Question about Fujitsu AMILO PC Laptops
Hi, I have FUJITSU V-2045 LAPTOP. I conneted with my samsung LCD TV. thru VGA. But I can view only image files. Not able to view the Movie. While run the Movie in laptop we can see the laptop but I didnt get in TV. Only I can see some Black areas.. How I can rectify this problem? Pls advice.. Regards Deva
  • 320 Answers
Check the video settings of your tv. Take the necessary setup,you must be running the laptop through the pc mode of your tv.
Posted on Nov 08, 2010
Connecting Eee pc laptop using xp to my tv with vga
Connect the VGA cable to the laptop and to the tv. On the TV take your remote and go to Select Input then select (PC or Computer or VGA just depends on your TV). if the image is not on your tv, reboot the laptop.
After rebooting if the image is not on the tv, try the steps below.
The video will show on most systems when you reboot without you having to do anything. Some systems will require you to hit the FN (Function key) located at the lower left portion of the keyboard + the correct F1 thru F12. Hold down the FN key then hit the correct key for displaying on the monitor (F1 thru F12). The correct key will normally have CRT/LCD on it or it will have the icon of a display.
May 09, 2012 | Acer Aspire One AOD150-1165 Notebook
Can't display with my laptop using VGA to 3RCA cable
Can't display where on another monitor or tv? Did you reboot the computer after plugging in the VGA Cable. Sometimes you have to hit the FN Function Key + F1 thru F12 to get the image to display. The correct F1 thru F12 key will have CRT/LCD on it or it might have the icon of a display. Press and hold the FN function key then hit the correct F1 thru F12 Key.
Mar 29, 2012 | HEWLETT-PACKARD ProBook Computers &...
How to connect amilo notebook to lcd tv
Hi. Check you have the appropriate connection on your TV for a VGA input. If you have, and there is also one on your laptop, then just get hold of a VGA cable and plug the laptop into the TV. Switch TV to VGA connection source, and on your laptop, there will be a function for switching displays on one of the F keys. Hold Fn at the bottom left of your keyboard and press the appropriate F key (such as Fn+F4 for example). This will switch the display to the TV. Hope this information helps.
Nov 06, 2010 | Fujitsu AMILO PC Laptops
To play laptop thru samsung tv I am attempting to play laptop movie thru tv. I have tried the rca y cable with 3.5 mm plug from headphones of laptop to red and white audio in on the samsung tv., no sound....
So you are connecting the laptop to the TV using VGA port of the TV, right? To get sound in the PC input mode, you need to use the PC audio input jack (green jack, mini 3.5mm jack) not the RED and White RCA audio input, they are for Composite Video AV inputs. That is how I have my laptop and TV setup to watch Netflix.
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
Jun 16, 2010 | Samsung LN52A850 52 in. LCD HDTV
Lead from external harddrive to tv- to show films,--usb connection from harddrive to 15pin to tv
Dear ragalgey,
As far As I can remember, most TV design to receive the signal to watch whatever you want limited to available TV station in your local broadcaster.
If you think you connect your harddrive to TV USB or 15pin (VGA cable) then you can watch the movie file from harddrive is a totally wrong!
You need a drive or a player for those file that capable to configure your TV to play them. Or at least you need a PC or Laptop Computer that played your harddrive then send the images/video via Video Out Jack (Yellow) from your laptop, or connect the 15pin VGA jack from Laptop PC out then plug in to your TV. In this case you'll need the Jack/adapter to convert from 15pin VGA from laptop to available Video jack on your TV.
Good Luck!
Best Regards,
bionic23
Dec 08, 2009 | Samsung Computers & Internet
Trying to connect laptop to Samsung HD LCD TV using VGA cable.
I had the same problem with my Samsung series 6 32" Lcd. After many hours of trying different settings and banging my head on the wall I found the solution. What the problem is your VGA cable not supporting the high resilotion of your Samsung TV. The simple solution is to buy a new VGA cable that supports HD. Take a look at this site you need something like this one! Hope this helps.....C
http://www.clearly-av.co.uk/PGM1110.html
Sep 19, 2009 | Philips 32PF7421D 32 in. LCD HDTV
Using my Samsung LCD TV as monitor for my Sony Vaio Laptop
yes sir..i think you must looking and buy VGA adapter 15 to HDMI complete with the HDMI cable set. you can find this adapter at the computer spare part store or electronic part store. not cheap but very usefull for you in the next day.
is very easy to connecting...plug you adapter to the output VGA VAIO.. connect the HDMI cable to adapter (like USB) and the rest to the input at your samsung lcd...good luck..
Jan 31, 2009 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
HOW TO CONNECT SAMSUNG LCD TV TO ACER ASPIRE
hi if you laptop has the s-video you can connect that to the tv an it would work
Jan 10, 2009 | Televison & Video
Connecting Laptop to LCD
It might have something to do with wether the VGA cable has all pins connected.
I think some cables don't have all 15-pins wired.
As soon my LCD TV works I will post the outcome.
Greetz Arno
Nov 07, 2007 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
Fujitsu AMILO PC Laptops Logo
64 people viewed this question
Top Fujitsu Computers & Internet Experts
Computer Links
Tony
Are you a Fujitsu Computer and Internet Expert? Answer questions, earn points and help others
