable PDF file) for $7.99
http://www.promanuals.com/serviceparts/mitsubishi-wd-60735-wd-65735-wd-73735-wd-65835-wd-73835-wd-60c8-wd-65c8-wd-73c8-wd-65736-wd-73736-service-manual/
This site sells your TV service manual for $5 as a .PDF sent to your email:
http://tv-part.com/index.php?target=products&product_id=1369
If you can read/use a service manual, $5+tax is a lot better than $hundreds for a new television. Or- buy the downloadable manual, and give it to your favorite electronics friend to peruse. The darkness coming from the new lamp might bespeak of a power supply problem, or a poor connection between the lamp and the power supply. The fact that the lamp module stays on after it should go out also says power supply problem.
In the worst case, keep both your lamp modules (they're probably both good), and sell them online to help defray the cost of a new television.
Sep 30, 2011 | Mitsubishi WD-65736 Television
Mitshubishi TV WD65C8 picture is dark - has been that way since i bought it 2 yrs ago? sonenergy@qwest.net
If you have a dark picture I would first check lamp and see if correct, and if correct you could have a bad or weak ballast, but I would buy new mits lamp and replace and see if this helps if not check ballast
Apr 16, 2011 | Mitsubishi WD-65C8 65 in. LCD HDTV
My mitsubishi wd-65c8 has a flashing green light.. I have replaced the capacitors on the DM board and the same is happening.. what else could be the...
Common Repairs
For the following models: WD-52631, WD-57731, WD-65731, WD-Y57, WD-Y65, WD-57732, WD-65732, WD-57831, WD-65831, the most common repair problem stems from television shutting off almost immediately after it has been turned on accompanied by the message, "TV will shut down in a few seconds. Please check if the air flow is blocked." According to the Mitsubishi website, this issue is caused by a loose connection as a result of a faulty thermal sensor. For models: WD-73727, WD-73827, WD-73927, WD-73732, WD-7383, the most encountered repair problem has been in relation to the optical engine. Another common situation consumers have encountered is failure of the TV to turn on along with unceasing flashing of the green power light. The solution for this problem, caused by the DM board, will vary by repairman. Consumers have also encountered issues with moving vertical or horizontal lines appearing on the screen which can either be due to problems with the capacitor, light engine, or formatter board. Make sure all bad caps are changed.
Jan 23, 2011 | Mitsubishi WD-65C8 65 in. LCD HDTV
My mitsubishi wd-65c8 picture is dark. i've tried to fix the brightness but that didn't help what do i need to do
Open up the front lower panel. You will find several screws that hold another panel cover. Remove the second panel and you will find 6 knobs that will help adjust your coloring and fine tuning.
Dec 19, 2010 | Mitsubishi WD-65C8 65 in. LCD HDTV
Calibration
The main setting is usually the brightness, contrast and hue, do it manually until you're satisfy with the results
Jul 28, 2009 | Mitsubishi WD-65C8 65 in. LCD HDTV
Mitsubishi tv
I can help you unlock your Mitsubishi HDTV V-Chip.
Please follow these steps to bypass the vchip or reset the V Chip password.
These steps are actually for a Mitsubishi Projection HDTV, but I think they may work for a Mitsubishi LCD HDTV too.
I hope that helps.
_______________________________________________
Reset Mitsubishi HDTV VChip Password
Bypass Mitsubishi HDTV Front Panel Lock
Jun 23, 2009 | Mitsubishi WD-65C8 65 in. LCD HDTV
Mitsubishi WD-65C8 65 in. LCD HDTV Logo
205 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
