My maytag front loader washer is saying nd so i turned it off but the door wont open to get the cloths out how do i get the door open ???
  • Washing Mach... Master
  • 1,902 Answers
Hello
ND error in your Maytag Front Load washer indicates no drain issue. To start with check the drain hose for any clogs and try cleaning it, then check restriction in drain pump assembly or loose wire at the pump. Please get back to me if you have any other questions.
Kevin
Posted on Nov 08, 2010
Samsung wf8750lsw front loader door wont open
Not sure if you mean when it is fully off or operating, but if you mean that once it is operating the door won't open, then the following applies...
Once a front loader wash cycle starts, the door on a front loader is physically (electronically) locked until the full cycle ends after spin dry. This is to prevent anyone opening the door and letting all the water out in the middle of the wash cycle, which a lot of people try to do to put in more clothing etc.
Apr 11, 2014 | Zanussi F1045W Front Load Washer
Error code nd
my washer comes to the rinse cycle and wont go any further and beeps and the says "nd" on the screen. Door is locked and wont let me get my clothes out
Aug 04, 2013 | Samsung WF337AA Front Load Washer
My electrolux ewf 1087 front loader door wont open
You will need to remove the drum and reset the alignment.
The cloth is struck and has jammed on the drum movement.
click this link: drum removal
Jan 21, 2013 | Electrolux Washing Machines
My maytag washer mah-24 have a "nd" msg. which mean "not draining" and now i cannot open the door to take the clothes out. pls. help.
Unlocking the door:
Turn on the washer, but don't start any wash cycles. After a few minutes, the door should unlock itself.
Troubleshooting the "nd" message:
"nd" means "no drain". Empty the (now unlocked) washer and fill the wash tub with just enough water to see a bit of water at the bottom of the tub. Run a drain cycle and check a) if it drains and b) if there are any unusual noises while it is draining. If either event occurs during the drain cycle, the drain pump may have to be repaired/replaced.
Nov 25, 2010 | Maytag MAH2400A Front Load Washer
Can't get the door to unlock? Load in washer is beeping ND..not draining but after several attempts inlcuding shutting power off..still can't get the door to disengage?
In front loader machines there is a safety latch that stops you from opening the door if there is water in the machine. I think it needs power to release the latch, I am not familiar with this model.
You probaly need to drain the water off somehow.
Dec 16, 2009 | Maytag MAH2400A Front Load Washer
My Maytag Neptune front load washer displayed ND with 19 left in wash cycle. Door won't open, what can I do?
Not draining,throw rugs tend to clog this unit as do bobby pins and under wires I'm giving you a link to the repair manual it covers the 3000 through 5500 it will help you get the door open and the clothes out so you can start bailing...
http://www.servicematters.com/maytag_library/docs/16010061.pdf
Sep 13, 2009 | Maytag Neptune MAH5500B Front Load Washer
Can''t get my clothes out... water still inside
does it have a dial that you can manually turn to start the next cycle? You can usually drain the water by pulling the drain hose out from the wall drain behind hte washer....( usually just shoved in the drain not attached) but be aware that when you hold the hose below the water level in your washer it will start to drain. Then perhaps the door will unlatch.
Sep 09, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune Washer Door Locked
INSIDE THE SOAP LOADER THERE IS A LIME COLOR STRING PULL IT WILL UNLOCK LATCH
Apr 18, 2008 | Maytag Neptune MAH5500B Front Load Washer
Washing Machines Logo
108 people viewed this question
Top Washing Machines Experts
