Question about Vacuums
The power cable connected to the philishave has got burnt. to be replaced/repaired
  • 320 Answers
The cable must be replaced as soon as possible to avoid any short circuit and damage to your appliances.
Posted on Nov 08, 2010
Can I buy a new head for philishave #5401
Replacement frames can be purchased as at the link below.
http://www.espares.co.uk/part/mens-shavers/philips/p/1114/128/0/0/540130/philishave-electric-razor.html
Or replacement blades can be purchased as at the link below.
http://www.shavercentre.com/canada/philips_parts.html
If you need any further assistance then if you advise what country you're in I'll look into it further.
Aug 27, 2011 | Philips Vacuums
I think my vacuum is even older. It's a tank type. My carpet attachment won't spin where the brush rotates.
The first thing to do is make sure the power nozzle motor is working. If it is, then check the belt by trying to spin the brush. If it spins freely, the belt is broken and needs replaced.
If the power nozzle motor is NOT running, there could be several things.
1. Make sure brush is clear and cleaned of all loose strings, cords, and other foreign matter.
2. Press reset button. Try vacuum again.
If it still doesn't run, ensure all wire connections are tight, and have no indication of arcing, i.e., blackened or burnt connections. Any such connections need replaced.
There could be a broken wire in the hose. Usually the hose will need to be replaced, but occassionally it can be repaired.
Internal wiring worn or broken. Needs repaired/replaced.
All repairs should be done by an authorized Aerus Electrolux service technician at an Aerus store. Check the phone book, or go to the following site to locate the store nearest you.
http://www.aerushome.com/storelocator/
Oct 13, 2010 | Electrolux UltraLux 2000 Bagged Canister...
I think i have burnt out motor. can it be repaired?
If the motor is burnt out, it can't be repaired. Replacement is an option, but the cost of a new motor plus labor may be more than the cleaner is worth.
Aug 23, 2010 | Dyson Vacuums
Wont shut Off
its the power switch, hoover has had that problem for years. I'd take it to a vac repair shop, sometimes the wires that connect to the switch get burnt as well and should be replaced.
Sep 16, 2009 | Hoover U6630-900 WindTunnel Bagless...
My henry hoover has just stoped working its not the fuse do you have any ideas
I had exactly the same problem.there were no burning smells coming from it so nothing seemd obvious.I then took it apart and checked that all wires were connected,which they were.Then decided to check the plug.After replacing the fuse I chopped the cable of (as it is a seald plug) and connected up a new one.Hey Presto,Henry was alive again.Hope this helps.
Nov 03, 2008 | Hoover Vacuums
Burnt out resistor
I'm in the same fix. I learnt that a new pcb is £68 so had the pcb repaired but after the machine has warmed up it now cuts in and out. Like you, I haven't been able to locate a wiring diagram so am trying a last minute lash-up before binning the machine:
A friend suggested that since we all seem to only operate the cleaner on full power I should connect the on/off switch direct to the motor bypassing the rheostat and the pcb as in old fashioned machines.
Aug 31, 2008 | Miele S251i Plus Bagged Canister Vacuum
Carpet attachment
Check the plug ends at the top of the wand and the plug going into the hose handle, also at the bottom of the wand. It sounds like they may be burnt, if so they will need to be replaced. One cause of these connections going bad is not turning the power head off when connecting or disconnecting. Therre are other causes, the switch in the handle is going bad, also some of these cannisters have a relay mounted by the vac motor, sometimes they go bad.
Mar 12, 2008 | Kenmore 25512/ 25513 Progressive Canister...
Power brush problem
Check the contacts where the power head attaches to the wands and also where the wnd attaches to the hose. If any of the contacts look burnt, then they will need to be replaced. Unhooking them when power is on is what causes most of these problems. But if they look ok, could be a problem inside the power head, or in the circuit board that is inside the cannister.
Feb 11, 2008 | Samsung Ultra Quiet 9073R Bagged Canister...
Vacuums Logo
79 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
