Question about Intel D865GBF Motherboard
My pc with mother board dg33fb fail to start power led is on but system is not working cpu fan not working no display on moniter also only the dvd writer led keeps glowing as shown to a compter engineer he say bios is not working and is to be replaced and he is not getting new bios from any where as this series is not so popular due to being very expencive mother board please suggest the way to it
SOURCE: no display on moniter but cpu is running
change the RAM(RANDOM ACCESS MEMORY) of your pc.
Posted on Dec 12, 2007
  • 433 Answers
SOURCE: D865GVHZ mother board Doesnt boots
If everything was working fine before, and you flashed bios unsuccessfully, then yes, if would be a bios problem.
If you didn't flash the bios you should check the connections on your monitor. If that's okay then check your memory, hard drive and cpu.
Good luck,
Hank
Posted on Aug 18, 2009
gvctts
  • 103 Answers
SOURCE: Intel DG33FB motherboard problem
Dear User,
Please remove the RAMs from the motherboard slots and then switch on your computer. if it give beep for RAM then your motherboard is almost ok. if it does'nt give any beep then there would be problem at motherboard side. Then switch off your computer remove power. and then remove (CMOS) battery from motherboard to reset. and then start your computer while making sure that power is not connected to computer. this is for the releasing of power in motherboard so that BIOS gets to be factory defaults.
then install battery and RAM then powerup your computer hopefully it will work fine. if it does'nt then Motherboard have critical problem.
Please dont forget to rate my answer
Posted on Sep 05, 2009
  • 277 Answers
gove59,
Please check all Capacitors around the CPU. If the caps have dome shape caps then you need to have them replace. They are about .29 per cap and if you have a friend who solders... you should have computer back
sd03
  • 59 Answers
SOURCE: MY MOTHER BOARD LED ONLY WORKING CPU FAN AND POWER
please check your moniter
Posted on Jun 09, 2010
Cpu fan not working
Get a new one. They fail occasionally. The system cannot operate without it.
Jan 08, 2012 | Compaq Computers & Internet
Wnen i start my computer my moniter is going to sleep and when i disconnect from cpu it get start and show the cable is disconneted what is the prblem can you give a answer for this particular problem
check whether the pc is running. when it swithes on hear for boot sound. problem can be because of: computer ram failed mother board failed. power supplied failed moniter cable losse connection
Sep 16, 2010 | Computers & Internet
Intel mother board power light is on... but processor not working.. when switch on my cpu. the mother board powerlight displayed.mother fan is only one time run for sec.. processor not on
This is was with me too. I know how to fix it. Remove all cables from your cabinet, i mean like keyboard, mouse, moniter etc. Remove your ram too. Then press your power button from 30 seconds. wait for 10 mins plugin all cables and turn it on. Hope it works for you.
Best of luck.
Jul 22, 2010 | Intel D945GCCR Motherboard
Emachine T6520 Wont Start Up
Check your num lock key status press it on and off if hum lock led is on and off when u pressing then your cpu working fine. so check connectiopn of vga cable cpu to monitor.
Also some times display screeen resolution issue so when u power up press F8 key then enter in enable vga mode then you can chang escreen resolution to 1024*768.
but if num lock key is not on and offf then open the cabinet of cpu then find cmos cell on mother bord and pull it for 14 minutes then check .
Jul 04, 2009 | E-Machines eMachines Desktop PC
Moniter Screen Blank when my PC start....Giga byte 8S661FXME-RZ Mother board
try to remove the motherboard from the casing and see it if the have some capacitors or any circuit distroy. use other mother board for testing chek your hardware one by one maybe some of your hardware devices damages.
Jan 01, 2009 | Computers & Internet
No start up , button lites up - cd-rom wont open , noticed no fans on for 3d card or big one on mother board
If the cpu/heatsink fan isn't turning then most pc's will shut down to avoid further damage to cpu & board. I would first replace the fan if it's the one over your cpu. Try replacing power supply. If your board has the 4 pin plug, you must have that plugged in. But keep in mind if that fan isn't running a new power supply isn't going to make it start working. You have to have that fan working. Then go from there. If once it is working & other devices like video and/or roms aren't, check your memory. The best way to troubleshoot devices are to plug one at a time in and power up until the problem starts. Hopefully you won't have to go to that step.
Aug 14, 2008 | E-Machines eMachines Desktop PC
Emachine Will not boot
different beeping patterns are codes which indicate what part of the hardware has failed (ram, video card, cpu, ect). the fan failure would not cause beeps, and would not cause the cpu to fail unless already in windows. if you could find out the manufacturer of your motherboard you could check with them about what the paticular pattern of beeps which you are getting mean.
May 17, 2008 | E-Machines eMachines Desktop PC
AUS A7N8X -X Mother board AMDAthlon 27648 CPU No picture
if this is a built sustem out of the box with old monitor try another monitor oddly enough some arent compatible, you can check by looking at the prong patern.
May 10, 2008 | ASUS P5K Deluxe/WiFi-AP, iP35, S 775,...
ASUS STRIKER FORMULA
This Is A Processor error Message, CPU ( Central-Processing-Unit ) INT ( Intermittent Fault ) wrong Type Installed. ( Faulty Processor ) Disconnected Fan-Wire To Motherboard ?
Or if It,s INIT Then It Fails To Initialise The CPU.
Is The Board Auto-detect Settings ? Or Jumpered ?
Mike @ Compurepair.
** Please don,t Rate This Post until Your Problem/Issue Has Been Resolved**
Feb 27, 2008 | ASUS Striker Extreme Motherboard
Intel D865GBF Motherboard Logo
107 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
