Question about MSI CR600-001US Notebook
Display skips during video play back and game play. restoration to factory default didnt fix problem
    Brigadier General:
  • 8,909 Answers
That doesn't surprise me at all.
If you are watching directly from the internet, you have a download speed issue as it is stopping to refill the cache.
Try a faster broadband or wait until it has downloaded before viewing.
If your RAM is too small, that will also cause that problem.
Hope that points you in the right direction.
Posted on Nov 08, 2010
Take off family code
Hi, really you have only a couple options. Either guess the security questions correctly, reset the system or get it replaced.
If you want to just get to the prompt to change the passcode and you know the security question, type in:
Code to go to family control security questionX, Y, Left Trigger, X
If you want to reset all settings to factory default you would press:
Code to restore factory defaults.LT, RT, X, Y, LB, RB, D(dpad), Y, U(dpad), D(dpad)
Go to console settings and all the way down to select system info.
Enter code above.
Then you will be prompted to restore factory defaults.
Your 360 will then restart and go to the dashboard.
When prompted to restore family settings, you would choose to skip it.
Also, you can do this while removing all storage devices if you are concerned of any changes. Just turn off your system before and after while disconnecting your hard drive or memory units.
Let me know if you have any questions.
Aug 05, 2012 | Microsoft Xbox 360 Elite Console
Tip
8 Steps to Fixing Any PS3 Issue
Note: If your PS3 is on, but you are looking at a blank screen, you PS3 may be in HD mode.
  • Turn off your PS3.
  • Hold down the power button for 2 beeps. This will reset your PS3 video to standard output.
  • If you are unable to reset your video, skip to Step 8.
  1. Back Up your PS3. You will need a compatible external hard disk drive for this step.
  2. Enter Recovery Mode.
  3. Choose "System Update".
    Try to load a game or movie. If it works, skip the rest of the steps listed below; otherwise, continue.
  4. Re-enter Recovery mode, and choose "Restore Default Settings".
  5. Re-enter Recovery mode, and choose "Restore File System".
  6. Re-enter Recovery mode, and choose "Rebuild Database".
  7. Re-enter Recovery mode, and choose "Restore PS3 System". WARNING!: This option will delete everything on your PS3 hard disk drive!
  8. Return the unit to Sony. If your PS3 is still under warranty the fix will be free; otherwise it will cost $150.
on Mar 26, 2010 | Sony Playstation 3 (PS3) Console
So i bought an ACER ASPIRE ONE D255 red slick color laptop recently, now it's only second hand but it works fine. i checked the audio, video and it's ok. i have two problems: -when i would try and play...
Regarding the unexpected errors on playing games like solitaire or minesweeper on your D255...
As it is second hand, there may be hardware or software problems or both. Software problems can be eliminated by doing a restore of the notebook to its factory image and settings as follows...
1. power off the notebook completely and then power on again
2. during the start-up, press Alt key (to left of space bar) and F10 key together repeatedly
3. wait several minutes for Acer eRecovery to load
4. after loading eRecovery, use the up and down cursor keys to select restore type.
5. following is from the initial screen for Acer eRecovery Management (V7.0.10)
Select Restore Type
[>] Completely Restore System to Factory Defaults
Restore your PC to factory default status.
All data on C: drive will be deleted.
[>] Restore Operating System and Retain User Data
Restore only the operating system of your PC to the factory defaults.
Files from your user accounts will be transferred to C:\backup.
This option will not remove persistent viruses or malware.
[>] Exit
Regarding WiFi problem...
1. may just need to turn on the WiFi by pushing the slide switch for it at the front right of the D255
2. you would do this after restoring to factory defaults above to ensure no software problems....
Mar 17, 2011 | Acer Aspire One PC Notebook
My ps3 does not load games or movies, screen stays still with the circular load symbol at the the top right corner, anything i can do at home to fix this?
Try this:
Mar 25, 2010 | Video Game Consoles & Games
I removed the flash player an now cant play games
the flash player is an easy fix. re-download the flash player. i am not sure if restoring it to factory will help. but if this is what you truly wish to do. restart and go into system restore. should be like f8 or something like that. (one of those f# buttons.) then go from there.
but re-downloading the flash would be easier and u wouldn't lose anything.
might i suggest backing up your stuff first?
Jul 06, 2009 | Acer Aspire 5500 5570-2609 Laptop
Ps3 froze
I was having the same problem. It was COD WAW causing the problems. I had to restore mine to factory defaults 2 days after I played the game but now everything has been working fine. If you can't see anything to get to factory reset, you can turn your power off on the back and then turn it back on, hold your finger on the turn on switch on the front for about 3-4 secs til you hear 2 beeps and it should come up and let you restore from there. Thats what I done and its been 2mths now and still no problems. I was on the verge of sending it in til I found this solution online. Hope it helps! BTW, i didnt do the full restore where you lose all game saves, just the easy one restore factory SETTINGS!
Feb 04, 2009 | Sony Playstation 3 (PS3) Console
The start up screen for the ps3 wont let me log in
Dec 25, 2008 | Sony Playstation 3 (PS3) Console
Hi my psp works fine untile i am literaly playing the game. then
you can try restoring it to the factory default settings but this may lose any saved data so back it up first on a memory stick. Scroll all the way down on the left menu and go to settings then restore factory settings
Dec 08, 2008 | Sony PlayStation Portable (PSP) Console
PSP MODEL NUMBER ABO12448630PSP2001
  1. go to the settings tab
  2. go to system settings
  3. scroll down until you see restore default settings
Oct 10, 2008 | Sony PlayStation Portable (PSP) Console
Error code 80010514
Sony has a few fixes for this.
Visit PLAYSTATION 3 System Software Update to download and install the most recent version.
To check what version of the System Software is currently installed on your PLAYSTATION 3:
  1. From the XMB™ home menu, go to icn_settings.gif(Settings) > icn_syssettings.gif(System Settings) > [System Information].
    The system will display the System Software version number.
OR During certain troubleshooting situations, it may be necessary to restore all of the PLAYSTATION 3 system settings back to their original "default" configuration.
  1. From the XMB™ home menu, go to icn_settings.gif(Settings) > icn_syssettings.gif(System Settings) > [Restore Default Settings].
  2. Once you select [Restore Default Settings], you will see a list of settings that will be restored. Scroll through them and press the icn_btnx_color.gifbutton to restore the settings.
  3. After the operation is complete, you will see the initial setup screen that appeared the first time you turned on the PLAYSTATION 3.
    You will need to go through the initial setup process before you can use the PLAYSTATION 3.
IMPORTANT
The Restore Default Settings feature will erase any previously saved settings and restore all of the following settings to the default:
  • BD/DVD Settings
  • Music Settings
  • Chat Settings
  • System Settings
  • Date and Time Settings
  • Accessory Settings
  • Display Settings
  • Sound Settings
  • Security Settings
  • Network Settings
  • Internet Browser Settings
Also, do not confuse "Restore Default Settings" with the "Restore PS3 System" option (the next option down on the menu). The "Restore PS3 System" will not only restore the default settings, but it will also delete all hard disk content. (You will lose all saved content from your PS3 system's hard drive if you use "Restore PS3 System.)
OR
Power-Cycle All Network Equipment Power-cycle means to turn the networking devices OFF (i.e., unplug it from the power source), and then to turn it back ON after a set period of time. This will allow the network devices to refresh its settings.
Please power-cycle ALL of your network equipment, including any wireless access points, routers, Voice Over IP (VOIP) modems, and broadband modems for two (2) full minutes. After 2 minutes, you can turn on (or plug in) your equipment.
Hope this helps. Good luck and happy gaming!! // //
Sep 29, 2008 | Sony Playstation 3 (PS3) Console
MSI CR600-001US Notebook Logo
37 people viewed this question
Top MSI Computers & Internet Experts
vsri9
Alun Cox
David
David
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
